Skooby Samba Member
Posted: Sat Jun 18, 2005 9:42 pm Post subject: Removing Front Seats 1966 |
Hi everyone. Just bought my 'new' 1966 bug and I am currently working on taking out the entire interior. My only issue is I can't seem to take out the front seats!! Any bolts or anything of the sort I should be aware of?? |
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Sat Jun 18, 2005 10:03 pm Post subject: |
No bolts. Lift the adjuster lever up ... slide the seat forward as far as possible ... get on your knees and look under the seat ... if the spring is still there, unhook it ... continue to lift the seat adjuster while working the seat further forward. The seat rails will slide right off the front of the pan rails. If it sticks ... spray some rust solvent and keep working the seat forward and back ... it will eventually come loose. _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
Morganwerk Samba Member
Joined: December 30, 2000 Posts: 496 Location: Sacramento Valley
Posted: Sat Jun 18, 2005 10:08 pm Post subject: |
Sometimes it helps to hop in the back seat and while an assistant holds the lever up and minds the spring, put a foot on each side of the seat frame and push forward with your legs. Don't stomp, just constant, even pressure. _________________ Gary
1966 1300 Sea Sand
2003 GTi VR6 |
RJBeetle66 Samba Member
Joined: February 16, 2004 Posts: 120 Location: Rhode Island
Posted: Sun Jun 19, 2005 3:44 pm Post subject: |
some advice for afterwards....put some thick grease on the seat and pan rails before reinstalling them so you wont run into any problems with installing and sliding the seats for adjustments later on. Mine have been in for about a two years now and slide free when I need to move the seat forwards or backwards (no more wiggling the seat to make it move). _________________ 66 Bug (still no name as of yet)
94 Geo Metro "Molly"
possibly a 65 Chrysler Newport (will have to see about that one)
Volksrods.com alias... BrokenBeetle66 |
jps1145 Samba Member
Joined: March 16, 2005 Posts: 654 Location: Tehachapi, CA
Posted: Sun Jun 19, 2005 6:05 pm Post subject: |
Some later beetles have a spring stop on the tunnel side of the rail that will need to be pushed out in order for the seat to slide all the way off. I don't know exactly what year that started. But for sure it is on my 69.
-John _________________ Tehachapi, CA
'69 Baja
Vintage Funco single seater
My Baja |
Posted: Sun Jun 19, 2005 6:11 pm Post subject: |
there is supposed to be one on a 66 i'm pretty sure. Sorry, I cant help with taking it off, since my car never had them and I never really saw it necessary to replace them. If they're there, it should be pretty self explainatory to get off...as most things are on these cars.  _________________ 66 Bug (still no name as of yet)
obus  Samba Member
Joined: March 08, 2001 Posts: 11671 Location: just off Garden State Parkway Exit 81
Posted: Sun Jun 19, 2005 7:19 pm Post subject: |
I use generic packing grease on my rails and they have been fine. Wheel bearing grease is pretty good too, since it's heavy and waterproof. I think you can get a plastic packet of it for about $1 at autozone, and that should be enough to get all the rails on the seats and pan done. I used an acid brush to put it on, but your fingers will work just as well, you'll just be kinda slimy for a while after. haha
I dont really know if there's any name brands that are neccessarily good or bad, but for this application it shouldnt matter too much since they're not moved very often (I trusted the autozone brand for my Geo Metro wheel bearings...and I drive that about 50miles a day!).
Hope that helped! _________________ 66 Bug (still no name as of yet)
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Skooby Samba Member
Posted: Mon Jun 20, 2005 3:41 pm Post subject: |
Yeah! So about 45 min of pulling, pushing, nudging and screaming they finally came off. It was actually quite amusing because I was in the backseat pushing while my bf was in front with the adjuster lever up. Here I am in the baby-birth position screaming out of frustration because these damn things won't come off, then in a big *woooop* the seat comes un-stuck and goes flying off the rails. Nope, the seats did not have a saftey locking tab. Thanks for the info of putting packing grease on the rails though. I was wondering what I could put on there to not have this same problem again. This is kind of a related question; Anyone know of a good place to get decent/new seats for the vw? I'm not the tallest person in the world and I actually have to put a fluffy stiff pillow on my back in order to reach the clutch etc. I don't know whether this is due to the fact that I think the driver side seat might be broken or whether I'm just short. Anyone know if any kind of 'racing seat' might fit?? Not that I want to install racing seats, but something with that same shape; head-rest, higher back support....any suggestions?? |
rcs_80 Samba Member
Joined: November 10, 2011 Posts: 70 Location: Oakhurst, CA
Posted: Sun Feb 05, 2012 10:19 pm Post subject: |
I also have a 66 and Im having trouble removing the front seats. The levers on both seats seemed to be jammed pretty good in the crease behind the teeth. Any tips on how to get them out? I havent had much luck.
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Feb 05, 2012 10:37 pm Post subject: |
How did it get in there?  _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
kanniff Samba Member
Joined: October 12, 2009 Posts: 811 Location: West Coast
Posted: Sun Feb 05, 2012 10:48 pm Post subject: |
rcs_80 wrote: |
Your teeth aren't even locked in the spots.
you need to tug a bit harder. _________________ 1958 PGSG Standard |
rcs_80 Samba Member
Posted: Sun Feb 05, 2012 10:50 pm Post subject: |
Thats what I would like to know. There jammed in there really good. I just purchase the car a couple of weeks ago and both seats were already like that. I've been trying to remove the seats so that I can pull the carpet out to clean any rust and battery acid. |
ping349n Samba Member
Posted: Mon Feb 06, 2012 6:38 am Post subject: |
I had the same problem with mine a few days ago. Use a rubber mallet and alternate tapping on each side from the rear until it slides free. I had a 69 that was rusted to hell and back and it was the only way I could get it free. |
lchang003 Samba Member
Joined: December 23, 2011 Posts: 117 Location: Fiddletown,CA
Posted: Mon Feb 06, 2012 9:01 am Post subject: |
I'm in the same boat...I too have a orange back rest. Without it I can't reach anything and I am 5'3"!
Skooby wrote: |
I'm not the tallest person in the world and I actually have to put a fluffy stiff pillow on my back in order to reach the clutch etc. |
_________________ '66 Bug - Ocho
67 DD Panel - DD
60 Baja - Diablo
65 Bug - Betty
73 Baja - Dottie
79 Bus - Lil D
SST ~ Team Badfishie/DD
2013 HBG
2014 Mendo/Trinity
2015 Usal Beach Aftermath
2017 Oregon Start |
panicman Samba Member
Joined: December 18, 2011 Posts: 2657 Location: Canby, OR
Posted: Fri Mar 16, 2012 12:00 am Post subject: |
Try positioning the seat in the most forward position that the teeth will catch the rail stops. I suppose it may be possible for someone to cut and modify a seat frame if that doesn't work. |
