Rear Suspension Noise
Woreign
Woreign is offline
PostPosted: Sat Jan 21, 2012 8:44 am    Post subject: Rear Suspension Noise Reply with quote
I have clunky noise at the right, rear of my car. It only happens when going over bumps. I can reproduce the noise in the garage by lifting up on the rear bumper. I thought it might be a loose shock bolt, but both top and bottom are tight. While "bouncing" the car, I don't see any thing loose. Maybe one of the CV joints? Or bad bushings in the spring plate?
I serviced the CV joints about 2 years ago, and they seemed to be OK. They were dry at the time and only had some shiny spots. I'm not opposed to replacing them, but I'm concerned about the cheap after-market quality.
flyinglow94
flyinglow94 is offline
PostPosted: Sat Jan 21, 2012 9:19 am    Post subject: Reply with quote
The shock bolt may be tight but the bushing around it might be warn out. Pull the shock and then bounce the car and see if the noise is still there.
"What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.."
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
IAMIROY
IAMIROY is offline
PostPosted: Sat Jan 21, 2012 9:42 am    Post subject: Reply with quote
I agree, I had the same thing happen to my S-10 a few years back.
Woreign
Woreign is offline
PostPosted: Sat Jan 21, 2012 9:52 am    Post subject: Reply with quote
That appears to be the source for the noise! Removed the bottom shock bolt and the noise went away. The shocks and bushings are only a few years old, so they are OK. I think the holes in the suspension arm that the shock bolt passes through might be a little wallered out. The bolt may have loosened enough to cause the noise. The next drive will tell me for sure...
I'm glad that my CV joints are not the culprit, although I need to replace one of the boots. There is a small slice in it and it throws a little grease out of it. Being such a small slice (1/4") is there a way to seal it? Or should I get a new boot? And if so, should I replace all 4 for peace of mind?
flyinglow94
PostPosted: Sat Jan 21, 2012 11:05 am    Post subject: Reply with quote
If the CV boots are old I would replace them all but absolutely replace the torn boot befor it costs you more money.
Bobnotch
Bobnotch is offline
PostPosted: Sat Jan 21, 2012 11:47 am    Post subject: Reply with quote
Yeah, they're the same as an IRS beetle, so they should be easy to find (even in Germany).
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Woreign
Woreign is offline
PostPosted: Mon Jan 23, 2012 11:18 am    Post subject: Reply with quote
Well, the clunking noise is still there. The shock is not loose as I had suspected. I did notice that the spring plate bushings need to be replaced. The torsion tube is not centered in the spring plate cover. Could this be the cause of the noise?
I have new inner and outer bushing, but I'm hesitant to tackle this job on my own. I've even watched some videos on how it's done, but the whole spring tension situation worries me.
If I do tackle this job on my own, I should probably do it at the same time that I replace the CV boots, right?
Mike Fisher
Mike Fisher is offline
PostPosted: Mon Jan 23, 2012 11:46 am    Post subject: Reply with quote
Measure both sides now to see if they are different heights, before you start. Once they are apart your Magnetic Angle Gauge is your only guide to keeping/getting them level.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch
Bobnotch is offline
PostPosted: Mon Jan 23, 2012 11:50 am    Post subject: Reply with quote
I would. The bushing job follows along the same lines as lowering, so keep that in mind. Check out what's been said about lowering an IRS car, as that'll help you a little too. You might have to remove the clip for the brake hose to get enough room to swing the trailing arm down enough to clear the spring plate. Use a couple of heavy duty pry bars to get the spring plates off the lower stop, and you'll be fine, just watch your fingers. Wink I've found they like to stick in there at that end, so I use a bar above and below the torsion bar, to help "unseat" it.
The biggest issue (besides time), will be that the inner end of the bar will want to come loose first, and then you're stuck trying to get the bar seperated from the spring plate. I only mention this, as I had that happen to me twice while working on my 71 Notch. You'll need to unbolt the bottom front half of the rear fender, so you can get both out from under the car to seperate them. I plan on a full day doing it, but usually it takes less time. Very Happy
You'll also need some 3" inch long 10mm bolts (I use 3 of them), and some spacers to re-install spring plate cover. I'll work the cover on using the long bolts and spacer combos until I can get the stock bolts back in. I use a bottle jack to re-tension the spring plates on re-assembly (when keeping the stock height), as there's not enough room for my floor jack. A decent sized "C" clamp will also help you get the spring plates back on the lower stop. I hope this helps.
Tram wrote:
Tram wrote:
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jan 23, 2012 1:38 pm    Post subject: Reply with quote
Worn rubber spring plate bushings can also mess with your rear alignment.
No particular advantage to doing the CV boots at the same time, other than perhaps making it a little easier to get at all those cap screws.
It would be good to check the condition of the diagonal arm bushings at this time, though. Unfortunately, the original rubber style are no longer available, and you have to use the squeaky red urethane ones. Try putting some moly or other lube on those when installing to forestall the squeaking. Pay attention to the positions of those large washers when you take them out.
vlad01
vlad01 is offline
PostPosted: Mon Jan 23, 2012 2:59 pm    Post subject: Reply with quote
you can still buy the rubber ones, just look at cip1 . but yeah good poly bushes are heaps better used with the molybdenum disulphide grease .
don't use poly for the spring plates though Shame on you
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-501-541-C
