Anyone Use An Adjustable Voltage Regulator?
PDXWesty
PDXWesty is offline
PostPosted: Wed Jun 17, 2009 8:53 pm    Post subject: Anyone Use An Adjustable Voltage Regulator? Reply with quote
Does anyone know where to get an adjustable voltage regulator for the Bosch alternators as mentioned in this post?
http://www.thesamba.com/vw/forum/viewtopic.php?t=267379
If you use one, any problems with it?
Thanks!
89 Westy 2.1 Auto
tikiman71
tikiman71 is offline
PostPosted: Wed Jun 17, 2009 9:27 pm    Post subject: Reply with quote
I believe they can be found here:
http://www.davebarton.com/AdjustableVoltage.html
but I have not bought one or had experience with them yet. Hope this helps!
1987 Westfalia GL
crazyvwvanman
crazyvwvanman is online now
PostPosted: Wed Jun 17, 2009 9:28 pm    Post subject: Re: Bosch Adjustable Voltage Regulator? Reply with quote
They can be found on Ebay for $20 including shipping.
Search for "Bosch VW Voltage Regulator" and one of the ebay stores has them.
Mark
Thanks!
PDXWesty
PDXWesty is offline
PostPosted: Wed Jun 17, 2009 9:53 pm    Post subject: Reply with quote
Thanks. The one from Dave Barton is a remote mounted unit. There is one that mounts on the alternator and has an adjustment screw.
Has anyone ever used one of these or similar units?
89 Westy 2.1 Auto
tikiman71
PostPosted: Wed Jun 17, 2009 10:02 pm    Post subject: Reply with quote
That looks like a good deal. A similar (if not the same) one is further down on the DB site for $32 without shipping. Thanks for the tip!
1987 Westfalia GL
PDXWesty
PDXWesty is offline
PostPosted: Wed Jun 17, 2009 10:05 pm    Post subject: Reply with quote
EDIT
This one lists the correct part number.
http://cgi.ebay.com/ebaymotors/Voltage-Regulator-B...ccessories
89 Westy 2.1 Auto
scottjk
scottjk is offline
PostPosted: Wed Jun 17, 2009 10:26 pm    Post subject: Now I'm Wondering.... Reply with quote
You guys have me wondering about my charging system. I purchased a rebuilt alternator a few years back. Never seems to fully top off my Optima Yellow Top.
Can someone run me through the tests I need to do to check my system? I also would like to figure out if there is a draw on the system with my key off.
Thanks
Scott
tikiman71
PostPosted: Wed Jun 17, 2009 10:26 pm    Post subject: Reply with quote
Both the ebay item and the Dave Barton internal regulator have the Bosch part number 1-197-311-021 listed in their respective gargantuan cross reference parts list. I'm pretty sure either one would work fine...
1987 Westfalia GL
Perales
Perales is offline
PostPosted: Thu Jun 18, 2009 5:27 am    Post subject: Re: Now I'm Wondering.... Reply with quote
Download this file. It is a good multimeter instruction manual and it has a step by step instructions to do the test.
http://www.westfalia.gomez-perales.com/Documents/Actron%20Multimeter.pdf
-- 1987 Westfalia automatic (Captain Vino)
scottjk
scottjk is offline
PostPosted: Thu Jun 18, 2009 5:30 am    Post subject: Link not working Reply with quote
Nvmd, it worked with Firefox for some reason.
Scott
Perales
Perales is offline
PostPosted: Thu Jun 18, 2009 5:43 am    Post subject: Re: Link not working Reply with quote
Scott
I just fixed the link. Sorry, my bad. It works now.
crazyvwvanman
PostPosted: Thu Jun 18, 2009 5:49 am    Post subject: Reply with quote
That should be the case, since the internal one from Dave and the one from Ebay are the same brand in the same boxes. -373A version
Mark
PDXWesty
PDXWesty is offline
PostPosted: Thu Jun 18, 2009 10:33 am    Post subject: Re: Now I'm Wondering.... Reply with quote
Thanks
Scott
Take a look at this. Sounds like the same problem.
http://articles.mbz.org/electric/regulator/
89 Westy 2.1 Auto
PDXWesty
PDXWesty is offline
PostPosted: Tue Jul 14, 2009 3:10 pm    Post subject: Reply with quote
**Update 7-14-09**
I ordered the adjustable voltage regulator from a vendor on Ebay and I installed it this weekend. Everything worked out great. It came set at 14.2 volts output and I adjusted it to 14.5 volts after I installed it. It took five minutes to install. Simply unscrew the old regulator from the back of the alternator put in the new one being careful with the spring loaded brushes. It has a small opening in the back with an adjustment screw.
Now with the engine running and the lights and heater on, I have 14.2 volts at my batteries. This will be enough to keep them topped of for peak performance. I previously had 13.7 volts at the batteries. This would be good for people who have AGM batteries which need a slightly higher charging voltage as mentioned in the previous post. I'll definitely keep this updated if I run into any problems.
Here's the link again.
89 Westy 2.1 Auto
markz2004
markz2004 is offline
PostPosted: Sun Mar 04, 2012 9:57 pm    Post subject: Reply with quote
I recently installed an adjustable regulator as well. I adjusted it to get 14.1 at the battery bank. After a short test run the volts dropped. Presumably because the batteries no longer needed the juice.
What voltage should I target given a full battery? 14.2? If that is the case I should go back and readjust ..
Thanks
Mark
87 Westy, 250k GW 2.4 - 2.0 Wink, 16" wheels
pablovent
pablovent is offline
PostPosted: Sun May 27, 2012 8:15 pm    Post subject: Reply with quote
Thanks
Mark
Hi markz2004, you installed bosch adjustable regulator??....where buy this product??
regards.
gl98115
gl98115 is offline
PostPosted: Mon May 28, 2012 5:27 am    Post subject: Reply with quote
I purchased one last month off Ebay from "DrDepnerDeals". They ship worldwide.
http://www.ebay.com/itm/Voltage-Regulator-for-Bosc...mp;vxp=mtr
'87 faux-Syncro Westy w/ 2.3l GoWesty WBX
pablovent
PostPosted: Mon May 28, 2012 7:25 am    Post subject: Reply with quote
You have type4 bosch alternator installed?
Cygnus
Cygnus is offline
PostPosted: Mon Jun 04, 2012 2:24 pm    Post subject: Reply with quote
Is that last listed one workable - (The Drdepner one)? The earlier ebay links don't work. The last one doesn't list a Bosch part number 1-197-311-021 in their table. Just wondering if anyone can verify compatibility.
Thanks,
-Brian
'86 Syncro Timbertech Hightop "Cygnus"
crazyvwvanman
PostPosted: Mon Jun 04, 2012 2:50 pm    Post subject: Reply with quote
They sell various ones and the fine print shows the differences. For wbx 90 amp alternators I'm pretty sure you need 28mm, with NO resistor.
http://www.ebay.com/itm/Voltage-Regulator-Bosch-Au...35a363b271
Mark
Thanks,
-Brian
