anyone running a FK-10 on the street?
Page: Previous  1, 2, 3, 4, 5, 6
Alstrup
Alstrup is offline
PostPosted: Sat Feb 11, 2012 8:06 am    Post subject: Reply with quote
What I mean is, that we cant argue that they can make good power.
If they were ground on a fatter lobe, with the timing adjusted of course, they would make the same power and torque characteristics, but would not wear parts out, and would not need so high spring pressure to avoid valve float.
T
ALB
ALB is offline
PostPosted: Tue Mar 06, 2012 5:19 am    Post subject: Reply with quote
T
By fatter lobe do you mean bigger base circle? With the 86-88mm cranks that run into clearance problems, does it not? Do you have any experience with beehive springs?
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
westy richardson
westy richardson is offline
PostPosted: Tue Mar 06, 2012 10:07 am    Post subject: Reply with quote
Glenn wrote:
jamestwo wrote:
The FK-8 is the best cam for a TRUE hot rod daily driver.
I love my 2180 with K8.
I'm looking forward to my 2110 now Very Happy
90.5 x 82
5.4 rods
FK8 with 1.4 rockers
40 x 35 valves
CB 044's CNC ported
Weber 40 IDF's
Merged exhaust
All lightened, balanced and blueprinted
mark tucker
mark tucker is offline
PostPosted: Tue Mar 06, 2012 10:18 am    Post subject: Reply with quote
run a biger base circle and a smaller lobe lift and higher raito rockers.
ALB
ALB is offline
PostPosted: Tue Mar 06, 2012 10:09 pm    Post subject: Reply with quote
You've given me an idea, Mark; I have some Berg 1.54 rockers....
KopfenJager
KopfenJager is offline
PostPosted: Wed Mar 07, 2012 1:04 am    Post subject: Reply with quote
Any info on the FK42? just wondering how it compares to the other cams especialy the K8.
vince1
vince1 is offline
PostPosted: Wed Mar 07, 2012 2:40 am    Post subject: Reply with quote
The FK43 and 44 are closer to the FK8.
the FK42 is a nice low end torquey cam with not so much stress on lifters bores. Cool
my French blog https://vwpanelvan.wordpress.com/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ... Wink
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
KopfenJager
PostPosted: Wed Mar 07, 2012 2:57 am    Post subject: Reply with quote
I agree, Ive been running the FK42 in my rail, almost switched it out for a K8. Just wondering what the differance looked like on a dyno sheet.
ALB
ALB is offline
PostPosted: Wed Mar 07, 2012 8:56 am    Post subject: Reply with quote
The FK8 makes power to 6500 or so and has decent bottom end/mid range in a larger stroker motor(provided there is enough intake and exhaust for the motor). Where it shines, though, is above 3500 or 4000 rpm. In a vehicle that spends a lot of time putting around in the lower rpms (rough mountainous trail riding, rock crawling) this may not be the best choice. If you're talking about blasting up sand dunes, down fire roads or open desert, then in a lighter weight rail it could work well.
As you already know, the fast ramps/big lift of the FK42 provide a ton of low end/midrange power, the shortcoming being the 5500 or so rpm peak. What size motor is it in and how do you find it in your rail?
Simply swapping to the FK8 may be a disapointment; if the carburetion, intake port volume and exhaust are optimal for what you have now it may not have the ability to run the extra 1000 rpm with power. Remember, it's all in the combo.
As usual, just my 2 1/2 cents (I'm Canadian, eh). Al
MURZI
MURZI is offline
PostPosted: Sat Mar 10, 2012 7:33 pm    Post subject: Reply with quote
Ok, here is some first hand FK10 experience. Cranked up my buddies new 2110 build today and shoved it into the baja. 2110, fk10, CB rockers 1.4(1.45) actual, Tim's stage II's and 37 vent IDA's. IT FREAKING ROCKS!!!
Pulls hard even down low and keeps pulling to about 7K. I have stock 4.12 tranny with 28" tires and it had NO problems. Smooth idle..... Drives like a stock engine until you mash the pedal.
Next month I will finish my 2276 FK44 combo and will be able to update on the difference. For now......I say the FK10 is a killer cam. Smooth as silk!!!!!
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
fuguboy
fuguboy is offline
PostPosted: Fri Aug 10, 2012 12:34 am    Post subject: Reply with quote
Murzi
Which combo works best with stock gears ?
MURZI
MURZI is offline
PostPosted: Fri Aug 10, 2012 5:21 am    Post subject: Reply with quote
Two different cams..... Both totally streetable. The FK10 is a high revver and "comes on" at 2500-2800, not that it doesn't have bottome end torque, and revs to the moon. The FK44 is more linear and has huge torque, but with my heads still revs to 7k. The power is there from the bottom to the top.....
If i had to do it over, I would use the FK10 in both engines. My buddies car ,2110, fk10, IDA's , is driven all the time, 30-50 miles at a time, and it drives great. My car sits with a broken tranny... Laughing Laughing
The Fk44 would work BETTER with stock gears, but that is not to say the fk10 WON'T work...it will. One thing to consider with both cams, is that the lift gets in the 560ish (with CB 1.4's) range and you need to make sure your heads can handle that kind of lift.
In this video, the FK10 car is racing a 1915, 110 equipped car. My buddies 69 weighs 1940 lbs and he was running 8.50's all day long in the 100 degree heat. With some tuning and diet the car will be way faster.
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
58ragman
58ragman is offline
PostPosted: Sun May 15, 2016 3:06 pm    Post subject: Re: k8 vs fk10 Reply with quote
Ken Taber wrote:
I am woundering if you have tried a fk10? Our dyno and street testing has proved the fk 10 is a better street cam than a k8
whats the true RPM the fk10 comes in on most say 4000 but i fgure 2800rpms.
Whats the dyno say
Pizza Eater
Pizza Eater is offline
PostPosted: Mon May 16, 2016 6:28 pm    Post subject: Re: anyone running a FK-10 on the street? Reply with quote
Has anybody ran the CB FK-10 clone (2292)?
Looks like it has less lift, but longer duration than the FK10.
Adv. Duration 321°
Dur. @ .050" 270°
Lift @ cam .378"
Lift w/1.1:1 Rocker Arms .415"
Lift w/1.25:1 .472"
Lift w/1.4:1 .529"
Lift w/1.5:1 .567"
58ragman
58ragman is offline
PostPosted: Mon May 16, 2016 7:27 pm    Post subject: Re: anyone running a FK-10 on the street? Reply with quote
duration is 270 at .050 they always been that way but were written under duration as 266 or posibly 268 .
call down to engle they will set anyone straight.
A lot of people complain they want the advertised number 266 but 266 and 270 at .050 is nothing to balk about.
If your motor has serious power enough to handle a fk10 cam then whats another 4 degrees correct
Page 6 of 6
