oil cooler seals...once again
69sback
69sback is offline
PostPosted: Sun Feb 26, 2012 11:18 am    Post subject: oil cooler seals...once again Reply with quote
ok folks im sorry to beat this oil cooler thing to death, but i'm pretty frustrated. I believe I have the later style cooler and case, but please view the pics below and verify. The oil cooler is stamped and the case has about 10mm oil passages. The seals i'm using are the common seals used on the doghouse coolers. They are soft, pliable, and fit snug in the case.
Here's a link to my photos:
https://plus.google.com/photos/115732701725673114721/albums/5713504405290425537
The last time I had it all together it still leaked...not tons of leakage, but enough to where it would leak down on the cylinders and i could smell it. and over maybe 200 miles it would leak 1/4 quart.
THe only thing i can think of is that I incorrectly torqued down the bolts. What should I torque them to? the book i have refers to the cooler with the spacers installed so i know that's no good...
i can to see if the relief valve is stuck, but i doubt that's it.
the frustrating part is that it leaked LESS with the old seals!!! arrrgh! I should have never touched it.
I'm considering trying to use a little silicone to help seal it up...anyone try that?
So basically my 2 questions are..what should i torque the nuts/bolts to and is the option of silicone good or not?
Quick responses would be nice as I need to get it back together today!
THanks
David
[/img]
Bobnotch
Bobnotch is offline
PostPosted: Sun Feb 26, 2012 12:03 pm    Post subject: Reply with quote
Don't use silicone, and don't use the spacers. I couldn't find a torque spec on the oil cooler to case bolts, so you'll have to ask someone else on that. Yes, you do have the later oil cooler and case combo.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
69sback
69sback is offline
PostPosted: Sun Feb 26, 2012 12:25 pm    Post subject: Reply with quote
ok thanks for confirming i'm using the correct seals!! That helps immensely.
I found the torque spec here...
http://www.thesamba.com/vw/forum/viewtopic.php?t=236499&highlight=oil+cooler+torque
5 ft/lbs. not much but i guess that's why mine leaked after this last install because i torqued them down too much...I hope I didn't ruin the oil cooler mounting areas.
I'll put it together and let you guys know how it works...
W1K1
W1K1 is offline
PostPosted: Sun Feb 26, 2012 12:45 pm    Post subject: Reply with quote
I use the permatex hi-tack spray a gasket on the oil cooler side of the seal. Mine leaked twice before i did it this way. I spray the seal, let it get tacky, then install the cooler. If you install the seal too soon it will be slippery and won't seat, it will want to squish out.
It's not the textbook way, but it worked for me
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
69sback
69sback is offline
PostPosted: Sun Feb 26, 2012 12:57 pm    Post subject: Reply with quote
hmmm....the high tack spray sounds interesting. i might have that a try.
ok...so 5 ft/lbs is pretty small amount. i don't have a torque wrench that goes down that far. when it torque it down to what i feel like would be 5 ft/lbs the cooler still feels a little loose. is that about right?
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Sun Feb 26, 2012 6:34 pm    Post subject: Reply with quote
i have to do mine again also
the last time i did i didnt have correct seals and had to RTV them Sad Sad
but hopefully this week i will take the F.I. off and change them
as well as install a T1 alternator...maybe
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
69sback
69sback is offline
PostPosted: Sun Feb 26, 2012 6:50 pm    Post subject: Reply with quote
how did you post those pics? do you host them somewhere and then insert an img html tag?
so i got it all together...i hate doing the job...3rd time now. put it all together but now i've got a nasty vacuum leak. I can close both carbs and it still idles. hehe I used all new seals, looks like the driver's side carb leaks air from the throttle lever....there's some serious play in it and the idle races (or chokes) when i spray carb cleaner near there. but anyway, it runs fine with the leak. hehe. i know i'm getting bad gas mileage, but whatever, i'll get to it another day.
I drove the girlfriend and I to grab a cheeseburger and a beer...about 10 minute drive each way...no leaks yet! I'll report back in a couple days.
I ended up using just a little RTV silicone on the oil cooler side. Just a little.
I torqued the bolts down probably more than 5 ft/lbs. I would guess maybe 7-10 ft/lbs? It's hard to tell....
69sback
69sback is offline
PostPosted: Tue Feb 28, 2012 6:57 am    Post subject: Reply with quote
no oil leak so far! and i'm using 10w40 now too....soon to switch to 20w50 since the weather is warming up...
69sback
69sback is offline
PostPosted: Wed Mar 28, 2012 11:47 am    Post subject: Reply with quote
no leakage from the oil cooler seals. I need to track down some other leaks next. Smile
They key to doing the oil cooler seals correctly is not overtightening...
ataraxia
ataraxia is offline
PostPosted: Wed Mar 28, 2012 12:42 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=6
I created a Google images album in Picasa and use the link to the picture using the BB code. Use "preview" to see if it worked before posting it.
sharkskinman
Lateral Lunatic
PostPosted: Wed Mar 28, 2012 12:50 pm    Post subject: Reply with quote
Just upload them into thesamba gallery
PS4 "NKOGNEATO"
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Mar 28, 2012 7:53 pm    Post subject: Reply with quote
Certain combinatoins of coolers and seals required washers, some didn't. Maybe you are masjing them down because a washer is missing?
Someone posted a comprehensive list fo the variuos configurations, can't find it now.
sharkskinman
Lateral Lunatic
PostPosted: Wed Mar 28, 2012 11:27 pm    Post subject: Reply with quote
whats the number on the case
cuz that cooler is a late cooler
(same number as my 71 cooler thats OG)
the seals that you should use are the ones that only have a small amount of back n forth in the holes in the case
mine were orange
Left is the 8mm right is the 10mm
i used the right ones and i have NO Leakage
the ones on the left will fit VERY LOOSE
the one on the right will have less than 1/8 inch play in the whole
these are the 8mm to 10mm seals
They have a angle to them
FAQ on VW Oil Cooler Seals
http://www.oceanstreetvideo.com/vwtech/OilCoolerSealFaq.html
PS4 "NKOGNEATO"
yoyoma
yoyoma is offline
PostPosted: Fri Jan 12, 2018 3:58 pm    Post subject: Re: oil cooler seals...once again Reply with quote
Hello, where is the oil cooler and seals located and how are they accessed on a type 3? 1971 fuel injected, specifically.
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Jan 12, 2018 5:11 pm    Post subject: Re: oil cooler seals...once again Reply with quote
Buy a brown VOLKSWAGEN SERVICE MANUAL Type 3 1968-1973 Bentley manual from Amazon.com etc and get to educating yourself as we all had to do. It's our Bible and you will need it from the very beginning! Idea
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
mcmscott
mcmscott is offline
PostPosted: Fri Jan 12, 2018 5:47 pm    Post subject: Re: oil cooler seals...once again Reply with quote
No, the oil cooler is located under the spare tire well, you access it by looking under the car, see it? No? keep looking, its there,,,,,,,,,
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
KTPhil is offline
PostPosted: Fri Jan 12, 2018 6:47 pm    Post subject: Re: oil cooler seals...once again Reply with quote
The manuals will tell you about pulling runners, wires, hoses, tin, and such.
But depending on what's up with your engine, it may be better to drop the engine and do other cleanup/refreshing while it's out. Trying to do it in the car is a PITA so it's a worthy tradeoff.
Mike Fisher
PostPosted: Fri Jan 12, 2018 7:25 pm    Post subject: Re: oil cooler seals...once again Reply with quote
VW TYPE 3 1500 & 1600 Haynes manual is also good & most of us have a Bentley and a Haynes.
Bobnotch
Bobnotch is offline
PostPosted: Sat Jan 13, 2018 11:35 am    Post subject: Re: oil cooler seals...once again Reply with quote
Under the left side intake runners (those 2 big silver tubes), under the cooling tin hump. You have to pull the generator, the intake manifold (tubes and plenum), and the cooling tin before you can get to the oil cooler. Then it's just 3 M6 nuts to remove it.
Tram wrote:
Tram wrote:
Simon DeCasas
Simon DeCasas is offline
PostPosted: Thu Oct 14, 2021 12:06 pm    Post subject: Re: oil cooler seals...once again Reply with quote
What is he part number for the 10mm seals I get conflicting answers and are planning to run 10mm case and 10mm cooler, but I also have 10mm coolers and a 8mm case so I'm at a loss.
