guatebus Samba Member
Joined: May 12, 2003 Posts: 398 Location: Oakland, CA
Posted: Fri Jan 20, 2012 9:10 pm Post subject: |
| cdennisg wrote: |
| What is the exact length of a straight piece of hard line before bending for this area? |
370mm _________________ '64 standard microbus
'69 deluxe microbus |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20989 Location: Sandpoint, ID
Posted: Fri Jan 20, 2012 9:37 pm Post subject: |
| guatebus wrote: |
| cdennisg wrote: |
370mm |
Thank you. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
LHG Samba Moderator
Joined: April 13, 2000 Posts: 1855 Location: LostHillsGuy, CA
Posted: Sat Jan 21, 2012 3:32 pm Post subject: |
Here is the disturbing thing. This is the line that almost failed. It appears to have a "factory" bend and it's the original style zinc plated line.
Compare it to the ones Hazetguy posted.
| hazetguy wrote: |
here is one i did, next to a factory original line:
_________________ Brian O'Kelly
Central Coast Chapter, CA - Vintage Volkswagen Club of America
www.centralcoastvwclub.com
www.facebook.com/groups/vintagevwclub/ |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4240 Location: San Diego
Posted: Sat Jan 21, 2012 3:53 pm Post subject: |
| I think the inside hub area of some drums, varies in diameter. Its not a machined surface. There isnt alot of room for error either |
Snoop Bob Samba Member
Posted: Sat Jan 21, 2012 9:57 pm Post subject: |
| LHG wrote: |
| hazetguy wrote: |
Although similar, when looked at in the context of being inside a brake drum assembly with associated hardware, that appearance becomes drastically different. _________________
| BarryL wrote: |
| Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
| EverettB wrote: |
| I would be interested in knowing the sizes of the various shafts. |
Culito 11010101
Joined: December 07, 2006 Posts: 5882 Location: Columbia Missourah
Posted: Mon Dec 30, 2013 5:20 pm Post subject: |
| LHG wrote: |
| hazetguy wrote: |
Two different types of wheel cylinders... _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
| johnnypan wrote: |
| ...dont pay no attention to Culito,he's a cornhole.. |
64 ragtop volks Samba Member
Posted: Mon Dec 30, 2013 5:32 pm Post subject: |
| The earlier pics are early wheel cylinders 63 down I believe and the last pic of blue bus is 64 and up? |
type47fan1 Samba Member
Joined: December 03, 2011 Posts: 828 Location: McDonough GA
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1153 Location: Burlington, WA
Posted: Tue Dec 31, 2013 8:23 am Post subject: |
Definitely a good warning. When replacing the braking system on my bus, the old line on the drivers side was a replacement and poorly bent, and was ready to fail also. I just bent mine by hand as well. _________________ -Adam
'59 Mango Bus
'69 Bug - Cobalt Blue |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2604 Location: UK (South)
Posted: Fri Jan 02, 2015 1:50 pm Post subject: |
| cdennisg wrote: |
| guatebus wrote: |
| cdennisg wrote: |
370mm |
Thank you. |
Hi
Are the bridging line lengths inside the front drums the same for all years' brakes?
I've ordered a kit of Cunifer lines this afternoon from CSP in Germany for a '67 bus with dual circuit brakes. I checked with them before ordering, and they said that their kit includes two 240mm lines for this purpose.
My truck is a '56 but I'm converting to dual circuit brakes at the same time, hence why I've ordered a set of '67 lines.
Which is the correct length? 240mm or 370mm?
Thanks
Andy |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 281 Location: Richmond, VA
Posted: Mon Feb 02, 2015 5:15 am Post subject: |
I took off my front tires this weekend to lube the front end and noticed brake fluid on the inside of the right front tire. Everything looked fine, then I remembered this thread. I found the exact same problem.
The PO ran the line incorrectly. It runs inside the spring and is not held by the clip (arrow).
