Carb floods engine during braking
gitrdun
gitrdun is offline
PostPosted: Sun Jul 15, 2012 7:56 pm    Post subject: Carb floods engine during braking Reply with quote
I have pict 34 on a 1600 (technicly it has over sized jugs to make it 1835cc) that runs great and idles great. I have had it on two seperate engines and had exactly the same problem both times.
Everytime i pull up to a stop sign the engine dies and then i have to hold the throttle wide open to get it to start back up, and it starts hard like its flooded. If i gently slow down nice and easy, slow enough to dang near cause an accident it idles fine and no problems. If i let off the throttle, engage the clutch, wait on the RPM to drop to idle and then stab the brakes reasonably hard it will kill the engine every time. The only way to not kill it is to start gently slowing to a stop like a block before you have to stop.
So i pulled the top off of the carb after a short drive and the fuel level looks about 3/4 to the top of the bowl. That doesnt seem like an over filled carb does it. So what the heck is wrong with my carb?
esde
esde is offline
PostPosted: Sun Jul 15, 2012 8:49 pm    Post subject: Reply with quote
Warped top/ bad gasket allowing fuel to get sucked down the throat when there's a lot of sloshing around?
OLD VW NUT
OLD VW NUT is offline
PostPosted: Sun Jul 15, 2012 10:42 pm    Post subject: Reply with quote
Or a bad needle valve. Maybe the float has a hole in it? Or what esde said.
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
Culito
11010101
Culito is offline
PostPosted: Mon Jul 16, 2012 10:57 am    Post subject: Reply with quote
There isn't much to that system...it has to be too-full float bowl overflowing into the carb throat. Check your needle valve, float, and fuel pressure (you only need 2-3 psi)
Are you sure it isn't a wire somewhere that is swinging forward during braking and shorting out on something?
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
gitrdun
gitrdun is offline
PostPosted: Sat Jul 21, 2012 2:59 pm    Post subject: Reply with quote
So the problem turned out to be the solenoid valve by the throttle linkage. I noticed it wasnt clicking when i removed the power wire so i removed it and discovered the plunger was broken off and not even there. I put another used carb on it and the problem went away.
Now the engine falls on its face when i stab the accelerator even after setting the acc pump to its max setting. I cant win. I have three used carbs now, so i think i can throw enough good parts into one carb to get it running good.
SRP1
SRP1 is offline
PostPosted: Sat Jul 21, 2012 3:19 pm    Post subject: Reply with quote
Let me guess...............009 distributor right? Rolling Eyes
gitrdun
gitrdun is offline
PostPosted: Sat Jul 21, 2012 6:59 pm    Post subject: Reply with quote
Im not a VW guru so i dont know what the distributor is. It has two vacuum lines going to it. I have another distributor which has no vacuum lines. Maybe i should swap distributors and see if it helps. Man what a headache.
