Hard Start Relay Help
Swellchaser
Swellchaser is offline
PostPosted: Mon Aug 27, 2012 2:38 pm    Post subject: Hard Start Relay Help Reply with quote
I purchased the Hard Start Relay Kit from CIP1 and I am a bit confused with the install. http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-17-2917
The instructions says "Choose a mounting point for the relay close to starter and mount the relay..."
The length of wire on the kit is only about 1 foot, but the starter location is towards the rear of the vehicle. Am I supposed to extend all the wires? The rest of the connections are at the batter terminal
The "hard start" kit is also for "hot starts" correct?
Ahwahnee
Ahwahnee is offline
PostPosted: Mon Aug 27, 2012 3:07 pm    Post subject: Reply with quote
Here's where I mounted mine on an 84 (that thing with a 'B' on it):
I did not use that kit so can't comment specifically, but you may well need longer wires than were provided.
chimivee
chimivee is offline
PostPosted: Mon Aug 27, 2012 3:16 pm    Post subject: Reply with quote
Mount in the engine bay. No need to extend wires - connect to the battery by attaching to the big terminal (#30 I think) on the starter.
-James
86 Syncro Westy, etc
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
Swellchaser
PostPosted: Mon Aug 27, 2012 3:23 pm    Post subject: Reply with quote
Thanks,
My starter/solenoid is located underneath the van, aligned with the rear wheels. It's looking like I will have to mount it in that area.
Is there any difference between "hard start" and "Hot Start" relay?
Timwhy
Timwhy is offline
PostPosted: Mon Aug 27, 2012 3:33 pm    Post subject: Reply with quote
Swellchaser wrote:
Thanks,
No you shouldn't have to!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
Ahwahnee
Ahwahnee is offline
PostPosted: Mon Aug 27, 2012 4:22 pm    Post subject: Reply with quote
You don't say what vehicle this is for, but on the Vanagon the starter is located mere inches from that spot I show in the photo. Move your eyes to the left a bit (looking at the front of the engine bay) and you're looking at the solenoid.
S = Starter Solenoid / R = Relay
Same difference.
Swellchaser
PostPosted: Mon Aug 27, 2012 4:24 pm    Post subject: Reply with quote
To access mine I have to go under the vehicle. 1980 Westfalia
peaceful warrior
peaceful warrior is offline
PostPosted: Mon Aug 27, 2012 4:26 pm    Post subject: Reply with quote
I mounted mine on the side of the engine bay, just to the right of where Ahwahnee mounted his, just in front of the air cleaner box.....lot's of room and easy wiring from there.
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
thatvwbusguy
thatvwbusguy is offline
PostPosted: Mon Aug 27, 2012 10:07 pm    Post subject: Reply with quote
The original hard start relay is the Bosch WR1. The wires on the WR1 or any other normal VW hard start relay should be at least 20"-24". Are you sure they sent you the right part? If you can post a photo of your relay I can confirm what you have and help you through the rest of the install.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
Swellchaser
PostPosted: Tue Aug 28, 2012 7:57 am    Post subject: Reply with quote
This is the exact product I received/purchased
It appears to be a universal relay. The wires are 15inchs long
1980 Westfalia
thatvwbusguy
PostPosted: Tue Aug 28, 2012 8:17 am    Post subject: Reply with quote
That is definitely a universal relay pigtail, but it should still work. See if you can find a place on the forward wall of the engine bay that will allow the wires to reach the starter. There are some photos of the connections on my website here:
https://sites.google.com/site/vanagonheadlightrela...all-photos
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
Swellchaser
PostPosted: Tue Aug 28, 2012 8:27 am    Post subject: Reply with quote
That's funny, I was JUST looking at your site. Very nice! I Should of bought your relay instead. The one I have is all plastic (even the mounting bracket) and the wires don't seem to be that thick at all.
Thanks
1980 Westfalia
randywebb
randywebb is offline
PostPosted: Tue Aug 28, 2012 10:54 am    Post subject: Reply with quote
related question: do only the early Vans have hot start problems needing a relay, or do the 1986-later ones have the same problem?
1986 2.1L Westy 2wd Auto Trans.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Aug 28, 2012 11:17 am    Post subject: Reply with quote
Just the vans with the ignition switch up front and the engine/tranny/starter in the rear have such a propensity to benefit from the relay kits.
Mark
peaceful warrior
PostPosted: Tue Aug 28, 2012 11:32 am    Post subject: Reply with quote
Mark
Laughing Laughing too funny! That only leaves out the EV. Wink
TOOB Member #15
Brian
randywebb
PostPosted: Wed Aug 29, 2012 3:02 pm    Post subject: Reply with quote
what causes the hot start problem?
does the cable heat up, changing the resistivity, or what?
Swellchaser
PostPosted: Thu Aug 30, 2012 12:24 am    Post subject: Reply with quote
Installed mine today. Didn't need to extend the wires. Mounted it in the engine bay and ran everything to the starter. Now ready for a long warm ride to test it out Smile
1980 Westfalia
GarththeVan
GarththeVan is offline
PostPosted: Sun Mar 05, 2017 7:36 pm    Post subject: Re: Hard Start Relay Help Reply with quote
Any chance a start relay kit would ensure my Van starts every time? I'm planning on my 85 Vanagon being a daily driver and would like to not get stranded in the city or in the middle of nowhere. On a few posts I've seen people mentioning installing one of these as a list of priorities when getting a Vanagon. My Van doesnt start intermittently and sometimes wont start if it dies after it stalls at idle. Haven't found conclusive evidence that these kits will help. Only seen them used for hot start issues. Could anyone provide me some info? Thanks!
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Mar 05, 2017 8:00 pm    Post subject: Re: Hard Start Relay Help Reply with quote
No.
There are many things that can prevent an engine from cranking - dirty connections, weak or dead battery, faulty ignition switch, loose connections, faulty solenoid, failed starter, etc -- the relay does nothing for all of those.
Its function is to greatly shorten the current path and the commensurate voltage drop that occurs with the stock wiring. A situation that usually shows up as difficulty getting the starter to crank when it is very hot. Typically this is more than just a hot engine - I would experience it after a brief stop following a hot drive as the starter (really the solenoid) got heat-soaked from the engine.
All that is just cranking - you ask about starting and the list of things that can prevent that is long enough to make you marvel anything ever works.
