Split Bus Dolly Jacks
Page: Previous  1, 2
j.pickens
j.pickens is offline
PostPosted: Thu Jan 12, 2012 7:16 pm    Post subject: Reply with quote
UZI wrote:
do the wheels lock?
Not designed to, but I suggested to Josh that he could crank the bolt down at the wheel axle to lock it. Though if you want to torque on the bus, it would be trivially easy to lower the frame on some jackstands, which would be safest.
BeaterBarndoor wrote:
Red Fau Veh wrote:
zuggbug
zuggbug is offline
PostPosted: Thu Jan 12, 2012 7:59 pm    Post subject: Reply with quote
Great job John
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
Searching 4 A SC
Searching 4 A SC is offline
PostPosted: Wed Jan 18, 2012 10:56 pm    Post subject: Reply with quote
Hate to repeat what others have said but be careful with those. I have that exact HF wheel setup on my little 300lb trailer and I was rolling it down my driveway and it spun on the pivot point and crashed the tongue to the ground.
Aaron
Samba Luddite
Aaron is offline
PostPosted: Thu Jan 19, 2012 1:42 pm    Post subject: Reply with quote
Spookers....
j.pickens
PostPosted: Mon Jan 23, 2012 9:27 pm    Post subject: Reply with quote
That's why I removed the spring pivot pins and mounted the plate to the base with four bolts, four nuts, and eight washers. That sucka' ain't moving.
Oh, and until this Sunday, Harbor Freight has the trailer jacks 50% off.
They are normally $40, I paid $27, and they are now at $20 each.
If you are interested, get two of them, and I'll share the design at the online machine shop so you can make your own.
http://www.harborfreight.com/merchandising-promoti...41005.html
Post up here if you want the plans, and I'll set up the link.
Red Fau Veh wrote:
cdennisg
cdennisg is offline
PostPosted: Mon Jan 23, 2012 11:27 pm    Post subject: Reply with quote
There's a masturbatory joke in there somewhere, I'm just not quite seeing it.
j.pickens
PostPosted: Mon Jan 23, 2012 11:38 pm    Post subject: Reply with quote
Huh?
Red Fau Veh wrote:
cdennisg
cdennisg is offline
PostPosted: Mon Jan 23, 2012 11:50 pm    Post subject: Reply with quote
j.pickens wrote:
Huh?
Manny understands my sense of humor. Where is he?
peecee69
peecee69 is offline
PostPosted: Tue Jan 24, 2012 6:13 am    Post subject: Reply with quote
I'd like those plans. I have some of those jacks I was trying to figure out how to do just what you did. Nice!
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
zuggbug
zuggbug is offline
PostPosted: Tue Jan 24, 2012 7:05 am    Post subject: Reply with quote
I would like a set - how much are the plates?
58 15 window
56 westy
j.pickens
PostPosted: Tue Jan 24, 2012 1:13 pm    Post subject: Reply with quote
Cost me about $95 dollars delivered.
It will cost you about the same depending upon shipping.
You also have to supply 18 3/18-16 by 1.25" bolts, 18 nuts, and 32 washers, along with the 8 front beam bolts and washers.
Red Fau Veh wrote:
zuggbug
zuggbug is offline
PostPosted: Tue Jan 24, 2012 6:33 pm    Post subject: Reply with quote
John thanks for the info........I am cheap, I will have to make my own. I do not have that in my engine test stand.
58 15 window
56 westy
j.pickens
PostPosted: Sun Jul 09, 2023 1:50 pm    Post subject: Re: Split Bus Dolly Jacks Reply with quote
There was a recent posting about this, and I posted up the template for the adapter plates. I am reposting this to help anyone interested to find it.
j.pickens wrote:
Here is the bolt template. It is a PDF file, since emachineshop.com requires you to pay to get a proper STEP file.
Just print the file, measure, and adjust your printer until the dimensioned width of the plate is exactly 7.75 inches and you'll have a correct paper template. The dimensions as listed are : 14.7500 x 7.7500 x 0.2500 "
https://drive.google.com/file/d/1w2wUUGQjU4CuiOpdkGqbCIi4Yisg_fqn/view?usp=sharing
If you want to have emachineshop make it, here is their proprietary .ems file which you can open in their software and order the part. I used their recommended aluminum, though that may have changed in 11 years.
https://drive.google.com/file/d/1pqc2fXLcVZyKM3naDNpT6giYCY930-6B/view?usp=sharing
As I recall, I was a tad off on the torsion beam holes. You might just cut them a mm over the depicted hole size and you should be good. I had to use a rat tail file to fix it, no biggie.
Red Fau Veh wrote:
Page: Previous  1, 2
Page 2 of 2
