Ordered new 5/16fuel lines, will these 7mm clamps fit?
SCM
SCM is offline
PostPosted: Thu Feb 02, 2012 10:29 pm    Post subject: Ordered new 5/16fuel lines, will these 7mm clamps fit? Reply with quote
I just ordered a bunch of Dayco J30/R9 fuel hose, 5/16". I would like to get these Oettinger crimp-style hose clamps
http://www.germansupply.com/home/customer/home.php?cat=455
but they are spec'd for 7mm. I'm hesitant to get the clamps since 5/16" is a bit bigger (almost 1 mm bigger) than the hose that the clamps are sized for. Does anyone know if this is a non issue or should I get different screw-style clamps?
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
buildyourown
buildyourown is offline
PostPosted: Thu Feb 02, 2012 11:05 pm    Post subject: Reply with quote
You can get those in fractional sizes. Commonly referred to as Oetinger clamps. Even good hardware stores will have them.
McMaster lists them as "pinch hose and tube clamps" and has them in SS to boot.
http://www.mcmaster.com/#standard-hose-clamps/=g2zupa
tencentlife
tencentlife is offline
PostPosted: Fri Feb 03, 2012 10:37 am    Post subject: Reply with quote
"Oetiker"
I'm the language nazi today.
Experience is death to doctrine.
buildyourown
PostPosted: Fri Feb 03, 2012 10:47 am    Post subject: Reply with quote
tencentlife wrote:
"Oetiker"
Thanks. I googled it to make sure I had it right and that's what it autofilled.
You are correct.
germansupplyscott
germansupplyscott is offline
PostPosted: Fri Feb 03, 2012 7:23 pm    Post subject: Reply with quote
The hose clips in the link should fit but to be sure you can measure the OD of the hose. Those clips are stainless. The shielded type clips are the best way to clamp fuel hoses IMO.
SL
