Beetle Air Cleaners - picture reference thread
GüteAndTite
Early Convertible Güru
GüteAndTite is offline
PostPosted: Sat Jan 28, 2012 6:14 pm    Post subject: Reply with quote
THANKS GUYS! keep the pics and info coming, Im getting this filled in the first post as you add pics and info. starting to fill up. will be nice to have this stickied for future reference
Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse"
Agave58
Agave58 is offline
PostPosted: Sat Jan 28, 2012 8:03 pm    Post subject: Reply with quote
Hey Brett, Did you find out if the KNECHT's have a date code like the Mann's.. Think
1958 Agave Beetle (0\_!_/0)
Stateside Motors Inc
501 Foote Ave
Jamestown, New York 14701
Stateside Imported Cars/Motors Items Wanted
Sunland Motors
2030 Fremont St Las Vegas, Nevada
Sunland Motors Items Wanted
Zarzamora
Zarzamora is offline
PostPosted: Sat Jan 28, 2012 10:06 pm    Post subject: Reply with quote
Nothing for a 61?? Wink
Only one life, it will soon be past, only what's done for Christ will last.
58Dub
58Dub is offline
PostPosted: Sun Jan 29, 2012 2:28 am    Post subject: Reply with quote
I can take a look later today on mine....where is it usually?
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
Agave58
Agave58 is offline
PostPosted: Sun Jan 29, 2012 9:12 am    Post subject: Reply with quote
on the Mann's it is on the bottom towards the back.
501 Foote Ave
Sunland Motors
stale air
stale air is offline
PostPosted: Sun Jan 29, 2012 10:54 am    Post subject: Reply with quote
I just went and checked out my extra KNECHT that I have,and can't find a date on it anywhere. I even took a scotch brite to the underside where the MANN is dated, and got nothing.
58Dub
58Dub is offline
PostPosted: Sun Jan 29, 2012 11:01 am    Post subject: Reply with quote
wayne1230cars wrote:
This is the Mann air cleaner on my 1960 bug with a build date of Feb.23, 1960. The photo does not show the part # very well but I used some chalk to be sure and the number is 113 129 611A. I did find the date stamp on the bottom and it is 01/60. The car is very original so this may well be the original air cleaner. The May 1960 parts list that I looked at does agree with that part number.
and I believe my 60 was built in Jan. I don't see a date on my KNECHT though
Agave58
Agave58 is offline
PostPosted: Sun Jan 29, 2012 12:26 pm    Post subject: Reply with quote
So I guess the Knechts don't have any date stamps? Hey Aaron did you get a chance to look the filter on your 58?
501 Foote Ave
Sunland Motors
Harris
Harris is offline
PostPosted: Sun Jan 29, 2012 1:00 pm    Post subject: Beetle Air Cleaners Reply with quote
1962 with breather hose to top side.
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Feb 02, 2012 7:20 pm    Post subject: Reply with quote
Found the VW part number for the mushroom air cleaner in the 1945 parts manual.
1 29 401
In Stereo, Where Available!
61SNRF
61SNRF is offline
PostPosted: Tue May 01, 2012 5:18 pm    Post subject: Reply with quote
Here is an original EMPI air cleaner accessory to replace the stock oil bath top half on '67-'73 1/2 Beetles.
With this top half you also got a replaceable and more modern gauze type filter element...
-Bruce
An ounce of prevention is worth a pound of cure.
65'1300Deluxe
65'1300Deluxe is offline
PostPosted: Mon Jul 09, 2012 5:42 pm    Post subject: Reply with quote
1972 Super Beetle 1600 Dual Port air cleaner with vacuum fittings for thermostatically controlled valve for pre-heat tube flap diaphragm. Also has the driver's side connection for fuel vapor system connecting to charcoal canister under passenger side fender. Connection on passenger's side of fan-housing also goes to charcoal canister.
1965 Deluxe Beetle "Camilla"
1972 Super Beetle Barnfind "Roland"
2001 GTI 1.8L Turbo
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Mon Aug 20, 2012 8:52 pm    Post subject: Re: Beetle Air Cleaners - picture reference thread Reply with quote
These are both mentioned as 1962. I've read other places that one is early model year 1962 (August 1961 - March 1962ish) and the other is later 1962 model year (April 1962ish - July 1962ish)?
Early
OR
Late
Does this sound correct? Does the later one go into the 1963 model year?
janerick3
janerick3 is offline
PostPosted: Mon Aug 20, 2012 9:40 pm    Post subject: Reply with quote
The top air cleaner has the decal for a Zenith-equipped 356 with a replaceable paper "Micro-star" filter element...
Thanks,
Jan K.
Helfen
Helfen is offline
PostPosted: Tue Aug 21, 2012 1:29 am    Post subject: Reply with quote
GüteAndTite wrote:
Helfen wrote:
This is the original matching # engine for my 65, 111, 1200A (standard)
Note; there is no crankcase devise or tube to the air cleaner.
https://www.thesamba.com/vw/gallery/pix/516081.jpg
D.
i hate to say it but thats an earlier cleaner. is your car from australia or canada?
No, it's a Jan. 1965 production European Type 111 "A" Sedan--former standard designation that uses the last year a 36 hp engine was used in a beetle. It also uses for the last time a 28 PIC manual choke.
If it were a 1965 Canadian Type 111, 1200 Custom it would have the 36 hp engine with a 28 PCI manual choke carburetor, but would use the same air cleaner with the long snout for the pre heat on the left side and the crankcase hose on the right that all 40 hp engines use.
On some European models a crankcase devise was not required until 1967.
marklee
marklee is offline
PostPosted: Tue Aug 21, 2012 2:11 pm    Post subject: Reply with quote
Quick question air filter gurus....will a 69 air filter have any clearance issues with the deck lid on a 66 Beetle?
thanks,
Mark
CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Tue Aug 21, 2012 2:13 pm    Post subject: Re: Beetle Air Cleaners - picture reference thread Reply with quote
Early
OR
Late
Does anyone know how long the smaller hose that runs from the snout to the oil filler for the early 62 air cleaner is?
Helfen
Helfen is offline
PostPosted: Tue Aug 21, 2012 3:03 pm    Post subject: Re: Beetle Air Cleaners - picture reference thread Reply with quote
nlorntson wrote:
Early
OR
Late
No, but the long hose version is more efficient for getting crankcase vapors out of the engine crankcase.
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Tue Aug 21, 2012 3:19 pm    Post subject: Re: Beetle Air Cleaners - picture reference thread Reply with quote
nlorntson wrote:
Early
OR
Late
OK, referenced Progressive Refinements. The hose did indeed change location from the intake to the reservoir, February 20, 1962 chassis 905991 and engine # 6519664 for the type 1 and about the same time for the Ghia.
Now that's settled.
Eric&Barb
PostPosted: Tue Aug 21, 2012 7:02 pm    Post subject: Reply with quote
Only if you want to close the engine lid!
Get a 1966 air cleaner or the 1966 style air cleaner with the post 1967 preheat tube as seen on page one for the post-1968 engines in pre-1967 Beetles.
Page 2 of 9
