onetuza Samba Member
Joined: June 20, 2012 Posts: 579 Location: Sebastian, FL
Posted: Wed Aug 29, 2012 3:35 pm Post subject: Washer bottle? |
What holds the washer bottle in place? I'd like to take it out and clean it, but I don't want to break anything.
_________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car! |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Wed Aug 29, 2012 3:47 pm Post subject: |
It is just a press in fit, should pop right out with a little persuasion. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked  |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26533 Location: Douglas, WY
Posted: Wed Aug 29, 2012 3:50 pm Post subject: |
there are 3 'nubs' part of the plastic of the tank that click into matching holes in the body. Sometimes you can pop them out, other times they are really locked in there and it can help to crawl underneath and press up on the two you can see from below... and maybe have someone help it out from above.
an old thread about this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=320644&
Posted: Wed Aug 29, 2012 4:36 pm Post subject: |
Got it. Thanks guys. Now I need to fill it and need to see if the hose is clear. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Aug 30, 2012 7:59 am Post subject: |
Be REALLY careful trying to get it out! If you pull or pry the little nubs will crack and you then hav a leaky bottle.
It's best to push the nubs from the bottom. _________________ Mother Nature is a Mean Evil Bitch! |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Thu Aug 30, 2012 10:39 am Post subject: |
If you plan to fill it up with windshield washer fluid, be forewarned that if you use the washer and then let the fluid sit on original paint for more than a day or two it will start to eat through the paint. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
manydubs Samba Member
Joined: November 08, 2007 Posts: 155 Location: Kentucky
Posted: Thu Aug 30, 2012 1:04 pm Post subject: |
79SuperVert wrote: |
If you plan to fill it up with windshield washer fluid, be forewarned that if you use the washer and then let the fluid sit on original paint for more than a day or two it will start to eat through the paint. |
I recommend just using distilled water, much cheaper too! |
Posted: Fri Aug 31, 2012 9:52 am Post subject: |
Cr@p! Ok, tested it out and I have one small problem and one big problem. The small one, the valve leaks. The big one, the squirter runs without pushing the button. Ran all over the place till i noticed it. I guess this means I need a new wiper switch? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
thomas. Samba Member
Joined: July 31, 2010 Posts: 1364 Location: South West (Pa.)
Posted: Fri Aug 31, 2012 1:06 pm Post subject: |
Same thing happend to me. Fixed it with a new switch.Suprising how long that 35 lbs. of air lasts .I filled it at least 3 months ago and its still working. |
Posted: Fri Aug 31, 2012 2:27 pm Post subject: |
The valve - you can buy them at FLAPS, along with a removal tool. I've changed those out before on the washer bottle.
The wiper switch, not unusual for it to go bad - the rubber seals in there can't be expected to last forever. some recent talk about replacement wiper switches-
http://www.thesamba.com/vw/forum/viewtopic.php?t=521123& |
Keith Samba Member
Joined: August 15, 2005 Posts: 3632 Location: Brodheadsville, PA
Posted: Fri Aug 31, 2012 2:50 pm Post subject: |
glutamodo wrote: |
My valve leaked too, so I grabbed a good one out of avalve stem, still leaked, grabbed another, still leaked, it was the valve stem that was causing the leak. Had to replace it with one I had in a cracked bottle, its press fit in. Now it doesnt leak and holds pressure, unfortunately my switch doesnt release pressure when I push the button so the next step is to hook up another switch and a washer nozzle outside the car and test, if all is good I will hook it all up to the car. I suggest to everybody that is testing the washer system to use water first incase it leaks. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Fri Aug 31, 2012 3:00 pm Post subject: |
also, make sure you hook up the hoses to the correctly, there is an in and out. The outer one (B) is to the tank and inner one (D) delivers to the nozzle.
Posted: Fri Aug 31, 2012 7:17 pm Post subject: |
So, the 2 speed switch works fine but I need to replace the whole thing to get the washer to work? (German engineering my @ss) and is it just me who feels like I'm in the Twight Zone looking at that thing? Should be a simple two speed switch, yet it looks like some major piece of equipment with so many freekin electrical hookups sticking out of it.
Also I guess you reuse the knob and plunger? How do you get them off? Do they unscrew? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Keith Samba Member
Posted: Fri Aug 31, 2012 11:41 pm Post subject: |
onetuza wrote: |
Also I guess you reuse the knob and plunger? How do you get them off? Do they unscrew? |
Just pull the plunger out and unscrew the knob. _________________ Formerly known in the forums as "OVALTEEN"
Keith Samba Member
Posted: Fri Aug 31, 2012 11:46 pm Post subject: |
manydubs wrote: |
That would be great..............if distilled water didnt freeze and it will. _________________ Formerly known in the forums as "OVALTEEN"
Posted: Sat Sep 01, 2012 8:19 pm Post subject: |
beryl green'62bug wrote: |
How is the switch removed? My guess is it's released from the dashboard side by removing the knob and unscrewing that silver disk. I don't know if the knob pulls off like a radio knob or unscrews? I tried both gently with no luck. I don't want to break something since the switch doesn't come with a new knob/push button. Anybody know? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Posted: Sun Sep 02, 2012 1:12 pm Post subject: |
The knob unscrews and like you said the silver disk unscrews also.It can be a job to unscrew the disk though without the special tool. But I have always had pretty good luck with it .I used a homemade tool .Just a U-shaped piece of heavy gauged wire. You might need another person to hold on the switch while putting it back together. |
GB2S Samba Member
Posted: Sun Sep 02, 2012 1:22 pm Post subject: |
House of Ghia sells the tool, about $30.00. I rather pay that then be reminded of the scratches everytime I looked at it.
Geoff _________________ 1963 Ragtop |
Keith Samba Member
Posted: Sun Sep 02, 2012 8:41 pm Post subject: |
onetuza wrote: |
How is the switch removed? My guess is it's released from the dashboard side by removing the knob and unscrewing that silver disk. I don't know if the knob pulls off like a radio knob or unscrews? I tried both gently with no luck. I don't want to break something since the switch doesn't come with a new knob/push button. Anybody know? |
I answered your question 2 posts above this question. _________________ Formerly known in the forums as "OVALTEEN"
Posted: Tue Sep 04, 2012 6:06 am Post subject: |
What about the hose, does it just press on to the switch fittings or do you need to clamp it in some way?
Also, I need a short length of hose. Is any available or do you just get something at Home Despot?
Thanks _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
