Air cleaner oil level?
onetuza
onetuza is offline
PostPosted: Thu Aug 16, 2012 5:03 am    Post subject: Air cleaner oil level? Reply with quote
Anybody know the proper oil fill level for this air cleaner?
Is it the Lowe level where there is an overhanging flap of metal or that seam line above the slope and just below the intake holes?
Cadaver
Cadaver is offline
PostPosted: Thu Aug 16, 2012 5:16 am    Post subject: Reply with quote
year?
up to the rim lip, see the ring, there that is the anti slosh ring
to there,
click tech tab above then owners manuals. bingo
http://www.thesamba.com/vw/archives/manuals/68bug.php
http://www.thesamba.com/vw/archives/manuals/69bug/page45.jpg
says fill to the line
but where is the line.?
in a 1968 , you off the lid and look inside.
on that inside lower rim is a pressed in ARROW this arrow point to the line.
for sale now.
in Samba classifieds....1968 T1.
onetuza
onetuza is offline
PostPosted: Thu Aug 16, 2012 5:56 am    Post subject: Reply with quote
I'm not sure of the year. I bought it to replace also incorrect single snorkel cleaner on my 71 engine.
Not sure what a "rim lip" is.
The lower part, just above the bottom, looks like this
Forgive my ignorance, but I don't see how looking at owner's manual pages that say "fill to the mark" is helpfull. Been there done that. My point is, where is the friggin "mark".
D/A/N
D/A/N is offline
PostPosted: Thu Aug 16, 2012 6:26 am    Post subject: Reply with quote
The actual '71 oil bath is the one with the OYO thermostat, now unavailable except by luck or used.
Looks like yours is a 68-70 with the cable actuated flaps.
Here's a pic from my '71 oil bath which I think will have the same base dimensions as yours.
You see that dopey looking arrow thing at the top of the pic? I always filled it to the bottom of the arrow and never had a problem.
ROCKOROD71
ROCKOROD71 is offline
PostPosted: Thu Aug 16, 2012 6:30 am    Post subject: Reply with quote
first off, the single snout cleaner is correct for the '71 model year, that is a one year part with a thermostat controlled pre-heat flap (the cleaner will have a big spring thingy on the side) what you have pictured looks to be a double snout cleaner (the picture is awful and blocks all the parts important to identifying its year) from a 67 or 68. I digress however, there should be a lip just above the actual bottom of the air cleaner, you fill up to this lip. on later air cleaners there is an arrow stamped in the metal (an actual indent) to show the fill mark. earlier ones had a red line. sometimes this arrow is pretty hard to notice due to age and or grime.
hope this helps
happy trails
1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote:
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it.
asiab3 wrote:
Careful guys, a petulant child can grow up to be president these days.
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy**
Cadaver
Cadaver is offline
PostPosted: Thu Aug 16, 2012 6:43 am    Post subject: Reply with quote
you did not read my post
i said, see the manual
then see the arrow
the manual shows where to look
then look and see the arrow
if you'd have photo'd the cleaner, 90degrees rotated, we'd be pointing fingers now. Am i right?
if its not there, then it must be some very odd vw air cleaner.
but mine is a 2 snout too , in 68 .
i cant speak (say) for all 2 million 68s Air-cleaners made world wide.
but the USA variant does have the arrow, (needs to be clean to see it)
maybe yours is like a mis-stamped coin, a rare collectors item Rolling Eyes
some cleaners have other stickers on the side, with ways and means ,
stated,
the Bentleys states 66-69 (cant speak for 70+)
there are 4 variants... in first paragraph.
S3-Pg8
the KG cleaner is unique. 4th variant.
66 single snout.
67 2 snouts.
in aug, 67 the 1500 , the engine thermostat operates, the.....xxxxxx
page 9
states FILL IT TO THE MARK.
use 0.95 pints of engine oil. (that is all it state)
for sure ,do not over fill it , or risk oil induction,
for sale now.
