KDF-Fusca Samba Member
Joined: March 08, 2011 Posts: 10 Location: Curitiba (Brasil)
Posted: Mon Mar 21, 2011 3:29 pm Post subject: CB 041 Plus heads X CB 044 heads : what's the differences? |
Hello everybody.
I would like to know the differences between a 041 Plus and a 044 head...
They seems to be look a like.
I just know that los banditos, los panchitos and 041 heads are almost the same...
Tanhks and sorry about my poor english. _________________ Take a look on my home made "sleeper 72" bug: http://kdf72.blogspot.com/ |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23947 Location: SHALIMAR ,FLORIDA
Posted: Mon Mar 21, 2011 3:44 pm Post subject: |
deferent casting?they probly run the oval port program on an 041 casting that they got real cheep a few years back, I remember them for 79.00(I think it was the o41) so they may of paid 40.00 |
slalombuggy Samba Member
Posted: Mon Mar 21, 2011 3:57 pm Post subject: |
The port design is totally different and the heads are a much heavier casting on the 044. I have both 041 and 044s as well as a new set of wedgeport 044s. You could never think of porting 041s like the 044s, WAY more material everywhere to work with.
brad |
Posted: Mon Mar 21, 2011 4:21 pm Post subject: |
slalombuggy wrote: |
brad |
Hummmm... I understand.
But the 041 Plus have some difference between a regular 041? It have more material, or just big valves?
I do have a set of 044 ultra mag port but didn't get them installed in engine... I will built a engine that will not need so much porting, so I am looking for a head that provide me more cooling than the 044.
In fact, all these Auto-Linea's heads are made very very near from home (about 25 kilometers)... But I have to buy at USA (there I pay less than half price when compared to Brasil!!!!!)...
Tanks! _________________ Take a look on my home made "sleeper 72" bug: http://kdf72.blogspot.com/ |
Posted: Mon Mar 21, 2011 4:44 pm Post subject: |
The 044s have very good cooling, a similar amount and style of fins as a stock head. I know we both live in very different climates but I have yet to see cylinder head temps of over 350*C after an hour of cruising around town in my buggy with a 2332. I think with a propperly done cooling system you won't have any problems
I do not have any experience with the 041plus cylinder heads so cannot speak about them. Perhaps someone else does.
brad |
Posted: Mon Mar 21, 2011 5:14 pm Post subject: |
brad |
Thanks a lot and go easy with that super buggy, heheh.
See you. _________________ Take a look on my home made "sleeper 72" bug: http://kdf72.blogspot.com/ |
Posted: Mon Mar 21, 2011 5:36 pm Post subject: |
KDF-Fusca wrote: |
The 044s have very good cooling, a similar amount and style of fins as a stock head. I know we both live in very different climates but I have yet to see cylinder head temps of over 350*C after an hour of cruising around town in my buggy with a 2332. I think with a properly done cooling system you won't have any problems
brad |
See you. |
I don't know the meaning of "go easy" Could you explain? LOL
brad |
Posted: Mon Mar 21, 2011 7:52 pm Post subject: |
you could also look at the mofoco heads made in usa.I have both 044's and mofoco 042's both wedge ports. I have about 40000 on the 044's and about 70000 miles on the mofoco heads. I have burnt my self on the headers but not the heads..but both sets are ceramic coated in the chambers&valves & exports. do they run hot??? I used a cheeo ir temp gun on the ex port and it said 197 on the outer square flat portion of the 044's thats all i had to check with, |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Mon Mar 21, 2011 8:56 pm Post subject: |
041's use 14mm spark plugs. The 044's use those damn worthless 12mm spark plugs that are twice as hard to find and twice as expensive. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed Mar 23, 2011 4:52 pm Post subject: |
mark tucker wrote: |
Good to know... What kind of spark plugs have the MOFOCO heads?
Are they better than CB heads or it is just a matter of option?
Thanks a lot. _________________ Take a look on my home made "sleeper 72" bug: http://kdf72.blogspot.com/ |
Posted: Wed Mar 23, 2011 4:55 pm Post subject: |
vwracerdave wrote: |
041's use 14mm spark plugs. The 044's use those damn worthless 12mm spark plugs that are twice as hard to find and twice as expensive. |
In Brazil fortunately these spark plugs are very cheaper... We have a lot of motorcycles that uses that kind of spark plugs.
But thanks for the help. _________________ Take a look on my home made "sleeper 72" bug: http://kdf72.blogspot.com/ |
mharney Samba Member
Posted: Wed Mar 23, 2011 6:17 pm Post subject: |
My 044s with 44x37 dropped a seat in #4I after 18K miles. I am going on 45K on some 043s with mega heat and duty and no problems yet. I got the 044s on their way to one of the kings of cylinder heads for hopeful repairs.
044s do run a little warmer, but really it comes down to abuse. 400 degrees or more is gonna cause you some risk.. and anything less is probably ok on any head. |
Posted: Wed Mar 23, 2011 6:19 pm Post subject: |
KDF-Fusca wrote: |
But thanks for the help. |
I can buy them over the counter at the local parts supplier my shop deals with, not much more than a 14mm short thread VW plug. I'll pay a bit extra for plugs for a much stronger combustion chamber design. And if you start getting into bigger valves more material between the plug and seats is more than worth a couple of bucks a plug.
brad |
madeyebiohazard Samba Member
Joined: September 07, 2010 Posts: 45 Location: north carolina
Posted: Wed Mar 23, 2011 6:40 pm Post subject: |
slalombuggy let me ask you, did you have to do any work to those wedge ports before you bolted them on to get that great cooling. cuase i AM LOOKING AT A SET OF MINI WEDGEPORTS that I just got from cb that need some help. their is alot of excess casting material on them in the cooling webs (some are 3/4s blocked) and the machine work in the chambers is not the same between the two heads. I think I am going to have to put in some quality time with these puppies or they are gonna run hot. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Wed Mar 23, 2011 7:57 pm Post subject: |
Its definately a good idea to clean out the casting slag out of the cooling fins, if the "ports" are blocked then your cooling will be affected _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
AlteWagen Troll
Posted: Thu Jan 05, 2012 3:06 pm Post subject: |
Anyone have a source on the autolinea 041 plus heads. CB no longer shows them on their site. |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2373 Location: Mount Airy, Maryland
Posted: Thu Jan 05, 2012 3:56 pm Post subject: |
brad |
X2
After blowing plugs out of their holes and stripping the threads with stock heads and stock HP I would much rather use a 12mm long-reach plug. It's much stronger, not going to blow out and allows less interference in the chamber. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
farmhand Samba Member
Posted: Thu Jan 05, 2012 4:15 pm Post subject: |
Look for the "EMPI 40x35 12mm spark plug" cylinder head. It is the same casting(Auto Linea). |
Posted: Thu Jan 05, 2012 4:22 pm Post subject: |
I know it's almost a year since the question ws asked, but yes, I did do some clean up work in the fins and around the outsides of the ports to get airflow through the head, only took about half an hour and a couple of drill bits......
brad |
AlteWagen Troll
Posted: Fri Jan 06, 2012 12:29 pm Post subject: |
farmhand wrote: |
Has anyone had any problems with these castings? I know they are autolinea castings with the empi logo on them but any feed back would be nice.
Thanks |
