Long Spoon Popout Window Latch Questions..
Jack Frisch
Jack Frisch is offline
PostPosted: Thu Apr 12, 2012 11:59 pm    Post subject: Long Spoon Popout Window Latch Questions.. Reply with quote
Installed a long spoon latch on my 67 buses rear cargo door's pop out window tonight in order to get the windows to pop out more., and when closed and I go to open the door, the latch drags across the surface of the interior when he door opens
I have no spacer under where the latch gets screwed to the interior using three screws, am I suppose to use a spacer in this location, is that why its touching and dragging?
any help appreciated
Jack
1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
1967 13 Window Walk-thru Deluxe Bus, stock 1500 engine, Titan Red/Grey, Platinum Mesh interior, orig. & stock
1966 GT350H Shelby Orig. low mileage car
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Gallery Classifieds Feedback
tasb
The Distributor Distributor
tasb is offline
PostPosted: Fri Apr 13, 2012 6:17 pm    Post subject: Reply with quote
The only windows that were supposed to have the spacers were the rearmost which are past the cargo doors. Not sure why you are having the problem. The long spoons were not installed stock on 67's.
Roads Scholar
Member# 2059
Jack Frisch
PostPosted: Fri Apr 13, 2012 6:52 pm    Post subject: Reply with quote
yes, not stock but everything about how they mount and or work is suppose to similar and or exact to buses that do use and or come with them.
so i am wondering why the issue
olliehank47
olliehank47 is offline
PostPosted: Sat Apr 14, 2012 8:05 am    Post subject: Reply with quote
Your problem may be that the long spoon latch is mounted on a low hinge door (67). There is a picture of a long spoon latch mounted on a rear cargo door but it is a high hinge and therefore the outward swing of the door may be just different enough to allow the latch to clear the interior. http://www.thesamba.com/vw/classifieds/detail.php?id=1245616
Just a theory as I have no personal experience. Spacers on the door are not used as the mounting plate for the latch is welded to the outside of the frame rather that inside the channel as for the interior windows.
