Garage built bagged A-arm front end ...
Page: 1, 2, 3  Next
oxtaco
oxtaco is offline
PostPosted: Wed Jan 11, 2012 8:45 pm    Post subject: Garage built bagged A-arm front end ... Reply with quote
so let me start by saying hello. i semi-restored my 62 beetle back in high school and shortly there after i joined the navy. now being that i have spent about 8 of the last 12 years overseas the old girl had been sitting at my brothers house waiting for me. finally this last NOV i got the opportunity to pick this project back up and run with it.
the idea!! over the years i have built several mini trucks (bagged and bodydropped), 50's bombs and even simple bag jobs on friends VWs(type3's) but what i really wanted to do with my beetle was just have fun and build something i like. a simple retro custom exterior and interior and a "full" homebuilt suspension. this is what i have accomplished in the last three weeks and a couple old pics.
the last time i had her out for a drive (jun 2000)
my two flat windows
1835
the way it sits now.
soon to be A-arms
frontend underway
rear setup
first time test fit and layed out........ oh ya camber front and rear.
[/code]
GtiKyle
GtiKyle is offline
PostPosted: Wed Jan 11, 2012 9:00 pm    Post subject: Reply with quote
Maybe I'm confused on what the bar does, but how it's attached with those tabs does not seem very strong at all...Do you have some more pictures?
The wife approved build: http://www.thesamba.com/vw/forum/viewtopic.php?p=6152419
buguy
buguy is offline
PostPosted: Wed Jan 11, 2012 9:04 pm    Post subject: Reply with quote
Think there should be a gusset on the uprights/upper "A"?
oxtaco
oxtaco is offline
PostPosted: Wed Jan 11, 2012 9:21 pm    Post subject: Reply with quote
(buguy) upperarms have the inter tabs now i was waiting till i finished the upper bag mounts before i welded them on, also it already has the sway-bar and rack and pinion mounted i just didn't think to take pics before i put it all on the car for mock up. ill take some more once i pull it all back off.
oxtaco
oxtaco is offline
PostPosted: Wed Jan 11, 2012 9:42 pm    Post subject: Reply with quote
(GtiKyle) those are the lift link bars and the tabs are 1/4 plate, i have also plated most of the spring plate with 3/16 plate making it just under 3/8" thick in that whole area...... and i have also swapped out the spring plate bolts for 9/16 grade "8" hardware.... if its not strong enough i don't know how the stock shock mount could be (airkewld kit) that is just a 2" x 1/4 "L" shaped strip of cast.
but thank you guys for looking out.
hurley62579
hurley62579 is offline
PostPosted: Thu Jan 12, 2012 12:49 am    Post subject: Reply with quote
Thats some dam good progress for 3 weeks. Nice fab work. what the hell did they have you doing it the navy? Or have you just learned from working with mini trucks vws and such?
oxtaco
oxtaco is offline
PostPosted: Thu Jan 12, 2012 5:23 am    Post subject: Reply with quote
(hurley62579) I'm a Gunners Mate meaning i deal weapons and ammunition so no The Navy didn't teach me anything about fab work.. (: i just spent a lot of time in the garage growing up. but thank you for the complement.
AlmostOriginal
AlmostOriginal is offline
PostPosted: Fri Jan 13, 2012 12:46 am    Post subject: Reply with quote
I don't really like lowered bugs, but that car looks AWESOME!
My '65 Beetle "Herb". Originally Panama Beige. His forum (for now) - http://bit.ly/AbcyLC
California YOM Guide & Stories http://bit.ly/x8izYR
Looking for Catron Motors items and 1963 California plates #NHF 447.
kombi kid wrote:
I asked god for my first VW, I know he doesn't work that way so I stole a bug and asked for forgiveness!
buguy
buguy is offline
PostPosted: Fri Jan 13, 2012 6:14 am    Post subject: Reply with quote
Im curious how you came up with the design? The A arms are longer than anything I have ever seen. And why not equal length arms? Im no suspention guys, so im just asking questions here. I just thought the draw for A arms was to keep the spindle straight throughout the travel?
pOrk
pOrk is offline
PostPosted: Fri Jan 13, 2012 8:13 am    Post subject: Reply with quote
Very interesting front end design, can we see some more photos?
oxtaco
oxtaco is offline
PostPosted: Fri Jan 13, 2012 10:00 am    Post subject: Reply with quote
(buguy) the unequal length arms has to do with the fulcrum of the R&P, the lower arm are longer to keep the extended bag as strait as possible and also to increase the workload of the bag its self. the way i have it setup is to have very little negative camber from around 1" of lift all the way up to 9"" and when its laid out it has around 12 degrees of negative camber. the toe doesn't change till the car is lower then 1" and then it only change by about 1/4"
again thank you for the comments... i will try to get out there and get some more photos.
oxtaco
oxtaco is offline
PostPosted: Sat Jan 14, 2012 2:24 pm    Post subject: Reply with quote
so the mock up went well and i painted everything. in these pics you can see the R&P, sway-bar, bag mounts and compressor mounts. you can also see how i have made the main support frame a three peace unit so i can assemble it with the body on the pan. i have also utilized the rear cross member as the rear support
laid out
ride height
Viair 450's
pOrk
pOrk is offline
PostPosted: Sun Jan 15, 2012 9:26 am    Post subject: Reply with quote
This is great, although I don't see any adjustment for toe? You have it right on the money? Also how will this attach, looks like you have holes to attach it directly to where the factory beam would bolt up?
Keith
Keith is offline
PostPosted: Sun Jan 15, 2012 9:55 am    Post subject: Reply with quote
Toe is adjusted with the tierods.
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
pOrk
pOrk is offline
PostPosted: Sun Jan 15, 2012 11:19 am    Post subject: Reply with quote
lol dur
BadNis
BadNis is offline
PostPosted: Sun Jan 15, 2012 12:45 pm    Post subject: Reply with quote
Different
(o.\!/.o) 1967 Bug Yukon Yellow Project
http://www.thesamba.com/vw/forum/album_search.php?search_author=BadNis
mykidsbug
mykidsbug is offline
PostPosted: Sun Jan 15, 2012 7:11 pm    Post subject: Reply with quote
i gotta see how this turns out
oxtaco
oxtaco is offline
PostPosted: Mon Jan 16, 2012 2:44 am    Post subject: Reply with quote
here are some pics of how the main support frame comes apart. and then it installed on the car.
Spridle
Spridle is offline
PostPosted: Mon Jan 16, 2012 11:08 pm    Post subject: Reply with quote
I hope you made a good set of drawings. I would like a set up like this, and I'm sure there are a ton of others as well. Looks killer!
Thank you for your service.
bluntlunchbox
bluntlunchbox is offline
PostPosted: Tue Jan 17, 2012 11:52 am    Post subject: Reply with quote
Thanks for all the great pics. Really like this thread!!
Page: 1, 2, 3  Next
