grandpa pete Samba Member
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Thu Feb 09, 2012 9:19 pm Post subject: |
VWDog wrote: |
Good technique, but I am going to sound like a pr!ck here... in future you may want to match up the grain (ie turn it 90 degrees) so that it matches the cabinets next to it. |
The advice is sound, but given the limitations of what he had to work with, it worked out alright. Interestingly enough, what GP did is not completely inconsistent with what Westfalia did with the top drawer. Here is a picture of my cabinets, and they are original. The top drawer is horizontal, so Gramps really only took it one step further than Westfalia did.
Mine:
Gramp's:
_________________ *****************
"I will gladly pay you Tuesday for a hamburger today."
Last edited by Westfabulous on Thu Feb 09, 2012 10:02 pm; edited 1 time in total |
Desertbusman Samba Member
Posted: Thu Feb 09, 2012 9:28 pm Post subject: Re: Laminate Repair...tutorial w photos |
skills@eurocarsplus wrote: |
bignick wrote: |
What page is this on in the Bentley manual? |
:2gunfire:
i used the same glue and it holds like a bastard. it's the best stuff i have used for sure |
When I did my cabinets and laminate replacement I didn't use that stuff. Usually it works great but not always. I've had to redo too many things using it. Maybe heat and low humidity makes the difference. My preference of choice on laminates was Titebond Carpenter Glue. _________________ 71 Superbug
71 Westy |
Posted: Thu Feb 09, 2012 10:49 pm Post subject: |
grandpa pete wrote: |
Weastfabulous I'll give you $60 bucks for that old cabinet...heck I'll even throw in my old one... ....thanks for playing...  |
Haha. Save your money Gramps. Once you get all black handles on those cupboards and drawers, your cabinet will be just as good as mine......and you'll still have $30 left in your pocket.  _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Fri Feb 10, 2012 5:19 am Post subject: Re: Laminate Repair...tutorial w photos |
Desertbusman wrote: |
bignick wrote: |
:2gunfire:
When I did my cabinets and laminate replacement I didn't use that stuff. Usually it works great but not always. I've had to redo too many things using it. Maybe heat and low humidity makes the difference. My preference of choice on laminates was Titebond Carpenter Glue. |
I've also had some bad luck with Weldwood contact cement. Formica used to sell their own brand of contact cement that seemed superior to anything else I've tried but a quick Google search doesn't turn up any sources for the stuff.
On another note, my favorite method of removing old laminate is to use an old iron on high heat; just something to try. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
Posted: Fri Feb 10, 2012 9:32 pm Post subject: |
can anybody tell me what year cabinet the one i bought is. I removed it and the front seats and the front seat swivel out of a 74 but can't find another 74 with the same setup p.s. the swivel passenger seat is the best thing i have done for the bus.It opens out the back useable space _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Fri Feb 10, 2012 9:54 pm Post subject: |
can anybody tell me what year cabinet the one i bought is. I removed it and the front seats and the front seat swivel out of a 74 but can't find another 74 with the same setup p.s. the swivel passenger seat is the best thing i have done for the bus.It opens out the back useable space |
'76 to '79 Westfalia P22. The P27 had the lift top and stove like mine. _________________ *****************
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
Joined: January 01, 2007 Posts: 17871 Location: sticksville, ct.
Posted: Sat Feb 11, 2012 7:15 pm Post subject: Re: Laminate Repair...tutorial w photos |
josh wrote: |
bignick wrote: |
:2gunfire:
On another note, my favorite method of removing old laminate is to use an old iron on high heat; just something to try. |
really? mine has been fine for over 4 years. i had to do the back of my cabinet by the hatch. connecticut's 'hot' sun has yet to faze it. maybe i just got lucky i use that stuff for everything. it is great for the vapor barriers on the doors too _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
VWDog Samba Member
Joined: June 24, 2005 Posts: 627 Location: Ladysmith, BC
Posted: Wed Feb 15, 2012 12:38 pm Post subject: |
VWDOG yhankyou for tour asstoot observation |
Easy there grampa pete. If you notice I did say "good technique". I wasn't out to piss you off or call you down. Hell, most people just live with crappy cabinetry, but you actually took it up yourself to do something about it. So Kudos. My comment was merely an observation.
I didn't know this laminate was so hard to find, but since this is the case I probably would have tried to conserve the material by just patching. Yes, maybe yours looks better in some ways than a patch, but if one were to have enough skill and have the right tools, a patch can be used to match very well. We should all be so lucky to possess all those skills. Cheers. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22662 Location: Escondido CA
Posted: Wed Feb 15, 2012 12:54 pm Post subject: |
VWDog wrote: |
The OG laminate is unubtainium new. I had a 77 I sent to my friend in the Czech Rep.-I had to re-do the two main doors as well as some small stips on his cooker cabinet. If I hadnt been totaly striping my cabineets for a total redo then Id of been hard pressed to source large sections of the OG stuff.
To fully do most cabinets with OG stuff, you need to find another set of OG cabs just to pull the laminate off to use on yours. Then the fun begins to hope you have enough especialy when you want the grain to run correct.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
VWDog Samba Member
Posted: Thu May 14, 2015 11:14 pm Post subject: |
At the risk of raising the ire of grandpa pete, I thought I should post up what one does when there is no way of replacing an entire piece of laminate and instead one has to work to graft on a new piece(to match the grain).
I did this repair to the hanging, or headbanger, cabinet in the rear of a 79 Westy. Someone had cut a huge speaker hole
Here is the laminate cut away from the good material on the cabinet face. At first I broke it at the weak points of the hole then I cut along a straight edge where there was solid good laminate
The exposed hole:
Using a jig saw I cut the hole square with a "standing" bevel. A standing bevel is one that you can see the face of.
The repair piece has a corresponding "under" bevel
Glue it in
Plane or sand it off
Glue down both pieces. I kept everything aligned using masking tape.
You don't have a laminate router? Use a Japanese hand saw using the wood as a guide from below
Then a file for the corners
I used a touch of Polyshades Bombay Mahogany stain to help hide the joint
With all the black vinyl trim in place, one can hardly see the repair joint line
1970 Lotus White Single Cab 2015- , 1979 Sage Green 2014-2015, 1978 Dakota Beige Westy 2012-2015, 1978 Neptune Blue Riviera 2012-2017 , 1970 Neptune Blue Bus 2010-2012, 1970 Deluxe Savannah Beige 2010-2012, 1985 Iltis 2010- , 1962 Single Cab 2010-2013, 1975 Brasilia? Bay/Split Kombi from Brazil 2008-2011, 1985 DoKa 1999-2009, 1971 Bus 1999-2000, 1968 Double Cab 1991-1998, 1965 Ghia 1987-1991, 1970 Westfalia-bought by Mum and Dad in 1970, sold by me in 1993 why-oh-why :_(
Posted: Thu May 14, 2015 11:25 pm Post subject: |
I noticed the other day on the front of my rear seat in the 74 - that Westfalia did it like you did with two pieces.
Nice work. _________________
t3kg wrote: |
1964 1500 S
eche_bus Samba Member
Posted: Fri May 15, 2015 11:11 am Post subject: |
Looks good! |
Posted: Sat Aug 22, 2015 8:40 am Post subject: |
Happened upon this three years after the initial posting ;
Update ; Decided bus was too slow and traded for NICE 63 bug .
The " New Owner " has torn the entire insides of the bus out to "make his own "
I'm really enjoying buzzing around in my new bug
I'm making a custom VW Type6 mini camper that's a lot faster on the highway .  _________________ 63 two fold rag
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Wed Sep 09, 2015 12:04 am Post subject: |
VWDog wrote: |
