randiego Samba Member
Joined: October 13, 2008 Posts: 75 Location: San Diego
Posted: Sun Jul 15, 2012 2:54 pm Post subject: Trying to identify my stock springs - any help? |
I have a set of springs I pulled out of my '85 tintop - I'm trying to identify them, to make sure I have what I think I have.
I remember seeing a chart somewhere that showed the color codes for each spring for each model (The colored band around one of the coils).
The springs I'm looking at are (theoretically) the tall '85 springs. My '85 was pretty tall - 17.25" at each corner stock.
Front springs: light-brown stripe painted on them
Rear: Sky blue stripe
Anybody know the chart I'm talking about? _________________ '85 GL, 1.9, 4spd (Sold, we'll miss it)
'89 Carat, Bordeaux Red, 4spd 2.1 |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5930 Location: Tsawwassen, BC
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1937 Location: Sidney B.C. Canada
Posted: Sun Jul 15, 2012 6:07 pm Post subject: |
Brickyard info does not show all springs. For example, my '82 diesel westy has 2 white stripes, middle of spring.
The IG16 wiki has a little bi more info, http://www.ig-syncro16.de/wiki/Federn, but even that one is incomplete.
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
Posted: Sun Jul 15, 2012 9:18 pm Post subject: |
Thanks for the responses - the Brickyard link is very helpful.
The chart I remember seeing was very detailed, it went year-by-year. I thought I saved it! I usually bookmark unusual stuff I run across... anyway.
The one in german... I didn't see anything. _________________ '85 GL, 1.9, 4spd (Sold, we'll miss it)
Posted: Sun Jul 15, 2012 10:16 pm Post subject: |
Jake de Villiers wrote: |
But the Brickyard chart DOES have the info the OP is looking for... |
Really? I don't see any mention of a single blue or single brown stripe on either list.
Brickyard does not list any spring measurements or dimensions, the IG16 wiki does. That could be useful for the OP
OP, try IG16 link again,
Posted: Tue Jul 17, 2012 1:13 pm Post subject: |
Okay, that link worked, and that's very similar to the chart I saw, which was in English.
Very solid information. Google Translator is your friend! Many thanks. _________________ '85 GL, 1.9, 4spd (Sold, we'll miss it)
r39o Samba Polizei
Posted: Tue Jul 17, 2012 2:53 pm Post subject: Re: Trying to identify my stock springs - any help? |
randiego wrote: |
The only reference I find for 85 in the ETKA I only find 2 stripes painted the colors above:
For front with brown I only find:
(12) 253411105A
coil spring / F 24-F-110 635>>
/ ambulance JOKER,CARAT
253411105A 952
2 paint marks / use for: / brown paint marks
brown 1,2 /
for rear with blue is:
(1) 255511105C
coil spring
/ 255,256
255511105C 952
2 paint marks / use for: / blue paint marks
blue 1,2 /
(1) 255511105C
coil spring
/ 253,254:
255511105C 952
1,2 blue / M15,M16,M17 ambulance JOKER
NOTE: I looked at other years too and only a few have a single strip and that is yellow. In other words just about all springs in the VW parts catalog show 2 stripes per spring. I recently bought some used Carat springs and they followed what was stated in the ETKA. I do not know what springs you have. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10374 Location: Orbiting San Diego
Posted: Tue Jul 17, 2012 4:15 pm Post subject: Re: Trying to identify my stock springs - any help? |
Let me explain what the ETKA is saying. For spare parts, VW doesn't care to stock ALL the minor variations of springs used in original vehicle production. They stock 1 variation and tell you to use it for whatever fitments it is close enough to. So they make a spare part spring with 2 brown marks and tell you to use it to replace any original spring that had either 1 or 2 brown marks. Same with the blue. Simple enough.
Once upon a time a little bird told me that when you make a batch of springs they all turn out slightly different. So the manufacturer tests them and discards any that are too far off. The rest get sorted into 2 or 3 grades within the allowable range. All are very similar but ideally you don't want to use a spring on the right side that is at one end of the range and a spring on the left side that is at the other end of the range. So you grade the springs within the range into sub-ranges and mark them so that when the new vehicle is assembled the springs are a closer match. 1 paint mark for 1 sub-range, 2 paint marks for the next sub-range,.......
Mark
r39o wrote: |
brown 1,2 /
blue 1,2 /
