61TXghia Samba Member
Joined: July 17, 2009 Posts: 950 Location: El Paso, TX
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Wed Apr 04, 2012 11:20 pm Post subject: |
Great transformation of that bus! Can't wait to see more. Extra cool that your kids are into it... |
skaw Samba Member
Joined: February 05, 2010 Posts: 475 Location: VACAVILLE
Posted: Sat May 05, 2012 12:59 am Post subject: |
im loving your progress, and wow we have the same look, I too have cut wheel wells and I chose the gray primer and white top! looks good! congrats  _________________ SKAW= SEEK KNOWLEDGE AND WISDOM |
Posted: Sat May 05, 2012 10:30 am Post subject: |
skaw wrote: |
im loving your progress, and wow we have the same look, I too have cut wheel wells and I chose the gray primer and white top! looks good! congrats  |
Thanks SKAW, we have a blast in this bus. _________________ 62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
bill may wrote: |
Camping is cheaper than therapy. |
Split62 Samba Member
Posted: Sat May 05, 2012 10:39 am Post subject: |
durfeec wrote: |
61TXghia wrote: |
I think that the best part is that the PO already cut the rear fenders so I can put some monster mudders on it!! YEEEEEEHAWWWW!! So, has anyone fixed rear tire fenders that have been cut? Once I confirm the year, I will order the correct panels for repair. Thanks for all your help. |
yes. its fairly common for the rear tire repair. hit up Gerson. he'll get you what you need. and there is no better metal than his for patch panels. |
Any contact info for Gerson? I need to fix my rear tire fenders too... _________________ NOOB |
skaw Samba Member
Posted: Sat May 05, 2012 11:09 am Post subject: |
congrats on the bus split 62!! I am in Vacaville if you need any help , I believe gerson can be found at Klassic fab. _________________ SKAW= SEEK KNOWLEDGE AND WISDOM |
Posted: Thu Jun 07, 2012 9:31 pm Post subject: |
Here is an update. My motor spun a crank bearing and the material clogged one of the oil passages on the crank going to piston 1. I took block completely apart with step by step instructions from the "Bug Me Video". I took the block and had it machined, crank, and rods also. I then started the step by step process of rebuilding it. I also replaced the two relief valves. During the process, I dropped one of my pistons and put a dent in the edge, luckily a buddy had an extra piston that he gave to me. So rings and all bearings are new now. Everything came together rather easy. Once motor was installed, it would not start. Even though I didn't remove the distributor gear, I now have to put my distributor 180 off. The motor runs perfectly and I have already adjusted the valves and changed the oil after 25 miles. So far so good, does not heat up and has excellent power. Just need to get my distributor gear flipped and it will be good. _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
ccb_dan Samba Member
Joined: August 03, 2009 Posts: 321 Location: Cocoa Beach, FL
Posted: Fri Jun 08, 2012 3:54 am Post subject: |
That's pretty rad that you disassembled and reassembled the motor by watching an instructional video! Too cool! |
Posted: Fri Jun 08, 2012 10:00 am Post subject: |
ccb_dan wrote: |
I know, right. Felt like I was painting by numbers. LOL. Hopefully I did everything right and the motor holds up. _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
thecrewcrew Samba Member
Joined: November 28, 2004 Posts: 93 Location: Acworth, GA
Posted: Fri Jun 08, 2012 11:34 am Post subject: |
did you get the middle seat with it? _________________ |o\#/o|
Eric Knight
'68 Camper Tin Roof
'68 Highroof (Vandito Burrito)
'71 Single Cab
'73 Bus (The Wagen Bar)
'65 Panel Brazilian |
Posted: Fri Jun 08, 2012 2:15 pm Post subject: |
thecrewcrew wrote: |
did you get the middle seat with it? |
No middle seat. I have a table instead but wouldn't mind finding a middle seat. _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
kitcarson Samba Member
Joined: April 14, 2010 Posts: 56 Location: Eastern Idaho
Posted: Sat Jun 09, 2012 2:23 am Post subject: |
i have really enjoyed reading this thread. I just bought a 65 and it was in way better shape then yours. And seeing what you have done gives me some encouragement. You have done great. And everyone in your family enjoys the bus. My whole family went when I rescued mine too. It gives them some investment in it. Great job...... |
Posted: Sat Jun 09, 2012 11:51 am Post subject: |
kitcarson wrote: |
Thanks Kit, it is a blast to work on and your right, my kids love it. We had a get together last night and our club was happy to see the bus back on the road. Do you have pics of your rescue? _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
Posted: Sun Jun 10, 2012 10:17 pm Post subject: |
Went for a cruise today and noticed a weird sound coming from rear wheel. Took hubcap off and noticed a lug nut had come off. I guess the tire shop that mounted my tires stripped a lug nut and didn't tell me. I am looking to replace that rear drum now, but in the meantime, should I worry about driving with a missing lug nut on the left rear tire? _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15247 Location: Casa de Oro, California
Posted: Mon Jun 11, 2012 6:36 pm Post subject: |
61TXghia wrote: |
Went for a cruise today and noticed a weird sound coming from rear wheel. Took hubcap off and noticed a lug nut had come off. I guess the tire shop that mounted my tires stripped a lug nut and didn't tell me. I am looking to replace that rear drum now, but in the meantime, should I worry about driving with a missing lug nut on the left rear tire? |
You'll probably be ok for standard cruising. |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1663 Location: In Your Face...
Posted: Sun Aug 19, 2012 11:43 pm Post subject: |
61TXghia wrote: |
ccb_dan wrote: |
I know, right. Felt like I was painting by numbers. LOL. Hopefully I did everything right and the motor holds up. |
Any further updates 61TX?
I am impressed with your 'mechanical aptitude', especially since you've split the case and then reassembled the whole sha'bang. AND it runs too?!?! Good on ya, bro....  _________________
Lind wrote: |
Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
Posted: Sun Mar 01, 2015 6:42 pm Post subject: |
I have not been on here in a while, my bus has gone through some changes, I got rid of RGB's and went solid axle. Flipped the spindles in the front and now the bus is really low. I really enjoy driving it and I am assembling all the pics and a write up. _________________ 62 Standard Type 2 (Nothing Fancy)
bill may wrote: |
Z Samba Member
Posted: Sun Mar 01, 2015 8:27 pm Post subject: |
mmmmmmmmmm...der Wienerschnitzel
Bus looks good! |
