thom Samba Member
Joined: October 12, 2000 Posts: 6269 Location: Sacramento
Posted: Mon Feb 13, 2012 7:54 pm Post subject: February 1962 Type 34 Ghia junkyard rescue - build thread |
This is the build thread for my 1962 Type 34 Karmann Ghia, # 18896 with matching engine #14504 (I have some catching up to do)
This car was originally pulled out of a junkyard in Fairfield in 1998 by Larry Edson & Richard Troy. Larry had collected a zillion parts for it over the years, a lot of them NOS, but finally decided it was time to let it go.
Here's a picture with Richard Troy following the forklift out of the yard.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 7:56 pm Post subject: |
Initial evaluation:
The little thermostat dealy has been nicked
Started digging out some of the bondo
Taking a good hard look at some of the damage
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Doesn't look too bad; there's a little bit of rust, but I knew that when I bought the car.
Hmm. It's a little worse than I thought
Holy mother of god, that's a lot of bondo! It was over 1/2" thick in places.
What's even better is the dark grey stuff at the bottom isn't bondo. I was heating it and it wouldn't budge, and it smelled really bad, but familiar. It's JB-Weld!.
We're gonna need a bigger repair piece.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 7:57 pm Post subject: |
I pulled the oil sump plate. Ick. Lots of chunks, but it seems to be petrified dirt; the chunks crush easily in my fingers. I don't think I'm going to be able to just jump in and drive this one.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 7:58 pm Post subject: |
I swapped in the 009 from my panel, and a spare 6v coil I had laying around, new plugs and wires, and after much futzing, I finally got it running. It doesn't run well, but there's no expensive noises. If I heard a car running down the street that sounded this bad I'd pre-dial AAA for the poor guy. Compression on 3 & 4 was only ~80-90lbs, 1 & 2 ~100-15lbs. It has that kerflufflel sound like a head wants to fall off.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 7:59 pm Post subject: |
Here's something you don't see every day - original, solid axle boots. They've more than likely never been changed
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 8:01 pm Post subject: |
Blasted off some of the rust and bondo
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 8:02 pm Post subject: |
Further dismantling of my T34. Trying to get the dash pads off was trying at best. I pre-soaked the fasteners with penetrating oil, took a small brush and cleaned the threads as well as I could reach, knowing that too much torque would rip the stud right out. I'm trying to be super-surgical-careful, but all of the studs on the top pad were turning. I lifted gently upwards, and the entire thing popped off in two pieces. Judging by the oxidation of the foam, it's been in two pieces for quite a while, and it looks like the studs shuffled off this mortal coil decades ago. The dash also has a rich Corinthian leather overlay which has been fun to peel off.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Disassembled the rest of the dash over the past couple of days. When the weather clears up, I'll blast some of the problem areas.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 8:03 pm Post subject: |
Did some more blasting today. Looks like I'm going to need to section in a good-sized chunk of the passenger-side floor pan.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
This is going to be one of my biggest challenges. Note how the door frame is pushed inward w/r/t the other side. This poor thing took a pretty good hit at some point. The door is full of bondo. I have a replacement door, but I haven't tried fitting it yet.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 8:05 pm Post subject: |
Pushed out my passenger-side B pillar a little. I need to straighten out the inner structure so the fender can go back where it is supposed to be. I could really use a new section, as this one is pretty hammered. I have one of the repro sections, but that won't begin to cover it.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Got my engine torn most of the way down.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 8:06 pm Post subject: |
This is exactly how it looked when I pulled the valve cover off.
One of these things is not like the other.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 13, 2012 8:07 pm Post subject: |
I've cleaned the heads up a little bit, and found some trauma from a previous life. My guess is they either sucked a valve or some other FOD.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22681 Location: Escondido CA
EatACactus Samba Member
Joined: January 22, 2010 Posts: 223 Location: Wareham, Mass
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Mon Feb 13, 2012 10:52 pm Post subject: |
Great save Thom I am glad to see you saved the car it deserves you
Keep up the good work. _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
Mom 25 months of standing up to Cancer R.I.P I miss you so much.
Buy my best friends stuff
http://www.thesamba.com/vw/classifieds/search.php?username=56TIMOTEO
(21:10:42) Jennepher: Russell is our proudest achievment. I feel like Samba created him from a little nugget of crap into a full blown adult. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23536 Location: Kimball, Mi
Posted: Mon Feb 13, 2012 10:56 pm Post subject: |
Now we can see the real progress. Nice to see it all in 1 place. You're going to find you'll get more comments on the car this way.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13958 Location: White Mountains Arizona
Posted: Tue Feb 14, 2012 7:06 am Post subject: |
Rare car and even rarer guy doing it best of luck. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
