eliotv Samba Member
Posted: Sun Nov 21, 2004 9:36 pm Post subject: Media Blast, Soda Blast or Chemical Strip |
I have a 55 semi that I'm getting ready to restore. My question is what is the best way to strip the vehicle to bare metal? The car has very little rust. I've heard that media blasting can damage the metal. If you dip the vehicle, how do you seal the surfaces that you can't get to (Heater Channels, seams, etc.)?
After getting the pan to bare metal, what do you guys think about sealing the pan with a product like Rust Bullet or POR 15 and then going over that with something like Rhino Liner? Would that be a big NO NO If I was trying to keep the car mostly vintage? Thanks for the input  _________________ Nubby |
3Bugs Samba Member
Joined: December 27, 2003 Posts: 503 Location: Palmdale California
Posted: Sun Nov 21, 2004 9:54 pm Post subject: |
Everyone has their own opinion and experience here so I will just tell you mine.
I blasted my Ghia and yes it did cause problems with warping and stretching in places. It all depends on how good the operator is and what they know about metal. Blasting has almost as many problems as dipping when it comes to sealing everything up. The media gets into places you would not even think were on a beetle.
I striped my other cars with chemical stripper and had a more pleasant experience with it. Its not s bad s you may think. It took me a long weekend to do the entire car in and out. If you search this forum you will find many articles on this subject.
POR 15 is what I used on the pan but many say good things about rust bullet. I used truck bed liner for undercoating and inside the wheel wells but the original VW’s had black shiny pans on the inside. _________________ 3Bugs
Well, actually a 67 Bug, 72 Super, 61 Ghia and a 2004 Beetle Vert (sorry) |
coad  Samba Scapegoat
Posted: Sun Nov 21, 2004 10:00 pm Post subject: |
I'm not trying to sound like a jerk, but you really should use the search function for answers to this question. There's been tons posted on the pro's and con's of each method, and none of them are without a downside.
I think you'll find that dipping has the more serious potential problems, but there's probably an hour's reading right here on The Samba with the case made for and against each method.
A big part of it also depends on the condition of your car and the condition of the existing bodywork and paint. You'll almost need to study the information then apply it to your individual situation. |
eliotv Samba Member
Posted: Sun Nov 21, 2004 10:26 pm Post subject: Sorry |
I'm new to this site Thanks for the advice. _________________ Nubby |
Posted: Sun Nov 21, 2004 10:55 pm Post subject: Re: Sorry |
eliotv wrote: |
I'm new to this site Thanks for the advice. |
hey, it's all good. Just trying to tell you that your question is one that just doesn't have an easy answer.
(I like bead blasting, but wait right here and somebody else will wander by and tell you I'm nuts.) |
thebucket Samba Stockbroker
Joined: April 06, 2004 Posts: 3734 Location: Houston Texas
Posted: Mon Nov 22, 2004 1:38 am Post subject: Re: Sorry |
coad wrote: |
eliotv wrote: |
you're nuts coad  _________________ ITMC-El Presidente
OG 55 bullet 3 fold....
http://www.thesamba.com/vw/forum/viewtopic.php?t=150858&highlight=thebuckets++++fold |
Mr. Bungle Samba Member
Joined: December 11, 2003 Posts: 1707 Location: Vancouver BC, Canada
Posted: Mon Nov 22, 2004 3:52 pm Post subject: |
imo, blast. dont dip.
if you think about it, dipping will remove everything from every nook and cranny and in some places it will be tough to get primer/paint in there to cover up the bare metal.
try walnut shells to remove paint and filler and then sand to remove rust. find someone that does acvw's and knows the temperment of the metal. to much sand on one area for too long will create enough heat to warp the metal. especially on large surfaces like hoods and roofs.
por15 or rust bullet is fine. skip the rhino liner. |
2332cc Samba Member
Posted: Thu Dec 16, 2004 8:58 pm Post subject: |
Baking Soda blast works well and leaves the metal shiney, exactly like it looked when VW stamped it from day one. A friend's '62 was Baking Soda blasted and it revealed an unscathed ink stamp on the interior of the lid. All metal had very minor to no stress, depending on area structure. Sand blasting is brutal for body panels and dipping, no experience personally, just hear bad things regarding long term problems.
I will have my '55 3 fold Baking Soda blasted and I will chemically hand strip the rest. The pan can be sand blasted with no ill effects.
GOOD LUCK!  _________________ Make it Fast, Make it yours. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17095 Location: GFK 31 Year Vet
Posted: Thu Dec 16, 2004 9:29 pm Post subject: |
Mr. Bungle wrote: |
Plus the chemical has a tendency to collect and ooze out of body seams after your car has been painted then your new paint job in a few months is f%$ked on the first nice hot day. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
twinwindows Samba Pimp
Joined: December 08, 2000 Posts: 4086 Location: So.Cal. Highland Park GFK!
Posted: Thu Dec 16, 2004 11:36 pm Post subject: |
I have done this two ways MEDIA and Chemical, As far as the media blasting went is that by doing it like that you will have sand in all the tight places then even after you clean and blow it out your still going to have some media spilling around.
The split I have was done with a high grade Chemical and turned out just fine but if you don`t clean it up rite like Skim said you will have a problem later on. Using a hot steam cleaner with some major power takes care of that.
Blasting? Never again, Just the small parts. _________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed. |
Rome Samba Member
Joined: June 02, 2004 Posts: 10619 Location: Pearl River, NY
Posted: Fri Dec 17, 2004 2:48 pm Post subject: |
There are places that can dip the entire body into a huge vat to get rid of your paint and underlying seam sealers, body filler, etc. I can imagine that if you have the wiring harness still in the car, the dip process would dissolve it!
I hired a professional body repair instructor from work years ago to do some welding on rust patches on my Beetle at my home, and we then discussed various ways for prepping the body for paint. That particular car had been poorly repainted years ago and it's paint was cracking (spiderweb effect). For a "backyard" approach he recommended using aircraft paint stripper, always lathering on the stuff so that the surface never dries. Put sheets of body masking paper on the ground next to the car. You scrape the paint off the surface (plastic spatula) and let it drop onto the paper. Neutralize the stripper with water, then simply wrap up all that paper and discard it "per local regulations".
I have not tried that method (nor any other) so my input is really not qualified. But seems plausible and you can learn more using the "search" function here. A friend had his Ghia coupe stripped using baking soda blasting (mentioned by somebody here already) with very favorable results. |
Skim Rants Master
Posted: Fri Dec 17, 2004 3:12 pm Post subject: |
Unless you redipped the car in a vat of primer like the factory did after it was chemically dipped, you're gonna lose. _________________ GFK
1953 Kabriolet
1954 Sunroof
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Fri Dec 17, 2004 4:54 pm Post subject: |
I used walnut shells on my '53. Nothing was warped.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
El Guero Samba Member
Joined: January 03, 2004 Posts: 1199 Location: I.E. Y-QUE
Posted: Fri Dec 17, 2004 6:35 pm Post subject: |
paint stripping corp in sante fe springs dips em then sprays on red oxide primer via an electrostatic process followed by baking in it in a 350 degree oven my buddy just had them do his notch and it came out real good ready for Smoot body and paint |
Skim Rants Master
Posted: Fri Dec 17, 2004 6:55 pm Post subject: |
A good blaster that has worked with cars will always use a fine soda, walnut shell or plastic media or even a FINE grade sand. he will also know the correct technique on blasting, distance, PSI etc. The reason warpage happens is due to high pressure too close and when you blast something, it should never be head-on. It should always be at an angle that way the hit is never directly on the panel. You want the blasting to graze the body not hit directly. Also, sand blasting gets very hot. For example, If an inexperienced blaster were to sand blast in the dark, the metal will glow red hot where its being hit if the blaster doesnt know what the hell he's doing. _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Fri Dec 17, 2004 7:28 pm Post subject: |
texasbrown54 wrote: |
The problem is always the seams. There's two things to think about:
First, The dip is going to get inside all the seams. It will get them down to bare metal. Now, how are you going to get paint back inside those tiny little closed up seams? If you don't get the paint back in there that's where the rust if going to start (hell, that's where it usually starts even with paint). Like Skim said, the factory dipped in a huge vat, and most of the panels had protection on them before the seams and crimps were even made on the presses. Unless you can dupplicate that you're gonna have troubles.
Problem #2 is that those same seams are gonna fill with the stripper while it's in the tank and even pressure washing is no guarantee that they will rinse out those seams. They pull the body out and dry it in an oven. Well, all that does is change the trapped chemical from a liquid to a solid. Now there's little dry crystals of stripper inside those seams.
Those crystals just sit there quietly while you primer and paint in the nice climate controlled shop. Then, after your car is done you take it out on a humid August afternoon and park it at the mall. The humidity in the air gets to those crystals and turns them back into a liquid. The hot sun heats the liquid and it starts gassing out of the seams. You walk back to your car and notice a 1/16th inch of loose paint right on the edge of the door seam-- that's the stripper back from the dead and messing up your beautiful new paint job.
Not saying it always happens, but I've heard horror stories about top dollar Porsche restorations that had that exact problem. |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Fri Dec 17, 2004 7:45 pm Post subject: |
first, how badly rusted is the car?
dipping is great for parts, and bodyshells with no enclosed, unpaintable surfaces, and unlimited budgets. dipping doesn't do anything other than make a tough job tougher.
don't dip to strip a Vw unless you also plan to dip to paint.
there are no magic bullets. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
Posted: Fri Dec 17, 2004 8:20 pm Post subject: |
bljones wrote: |
there are no magic bullets. |
Too bad Lee Harvy wasn't a painter.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Hiramhaus Samba Member
Posted: Sun May 06, 2007 9:38 pm Post subject: |
I found a place that will soda blast my van (small van) for 450 bucks inside and out with doors and deck lid and hood. He said if I had the extra sheet metal it would be 750 for a standard bus. Advanced Blasting in Cedar Rapids, IA. Although they do not primer it when its done, I have to take care of that myself. I imagine that he will miss some places, but we will see. _________________ 1969 Ghia
2016 Audi Q3 |
vdubinit Samba Member
Joined: July 11, 2005 Posts: 1870 Location: central coast
Posted: Sun May 06, 2007 11:35 pm Post subject: |
Wow almost 3 years later, a post....... thats funny _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
