Dasdubber Samba Member
Posted: Mon Jan 23, 2012 5:20 am Post subject: Australian Custom 59 11 Window |
Hi everyone, thought some of you might like to take a look at 59 11 window microbus we have been restoring over the last couple of years for a customer. I run DAS Resto Haus here in Australia (VW restoration shop).....purists may not like the 'modernisation' of this bus, but we have attempted to retain an element of style consistent with the original design. So even if its not your 'thing', hopefully you can appreciate the work involved.
Cheers
Al
Well before I take a retrospective look and upload some of the 1200 odd pics we've taken throughout the resto, thought it might be good to preview how the bus looks in a 'close to completed form'
Posted: Mon Jan 23, 2012 5:22 am Post subject: |
It started out life as a semi solid 1959 Microbus.
Before I dive into a heap of restoration progress pics, I'll fast forward a little to give you an idea of the direction we took ..
Posted: Mon Jan 23, 2012 5:23 am Post subject: |
Like a lot of 50 plus year old buses, there are always lots of stubborn screws - rather than drilling and retapping all threads, where we can we use heat and then water/air to expand/contract the screw/screw plate to help uncrack them
So often people will assume "the rust is not too bad" when they can only see a small pin hole or two, but this is more often than not what is hiding underneath...
After blasting
The start of one of the major custom mods of this resto....a walk through conversion
A lot of Klassic Fab repair panels went into this bus (we are now the Australian distributors of these great panels)
Shaping walk through backs/sides
Posted: Mon Jan 23, 2012 5:25 am Post subject: |
A hell of a lot of time was spent gapping the doors and apertures throughout the welding stage
None of the buses were perfect out of the factory so often a bit of tweaking is required for the repair panels
Posted: Mon Jan 23, 2012 5:26 am Post subject: |
There are a lot of subtle (as well as some not so subtle) details on this bus including modified jacking points to keep the lines clean on the side of the bus as these are not very attractive in stock form. A bottle style jack will be used (if necessary) on the chassis rail (strengthened) but the jacking point has been 'cut and shut' so it can still be used a hoist lifting point
Lower windscreen sections had to be replaced as well
A donor door provided a replacement lower section (inner)
And a KF section plus a hand formed piece completed the rust repair on the outer skin
Lots of plug welds required for the cargo floor section
RHD locking ball handle Berg shifter is the ducks nuts
The start of the custom air conditioning installation
Another custom touch was the dash treatment including a glove box
I'll get some more pics up soon.
Cheers for taking a look
Al |
74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
Posted: Mon Jan 23, 2012 6:39 am Post subject: |
What a beautiful job! Your "customer" should be very pleased. |
Jacco Verveer  Samba Member
Posted: Mon Jan 23, 2012 7:42 am Post subject: |
None of the repair panels were perfect out of the factory so often a bit of tweaking is required for the buses
fixed it!!
edit forgot to say you make them work!!
Last edited by Jacco Verveer on Mon Jan 23, 2012 2:45 pm; edited 1 time in total |
Andy P Samba Member
Joined: February 04, 2001 Posts: 1166 Location: NSW, Australia.
Posted: Mon Jan 23, 2012 7:47 am Post subject: |
Showin' off the biz, eh, Al?
This is a killer build.  _________________ Cheers & God Bless
'62 Beetle
Jägdwagen |
Culito 11010101
Joined: December 07, 2006 Posts: 5880 Location: Columbia Missourah
Posted: Mon Jan 23, 2012 11:36 am Post subject: |
 _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Mon Jan 23, 2012 2:08 pm Post subject: |
jacco verveer wrote: |
None of the repair panels were perfect out of the factory so often a bit of tweaking is required [b]for the busesfixed it!! |
Thanks Jacco, you are right....a lot of the repair panels need tweaking....but likewise when you check door aperture and other internal measurements of these old buses and cross check them with factory specs, very few are exactly to spec after 50+ years. One repair panel will fit one bus perfectly, but will be not even close on another bus
For anyone interested, here are some of our other resto's:
http://dasrestohaus.com.au/gallery2/main.php
Cheers
Al |
Posted: Tue Jan 24, 2012 2:19 am Post subject: |
The start of the air con evaporator (blower unit) cover
Lots of little details like filling in the original brake fluid reservoir access hole
And fabricating a new heater duct
Hydraulic clutch
One amplifier is mounted behind each front seat and is covered (more details later)
As the owner is a cyclist, he requested we integrate bike mounts (x2) in the rear cargo area that fold away under the floor so remain hidden when not in use
Deluxe bumper trim has been installed on both bumpers
More dash work
Posted: Tue Jan 24, 2012 2:23 am Post subject: |
After quite a few hours the glove box door was close to completion
Coolers underneath the bus include the AC condensor, engine oil cooler and intercooler radiator (all with thermo fans mounted above coolers) plus small supercharger oil cooler - cable conduits/tubes etc have been relocated to allow fans to be mounted on top
Speaking of the engine, it will be a 2275cc type I based motor with AC compressor, single throttly body (coupled to Link G4 ECU), custom water to air intercooler, and a Rotrex supercharger which will produce around 7 pounds of boost. This was fairly early on in the mockup stage
Posted: Tue Jan 24, 2012 2:25 am Post subject: |
The start of the custom roof lining (fibreglass/mdf) with the rear sub box (sealed enclosure) housing the 2 10in subs.
Itchy stuff....
Front sections
A T3 engine access hatch was donated to the cause to make engine access easier (funny that)
Lots of time metal working the panels before filler work ensued
More pics to come
Cheers
Al |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4638 Location: Pasadena CA/DTLA soon China
Posted: Tue Jan 24, 2012 9:48 am Post subject: |
Awesome build, all that work already makes me feel tired and not go to work! _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
tanhis Samba Member
Joined: July 23, 2005 Posts: 659 Location: Rauma Finland
Posted: Wed Jan 25, 2012 3:43 am Post subject: |
Wery nice custom stuff there. _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
Posted: Wed Jan 25, 2012 4:33 am Post subject: |
Thanks guys, I know custom stuff is not for everyone...especially the purists, but hopefully people can at least appreciate the work involved even if it isn't their cup of tea.
....some more pics....
Plenums for fuel injection runners ended up rectangular as height was an issue under the supercharger
Top of runners were bellmouthed into plenums
Wedgeports were selected by the longblock builders
Another engine mockup with cardboard intercooler for dimensions
Intercooler water pump
Intercooler water reservoir
Supercharger oil reservoir
More bare metal work before filler is applied
Posted: Wed Jan 25, 2012 4:35 am Post subject: |
under the passenger seat we integrated a fire extinguisher mount which is on a hinged door
The first to be installed in Australia - a Red 9 Design double wishbone front end which incorporates rack and pinion steering
The shifter was relocated backwards for both better comfort and also to give more room when in first and third (for clearance to the air con vents)
A mid mount was fabricated and chassis horns and gearbox cradle have been boxed for extra strength
A custom spacer was machined to fit an aero-style filler cap and neck
Obviously in mockup stage at this point but the new filler/tank setup has a block back vent (to relieve pressure whilst filling) as well as a rollover vent which allows the tank to breathe but blocks if there was ever an accident and the bus ended up on its side/roof
arod Samba Member
Joined: March 07, 2004 Posts: 7323 Location: Casa del Carajo
Posted: Wed Jan 25, 2012 5:11 am Post subject: |
 _________________ the chupacabra is my homeboy |
PeteSC Samba Member
Posted: Wed Jan 25, 2012 6:07 am Post subject: |
delete
rubbachicken Samba Member
