can a tube style fuel sending unit be fixed?
groovydoobie
groovydoobie is offline
PostPosted: Mon Jan 02, 2012 9:25 pm    Post subject: can a tube style fuel sending unit be fixed? Reply with quote
hey all, I had a tube style sending unit that I tried to fix, I had apparently came detached from the inner base where this disc with a wire attached came off of the other side of the sender I guess, bottom line can I replace the wire in this thing and fix it? I soldered it back together but a little crooked the first time when I tried seeing if it would move it busted the wire so I also wanted to ask did I fudge it up by soldering it as well? and for my third question where’s the cheapest place to buy a new one? which I don’t want to do... thanks for any input.
69rulz
69rulz is offline
PostPosted: Tue Jan 03, 2012 8:21 pm    Post subject: Reply with quote
You have long sentences friend Very Happy . We need to know the year of your bus, i have yet to find someone who remakes the 68-71 units
Id rather die on my feet than live a life on my knees Right turn clyde
busdaddy
busdaddy is offline
PostPosted: Tue Jan 03, 2012 8:26 pm    Post subject: Reply with quote
therewasathreadonhereaboutfixinglaterunitsusingnichromewirefromtheelectronicsstore theearlyunitsaresimilarbutusealotlesswire waitifoundityayme Wink Razz
http://www.thesamba.com/vw/forum/viewtopic.php?t=380693&highlight=nichrome
Слава Україні!
groovydoobie
PostPosted: Wed Jan 04, 2012 6:47 pm    Post subject: Reply with quote
sorry fellas new to forums and am always runing a hectic schedual. no excuse for poor writing skills tho, so i have a tube style of a 73 and from searching it takes nickle-chromate wiring. so now i need to find how what thickness and how much wire to use...anyone have any opinions?
blue77bay
blue77bay is offline
PostPosted: Wed Jan 04, 2012 9:39 pm    Post subject: Reply with quote
Very Happy Very Happy Very Happy Very Happy Very Happy
I like hammers. Lots of hammers. Hammers and me go way back.
A large hammer collection is like an instant problem solver
Mark tucker wrote:,wack off as needed
groovydoobie
PostPosted: Thu Jan 05, 2012 1:12 am    Post subject: Reply with quote
So those links go to a float style type fuel sender I have one that's a tube style is this the same gauge wire?. I can prob guess on the length since it can't be too short or the wire won't connect on each side and too long would show the wire sagging...
seventyfo
seventyfo is offline
PostPosted: Thu Jan 05, 2012 7:25 am    Post subject: Reply with quote
They can be fixed, I had a brand new unit that the wire broke off at the connection. I soldered it back together and it worked fine.
85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey
Mountain Minstrel
Mountain Minstrel is offline
PostPosted: Fri Jan 06, 2012 9:37 am    Post subject: Reply with quote
I rewired a new one last year in order to get a better sweep of the gauge. I have some pictures somewhere and will find them and post later today.[/list]
Ken
69 Westy
99 S-10
04 Miata (Sold)
Desertbusman wrote:
Maintenance doesn't mean repairing it when it breaks. That's called repair.
miniman82 wrote:
Don't listen to him, people from Fresno are retarded. Rolling Eyes
groovydoobie
PostPosted: Fri Jan 06, 2012 8:43 pm    Post subject: Reply with quote
I'm glad to hear successful results, what type of wire did u use? I heard nickle chromate works and I have an idea of the gauge of wire, but what did u use?
groovydoobie
PostPosted: Fri Jan 06, 2012 8:44 pm    Post subject: Reply with quote
seventyfo
PostPosted: Fri Jan 06, 2012 10:33 pm    Post subject: Reply with quote
Used the wire that was there, just reconnected.
Mountain Minstrel
PostPosted: Fri Jan 06, 2012 11:39 pm    Post subject: Reply with quote
OK. here you go. I went to Jacobs Online and bought the 40 gauge nichrome.
Then came the hard part. This stuff is very thin and hard to work with. You have to run one continuous strand from the top (bottom in this picture) around the bottom (top in picture) and back to the top again.
Along the way it has to go through the metal tabs of the float like this...
It has to contact the wire on both sides. As the float moves up and down it effectively changes the length or wire as so the resistance and that gauge moves accordingly.
The hard part is soldering the wires while keeping them tight. The good thing is that the minimum order from Jacobs gives you enough wire to practice with.
The trick was to put something under the springy part (on the left side in the photo) while you solder it.
It still didn't give me a full sweep on my gauge but it gave me a full to just under half sweep. It is enough so that I know where I stand fuel wise. on of these days I will mess with changing the input voltage to give me a full sweep, but for now, this works.
Ken
69 Westy
99 S-10
04 Miata (Sold)
groovydoobie
PostPosted: Sat Jan 07, 2012 1:43 am    Post subject: Reply with quote
I've looked so long for this mountain minstrel, hopfully this helps a few more people wanting to save a few bucks. you've basically covered the whole procedure with pictures. Can't thank you enough now I can get my beautiful bus back on the road agin Very Happy
Mountain Minstrel
PostPosted: Sat Jan 07, 2012 1:33 pm    Post subject: Reply with quote
No problem, it is nice that there was something I could give back to this site.
Ken
69 Westy
99 S-10
04 Miata (Sold)
GeorgeO.
GeorgeO. is offline
PostPosted: Sat Jan 07, 2012 7:28 pm    Post subject: Fuel gauge problems Reply with quote
A little victory, I had a fuel gauge that was not moving. I took my dash apart to see if it was the gauge but everything was fine on that end. What If did notice is the amount of surface corrosion that was on the contact in on the voltage regulator (vibrator), and all the other contacts. I took the fuse box a part and found the black wire that supplied power to that circuit and found more corrosion in the fuse box. Using a cheap dremel tool the kind you get at Harbor Freight, I got out the bras wheel and started to clean up the contacts on the fuses, inside the fuse box and cleaned out with compressed air. Put it back together and lo and behold, my gas gauge now works. So if your bus has been sitting for long time, mine sat for 17 years, take some time to clean your fuse box and take your time not to cross any wires. Hope this helps guys.
groovydoobie
PostPosted: Sat Jan 07, 2012 8:01 pm    Post subject: Reply with quote
Thanks for the tip on cleanin up the fuse box, I didn't thnk about doin that mine just looks old no corosion but it never hurts to polish those contacts up!
askovronek
askovronek is offline
PostPosted: Fri May 05, 2023 8:01 am    Post subject: Re: can a tube style fuel sending unit be fixed? Reply with quote
I fixed mine just this past weekend. My gauge wasn't working at all. I had to pull the tank to replace the rubber hoses because there was a smell of fuel in the cabin and so while the tank was out, I pulled the sending unit. I tested conductivity through to ground and there was none. I did a little searching around and found that more replacement units have a second wire coming out for ground, but not the original VDO units. So I figured there was corrosion. My resistants wire was intact, so it wasn't that.
I ended up drilling out the rivet that held on both the positive and grounded the ground side. Because it's copper against Aluminium, there was significant corrosion. I re-attached everything with a machine screw and nut to hold it on tight.
Of course, in doing all this, I did break the wire from where it was soldered on. So re-soldered it, taking up the slack with the springy plate. There was still plenty of wire left.
I tested it outside the tank first and it worked fantastic! Shortly I'll have it in the tank and installed. No reason it shouldn't perform fine there as well.
I can't upload photos right now as it says I'm blocked, but will try again later.
askovronek
PostPosted: Sat Jun 03, 2023 7:44 pm    Post subject: Re: can a tube style fuel sending unit be fixed? Reply with quote
Finally got the photos uploaded. They are here: http://www.thesamba.com/vw/forum/album_search.php?search_author=askovronek&show_results=summary
'72 Camper
'00 EuroVan Camper
