Back Burner Old Style Baja Bug Turned Daily driver
sovereignsamba
Banned
sovereignsamba is offline
PostPosted: Thu Jun 09, 2011 2:05 pm    Post subject: Back Burner Old Style Baja Bug Turned Daily driver Reply with quote
Over the last 3 years, this baja has slowly been put together using spare parts from other projects, free parts such as the 1973 body & 1967 pan (not ideal), & a donor motor from a glass buggy that awaits a newer bigger motor. The body kit I got in trade, it was made locally here by fiberjet probably in the 70s or 80s? The transaxle, along with the gear boxes & rims was found literally on the side of the road. Assuming it was trashed we picked it up for the deep rims & luckily we were curious enough to look it over & throw it in the car because it works so good for a free gearbox. The car really has been treated like a stepchild untill recently my brother decided to liquidate one of his muscle cars to supply the brakes, wiring, & "accessories". the last 3 years we had welded in new pan halves, I repaired numerous spots on the lower quarters of the body were it was damaged from being dropped 6 feet onto the grass while being moved... Embarassed some free seats went in at some point. Now it's a rolling all metal beast except for the body seal. The rest of the build I'll post pictures of, Soon we will be installing door glass & pulling the front end for some fun modifications.
Cheese grater dash!
this is "the back burner"
does anyone run this style setup in the rear? How do you keep it from hopping? or do you?
Locking collum to go in
Not much inside
Install this shifter w/special locking bolts to discourage thieves
Check back often for updates!
norcalmike
norcalmike is offline
PostPosted: Thu Jun 09, 2011 2:09 pm    Post subject: Reply with quote
Sweet! i love bastard budget Bajas
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Thu Jun 09, 2011 3:02 pm    Post subject: Reply with quote
Nice sheperd, too.
petrol punk
petrol punk is offline
PostPosted: Thu Jun 09, 2011 3:09 pm    Post subject: Reply with quote
Here's a custom made anti-hop setup for an RGB baja. I've heard that a company used to make anti-hop kits back in the day that you might be able to find used.
36hp '56 European DeLuxe oval
'70 bug 1835cc
sovereignsamba
Banned
PostPosted: Thu Jun 09, 2011 3:21 pm    Post subject: Reply with quote
I was wondering what those bars were hanging down there, I figured it was to add strength to the swing plate.
crazyman1
crazyman1 is offline
PostPosted: Thu Jun 09, 2011 8:04 pm    Post subject: Reply with quote
Wish I could find free parts like that Smile
Looking good. Keep up the good work. Very Happy
sovereignsamba
Banned
PostPosted: Thu Dec 08, 2011 11:30 am    Post subject: Reply with quote
Where'd you get those tires? I want some
sovereignsamba
Banned
PostPosted: Wed Feb 01, 2012 7:24 pm    Post subject: Reply with quote
Between several other projects, & moving we finally made some progress.
Wiring done, not too pretty but ready for thrashing Cool
Lights mounted, screwed up & the blinkers are under the scoop!
Next will be tires & front end widening/lifting
Sled plate
Budget Laughing
"new" windshield w/rock chip already in it, recycled rubber Laughing
door needs screws Rolling Eyes
sovereignsamba
Banned
PostPosted: Mon Apr 02, 2012 6:39 pm    Post subject: Reply with quote
reduction box let go of the tube, snapped the weld on the tube, pulled the axle out of the diff, destroyed several teeth & bearings Laughing
dirtkeeper
dirtkeeper is offline
PostPosted: Tue Apr 03, 2012 7:32 am    Post subject: Reply with quote
that sucks. hope you were having some fun when it happened.
sovereignsamba
Banned
PostPosted: Tue Apr 03, 2012 1:02 pm    Post subject: Reply with quote
yeah it was worth the fun Very Happy Trans was popping out of 3rd anyway
sovereignsamba
Banned
PostPosted: Fri Apr 27, 2012 10:49 am    Post subject: Reply with quote
need some reduction box parts if anyone out there is reading
sovereignsamba
Banned
PostPosted: Sun Feb 01, 2015 2:35 pm    Post subject: Reply with quote
Vanapplebomb
Vanapplebomb is offline
PostPosted: Sun Feb 01, 2015 6:51 pm    Post subject: Reply with quote
Nice! Looks like you got a little high centered there. Laughing
1800 Type 4 Berrien 295
Brian
Brian is offline
PostPosted: Sun Feb 01, 2015 11:58 pm    Post subject: Reply with quote
Pretty heavy chevrons
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
sovereignsamba
Banned
PostPosted: Fri Feb 06, 2015 12:14 pm    Post subject: Reply with quote
Nothing a little throttle wont fix
sovereignsamba
Banned
PostPosted: Fri Oct 09, 2015 9:07 pm    Post subject: Reply with quote
sovereignsamba
Banned
PostPosted: Fri Oct 09, 2015 9:25 pm    Post subject: Reply with quote
sovereignsamba
Banned
PostPosted: Fri Oct 09, 2015 9:26 pm    Post subject: Reply with quote
sovereignsamba
Banned
PostPosted: Mon Sep 11, 2017 8:59 am    Post subject: Re: Back Burner Old Style Baja Bug Turned Daily driver Reply with quote
Time to un do the ugly
