36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Thu Aug 09, 2012 8:50 am Post subject: |
Gonna be fun to see both of these engines run Ronnie. See you in a month........
Burly |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Thu Aug 09, 2012 10:02 am Post subject: |
| splitpile wrote: |
I also built a new beam for the bus to get the front down a couple inches as I am running going to try smaller rear tires instead of regearing the existing trans.
Ronnie, why not just change out the gearbox for one that has the right gears? It's not that big of a chore (with your straight axle setup) and most transmission shops will put together any R/P and gear stack you want......just saying since you'll have the engine out anyway. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5928 Location: back to living where hell meets the suface
Posted: Thu Aug 09, 2012 10:47 am Post subject: |
| Mr. Motorhead wrote: |
| splitpile wrote: |
Ronnie, why not just change out the gearbox for one that has the right gears? It's not that big of a chore (with your straight axle setup) and most transmission shops will put together any R/P and gear stack you want......just saying since you'll have the engine out anyway. |
Time. Rancho offered to build me a trans geared to the engine. I believe the gear stack is good in the trans I have just didn't have the power to pull it, now with twice the HP and torque it might work (at least on paper). The purpose of the smaller tires is to just lower the ratio a little to pull a little higher rpm's in each gear. I need to maintain 6000 to 6500 rpms in each gear. Plus if the new kombo works and I accomplish what I have set in my mind for the 36hp class I can then put the taller tires back on and put a big block in it to try for the 130 club!!!  _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Thu Aug 09, 2012 1:08 pm Post subject: |
Multi class racing is not a big problem when you have a few days to do the tuning and swaps, which is one of the fun things about running at Bonneville.
Good luck Ronnie..................
Burly |
Posted: Tue Aug 28, 2012 10:46 pm Post subject: |
Picked up my Engine from Geoff Hart (no more dyno time) and getting ready to install it in the bus.
PREP your VW for the salt, 1 lug nut rusted on, shift rod coupler rusted and a lot of PB blaster to get things apart and I pressured washed it for hours after last years adventure.
Got a few different sizes of tires for the rear to see which works the best.
Got the new steering wheel adapter test fit and need to machine the center of the steering wheel to fit over it.
Once I get the beam ib the Blavk Mamba shifter from Vintage speed Taiwan will go in
Hopefully a test drive this weekend and load on the trailer. _________________ Stocking distributor of "The Funky Green Panels"
TomSimon Samba Member
Posted: Wed Aug 29, 2012 9:08 am Post subject: |
Very cool, Ronnie!
What all are you bringing out this year? The Bus, I know. Is the supercharged Vee going to make an appearance? |
Posted: Wed Aug 29, 2012 9:15 am Post subject: |
| Tom Simon wrote: |
Very cool, Ronnie!
The VEE isn't making it. I am still working on the engine, a ton of r/d has gone into it and I still have a ton on machining to do on the intake system..
The SC is coming with me with the 124 hp 36 hp in it and I'm going to try and get last years engine upgraded, but running out of time. Work and fun just don't seem to mesh _________________ Stocking distributor of "The Funky Green Panels"
Posted: Wed Aug 29, 2012 11:57 am Post subject: |
Matthew, if you think work and fun are the same thing, confused does not begin to describe your condition!
But now that I think about it, I completely understand your statement.............
Burly |
slalombuggy Samba Member
Posted: Wed Aug 29, 2012 2:33 pm Post subject: |
| splitpile wrote: |
| Work and fun just don't seem to mesh |
Wait....I'm confused.... I thought work and fun are the same thing!?  |
If you do what you love for a living it's always fun, I'm having a blast!!! OOPs, time for my meds
brad |
Roadcow Samba Member
Joined: November 14, 2003 Posts: 1012 Location: Stockton, Ca. area
Posted: Wed Aug 29, 2012 2:59 pm Post subject: |
I'll have some of what he's taking!  _________________ 71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Wed Aug 29, 2012 3:03 pm Post subject: |
by the looks of your last pic, you've had enough  _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
Posted: Wed Aug 29, 2012 3:34 pm Post subject: |
Ditto !
Hope you are feeling better today Britt!
Burly |
Posted: Wed Aug 29, 2012 5:09 pm Post subject: |
I love working on VW's everyday, but when they cut into MY FUN, well you know. But I need to work on others VW's in order to pay for MY FUN, it's a give give situation _________________ Stocking distributor of "The Funky Green Panels"
Posted: Mon Sep 24, 2012 10:41 pm Post subject: |
Went 86.663 mph with the 1582 IDA engine, some gear changes for next year and a cam upgrade will hopefully push me to 100mph in a bus with a 36hp based engine _________________ Stocking distributor of "The Funky Green Panels"
Beetspeed Samba Member
Joined: July 30, 2004 Posts: 434 Location: The Netherlands
Posted: Tue Sep 25, 2012 11:42 am Post subject: |
| splitpile wrote: |
| Went 86.663 mph with the 1582 IDA engine, some gear changes for next year and a cam upgrade will hopefully push me to 100mph in a bus with a 36hp based engine |
100 mph = over 160 km/h in an old bus with a 36hp based engine. Now that would be something! _________________ '75 SB 1303 2,4ltr T4 turbo: 10.58 @ 129.9mph
'65 Ruska buggy 1192cc EFI 90hp N/A |
