Micropassatman Samba Member
Joined: January 27, 2006 Posts: 472 Location: Chico, CA
Posted: Thu Jan 19, 2012 6:12 pm Post subject: Reliable pressure plates for a bus? |
Just had my SECOND SACHS Brazilian PP FAIL on me today. This is my work vehicle and I can't have this unreliable SHIT in my bus anymore. Any ideas in terms of what might be the MOST reliable plate out there right now for a bus? KEP? LUK?
I need this baby R&R'ed by Monday and could use your help. Please! |
Inane Cathode Samba Member
Joined: September 11, 2009 Posts: 556 Location: Westminster, CO
Posted: Thu Jan 19, 2012 7:11 pm Post subject: |
KEP is who i chose for my pressure plate (stage II) (along with the KEP gold friction disk). It's held up just fine with 140 some odd hp the ej22 puts out, so im sure it's ok with the lawnmower you've got (j/k).
Only had one clutch cable break, and it was worn through at the clutch pedal (and also was as ancient as the rest of the bus i'm sure). Clutch feel is just fine.
<edit> Although now that i think about it i'm pretty sure i've actually got a 200mm pressure plate and clutch disk. so thats not really that helpful :/
Last edited by Inane Cathode on Thu Jan 19, 2012 7:22 pm; edited 1 time in total |
Desertbusman Samba Member
Posted: Thu Jan 19, 2012 7:16 pm Post subject: |
Why did it fail?
I've never had any problems with them. Got a picture of it? And you might tell us what year. Which T/O bearing system? _________________ 71 Superbug
71 Westy |
Posted: Thu Jan 19, 2012 8:07 pm Post subject: |
A few of the 'fingers' on the release mechanism just 'weaken'. It works but it feels like shit. Eventually it won't work at all. It's a '70 S/P 1600 with an 091 in it. Sleeved T/O bearing w/o collar on P/P - 200mm('71 bus or any late beetle). |
Posted: Thu Jan 19, 2012 8:09 pm Post subject: |
My local vendor has an EMPI knockoff of Kennedy's 1700lb plate for $99. Worth the risk? I'd rather have a 3-fingered plate at this point. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42553 Location: at the beach
Posted: Thu Jan 19, 2012 8:13 pm Post subject: |
Micropassatman wrote: |
You have an 002 Bellhousing on it? What type disk? _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Jan 19, 2012 8:15 pm Post subject: |
Regular Sachs sprung 200mm disc. |
Posted: Thu Jan 19, 2012 8:17 pm Post subject: |
Let me clarify:I drive delivering parcels in my bus for 8 hours a day. I need a plate that can be sprung/unsprung 1000 times a day and remain reliable. Clamping force isn't the issue here. |
SGKent  Samba Member
Posted: Thu Jan 19, 2012 8:49 pm Post subject: |
Wow. You might want to call FAT Performance as they show a German made F&S (Fichtel & Sachs) 200 mm diaphragm style in their catalog. Everywhere else showed Brazil. If they work you might stockpile a couple cause that is a lot of driving in a bus and it will tear up a clutch using it heavy duty like that. Stay away from anything unsprung or racing. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
SGKent  Samba Member
Posted: Thu Jan 19, 2012 9:34 pm Post subject: |
I had a similar 3 finger on my Jeep and it didn't last a long time HOWEVER if you can get a gauge block to set the finger height it is adjustable and you can get the height back. The drawback on a 3-finger is that they have more vibration in my experience. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Jan 19, 2012 9:40 pm Post subject: |
Vibration? At speed or during engagement? Anybody else have experience with the 3-fingered plates? |
SGKent  Samba Member
Posted: Thu Jan 19, 2012 10:12 pm Post subject: |
engagement. If one finger gets a tiny bit softer or wears more, the TO will rock as the pressure plate spins. It is less likely on a spring diaphragm. That is why three finger plates are adjustable. There is a gauge block tool where one uses the gauge block to measure the finger height above the flywheel so all three fingers are the same as the pivots wear and the springs get some miles. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
SGKent  Samba Member
Posted: Thu Jan 19, 2012 10:27 pm Post subject: |
one thing you might consider, is maintenance. As a clutch wears it tightens up. That removes freeplay. It also causes the diaphragm to be pushed in further each time you step on the clutch. Bowden tube bend also affects that. if you are over centering the clutch and pushing it in too far the diaphragms will wear out sooner. Also the clevis pin and parts can wear and give the illusion of freeplay when actually there is less than design. I relegiously maintain my clutch at 5/8 - 3/4 inch freeplay. That will help the clutch diaphragms last longer. At stop lights put it in neutral. On the freeway when stopped put it in neutral or move slow in 1st. That will also protect the engine thrust bearings. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Jan 19, 2012 10:34 pm Post subject: |
I also am religious about clutch maintenance. 3/4" freeplay, just replaced the clevis-pin and cable. |
SGKent  Samba Member
Posted: Thu Jan 19, 2012 10:46 pm Post subject: |
I think you are up against 1000 pushes a day. If you can get a German steel diaphragm that would be your best bet. I agree that it is the number of cycles that is wearing it out and not abuse or load. Metal only flexes so many times before it wears out. I used to drive a stick shift 71 bus, 73 fiat and 82 jeep cj7 in LA stop and go traffic. Only once did a pressure plate break or crack and that was a Borg and Beck diaphragm on the jeep at 80,000 miles. Usually they get weak or glazed. I would think maybe you could expect 30,000 - 40,000 miles between pressure plate replacements at 1000 pushes a day (2 yrs x 15,000 - 20,000 miles a year). Normally a disk would last me 40,000 to 50,000 in LA traffic and the pressure plate was good for two disks. I am doing this from memory but I do remember replacing them many times in the 300,000+ I owned each of those cars. I think the bus had 370,000 on it and the jeep 410,000 when I sold them. The fiat was only about 140,000. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Hoody Samba Member
Posted: Fri Jan 20, 2012 12:40 am Post subject: |
Once again as predicted the market did not bare the cost of Original German. Find an original German one. PM me with the specifics. |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Fri Jan 20, 2012 2:59 am Post subject: |
I'd probably go for a good used or NOS german pressure plate or a KEP plate if they are still american made.
I delivered pizzas from a bus for several years in the '90s. didn't have any clutch problems. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
DakDak67 Samba Member
Joined: September 25, 2011 Posts: 60 Location: Brisbane , Aussie land
Posted: Fri Jan 20, 2012 3:53 am Post subject: |
Yeh, i'm using a Kennedy stage 1 with a gutsy 2276.. no issues. |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5975 Location: Los Alamos, New Mexico, USA
Posted: Fri Jan 20, 2012 8:04 am Post subject: |
SGKent wrote: |
On the freeway when stopped ... |
I guess that's a Big City problem.  _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
