gregmerritt_type3 Samba Member
Joined: March 15, 2004 Posts: 35 Location: Berkeley, California
Posted: Mon May 07, 2012 9:01 pm Post subject: throwout bearing too off center? |
Gurus,
I mounted a new throwout bearing in my '63 Beetle (with '71 1600), and it sure looks to be a little bit off-center; see attached photo. Is this a problem?
Note that what motivated me to pop the engine out was funky sounds and feel in the clutch pedal; the center retaining ring of the pressure plate was all ground down and loose. Note that the old t/o bearing, as well as the fork, clips, etc. all looked fine.
Hmmmm...now that I look at the picture, does the left fork look bent toward the center? Argh...
Thanks for any advice!
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Mon May 07, 2012 9:48 pm Post subject: crossshaft |
Yes, It does look a little bent inward. No Big Deal
The weld job could have done it IF there are no marks from the
old T.O.brgn. coming off.
Take the clips back off and lube the Saddles and the mainshaft. _________________ V.W.owner since 1967 |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6131 Location: 37.5N 77.1W
Posted: Tue May 08, 2012 6:34 am Post subject: |
Quote: |
little bit off-center |
The Germans noticed that too and re-designed the TOB with a tube to keep it centered better in later IRS transaxles. Not sure who sells it but there is a modified main shaft seal that retro fits older transaxles with the tube for the newer style TOB. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
NWGhiaGuy  Samba Member
Joined: March 16, 2005 Posts: 703 Location: Bellingham, WA
Posted: Tue May 08, 2012 7:05 am Post subject: |
Are you sure that's an older style throw out bearing? It's been awhile since I looked at one, but shouldn't the early style have a flat surface where it mates with the pressure plate? |
Posted: Tue May 08, 2012 7:52 am Post subject: |
NWGhiaGuy wrote: |
This t/o bearing came with the 200mm '67-'70 clutch kit from cip to match my early trans ('62) with late engine ('71). The t/o bearing I took out did not have the raised center, and was a couple of mm thinner.
I hope this one's right!
-Greg |
Posted: Tue May 08, 2012 10:28 am Post subject: |
gregmerritt_type3 wrote: |
The t/o bearing I took out did not have the raised center, and was a couple of mm thinner. |
Here's a pic comparing them.
Edit: Note that the inner diameter of the new t/o bearing is smaller...
Last edited by gregmerritt_type3 on Tue May 08, 2012 3:55 pm; edited 1 time in total |
Paul Ray Samba Member
Joined: July 11, 2006 Posts: 159 Location: North Carolina
Posted: Tue May 08, 2012 1:23 pm Post subject: |
Not to hijack this thread, but is the center ring/collar of the pressure plate supposed to be loose or fixed in the center of the pressure plate? Also, I have the same situation as you did Greg. But my car ended up loosing 1st and reverse gear. I got the same kit as you and hoping it fixes my problem. |
Posted: Tue May 08, 2012 3:32 pm Post subject: |
Paul Ray wrote: |
...is the center ring/collar of the pressure plate supposed to be loose or fixed in the center of the pressure plate? |
On my new pressure plate, it is most definitely solid and tight!
Here's what my old pressure plate looked like. Most definitely too loose!
Posted: Tue May 08, 2012 3:34 pm Post subject: |
Actually, to follow up on that, note that it's unclear to me what the center ring of my pressure plate was rubbing against. My best guess was that the off-center throwout bearing meant that they would rotate non-concentrically and scuff/rub as they turned, and that the t/o bearing is made of harder stuff than the ring on the pressure plate.
Nothing on the t/o bearing, fork, etc. looks worn... |
Posted: Tue May 08, 2012 4:09 pm Post subject: T O BEARING |
How about some info on Where these parts were purchased?
2 different 200 mm pressure plates
2 different Release bearings
What part #'s do you have?
El Cheapo TO Bearing o,r F&S ?
That is 1 ugly Bearing.
www.airheadparts.com _________________ V.W.owner since 1967 |
Posted: Tue May 08, 2012 4:29 pm Post subject: Re: T O BEARING |
old DKP driver wrote: |
How about some info on Where these parts were purchased? |
Old parts? Unknown, lost to history.
New parts? CIP1 clutch kit: http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-211-140-025-BKIT
Last edited by gregmerritt_type3 on Tue May 08, 2012 4:42 pm; edited 1 time in total |
Posted: Tue May 08, 2012 4:31 pm Post subject: Re: T O BEARING |
That is 1 ugly Bearing. |
BTW what's ugly about the bearing lol...?
The busted parts are the leftovers of the center spring retaining ring of the old pressure plate, btw...  |
Posted: Tue May 08, 2012 4:44 pm Post subject: Re: T O BEARING |
What part #'s do you have? |
Code: |
VWC-111-141-165-AGR - OE QUALITY - EARLY THROW OUT BRG - BEETLE 46-70 / GHIA 56-70 / BUS 50-70 / TYPE 3 62-70
VWC-111-141-177-HD - HEAVY DUTY CLUTCH RELEASE BRG RETAINING SPRING CLIPS - ALL MODELS UP TO 1970 - SOLD EACH
VWC-211-141-025-BJ - PRESSURE PLATE 200MM - (NEW OE QUALITY) BEETLE 67-70 / GHIA 67-70 / BUS 67-70 / TYPE 3 67-70
VWC-311-141-031-BK - 200MM RIGID CLUTCH DISC - BEETLE 67-79 / GHIA 67-74 / BUS 65-71 / TYPE 3 67-74
These are the part numbers from the CIP1 kit. |
Posted: Tue May 08, 2012 4:46 pm Post subject: ugly bearing |
No LOL here! Have you ever Looked at an F&S Release bearing?
Again,....Where are these new parts from?????
did you save the boxes or invoice?
Trying to help you and it's really not a time to Laugh about these
parts.  _________________ V.W.owner since 1967 |
Posted: Tue May 08, 2012 4:52 pm Post subject: Re: ugly bearing |
Again,....Where are these new parts from????? |
I posted above with full part numbers and links to CIP1 kit....... |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Tue May 08, 2012 5:06 pm Post subject: |
_________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4656 Location: Whittier 90602
Posted: Tue May 08, 2012 5:42 pm Post subject: |
In your first pic it does look a little off to the right side. That would have more to do with how the cross shaft itself was welded and it's bushing in the trans rather than bent arms.
With the original TOB and P/P design, a little off won't do any harm because of the large surface area contact of the centering ring and T/O. With the new design, it may be more critical.
The cross shaft is centered by the bushing and the snap ring on the lever. If there is any wear in them, the shaft can shift to one side. If you want to see if you can center it better, you may have to just take it apart and inspect for wear. The bushing is held by a set screw, and can be shifted to one side or the other slightly before tightening.
You might find some other useful info if you want to wade through this long post re: clutches/TOB's...
http://www.thesamba.com/vw/forum/viewtopic.php?t=148307 _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Tue May 08, 2012 5:47 pm Post subject: |
61SNRF wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=148307 |
Super cool -- thanks a ton!!  |
Posted: Tue May 08, 2012 6:03 pm Post subject: |
Greg, my collar is still in the center. But mine can be moved in & out, up, down, left & right. So its not supposed to do that and should be complete unmovable? |
66brm Samba Member
That pic I posted above was the result of a poor quality HD throwout fork that mounted the bearing off centre by 1-2mm with a Kennedy STG1 pressure plate. It lasted approx 6 months of daily driving before destroying itself, the fork has now been replaced with a HD Bugpack unit that centres the bearing correctly _________________ Aust. RHD 66 Type 1
modok wrote: |
