How To Install a Cold Draft Beer (and keep the water) System
Page: 1, 2, 3, 4  Next
BellePlaine
BellePlaine is offline
PostPosted: Sun Sep 02, 2012 1:06 pm    Post subject: How To Install a Cold Draft Beer (and keep the water) System Reply with quote
If the pix die.
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
I’m to the point now with my 1975 Riviera with a late (1976) Westfalia interior that I’m ready to dream up projects that are not of the utmost urgency to the drivability of the vehicle. Of course, there are always systems to be maintained, but I’m ready to have some real modification fun. This summer I tackled such a project and installed a homebrewed beer draft system. It’s the perfect marriage of my two favorite hobbies: Volkswagens and brewing homebrew.
Given that this is a family vacation get-away vehicle and I didn’t really want to have to explain myself to non-approving critics, it was a major goal of mine to make the draft system as inconspicuous as possible.
In fact here it is:
I can serve both water and cold homebrewed beer out of the stock Westy sink faucet.
It’s done by using a 3-way ball valve at the faucet so if the handle is turned CCW, beer will flow. If the handle is turned CW, water flows. There is one fairly short common line going from the ball valve to the faucet and it just takes a second to clear.
See; that’s an Imperial Stout brewed with cold-press coffee and cocoa chocolate nibs:
I’ve widened the spare tire cabinet by a couple of inches which allowed me to fit two 5-gallon stainless steel Cornelius kegs. These “Corny” kegs used to be used by the soda industry but homebrewers have adopted them as the vessel of choice for kegging purposes. One of the two kegs is for water and the other is for homebrew. I’ve removed the stock 7-gallon water tank.
A beverage tube, or line, goes from the water keg directly to the 3-way ball valve/faucet. Another beverage line, which I’ve insulated, goes from the beer keg and runs along behind the sink cabinet and then into the icebox. In the icebox it runs through 50-feet of stainless steel coil which is cold from ice and then through an insulated line to the 3-way ball valve/faucet.
The liquid is pushed pneumatically, that is to say via pressure. I’ve installed a keg pump which fits just perfectly through the hole where the water-fill tube used to be in the original water system. The keg pump provides air to the water tank, and to a gas distributor which I’ve reversed to allow air or CO2 to push the beer. Beer prefers and inert gas such as C02 otherwise it gets stale quickly. The C02 comes from a hand-held dispenser with a fitting attached to a gas line. It uses those small BB-gun cartages. So I’ve engineered the beer keg to get either CO2 or air in case I use all of the CO2 cartages while camping but might still have time and beer to kill.
Here is what it looks like inside:
Underneath the sink, the 3-way ball valve:
Above the sink, the handle and faucet:
The spare tire cabinet/keg disconnects:
The icebox/stainless steel coil.
The water/beer keg air pump, and yes, that IS a Bay Window shifter knob:
The beer CO2 dispenser:
The beer CO2/Air distributor:
The system is great and discreet but wasn’t perfect. Getting a beer meant opening the slider door each time and disturbing my sleeping children. So I had a stainless steel box fabricated to fit nicely in the sink drain vent hole on the outside of the bus. Inside that box I had Corny keg threads welded so I could attach beer-out and CO2-in fittings which allows me to snap on a beer tapper and gas.
Here are some pics of the box:
The schematic on the whole system:
Most of the stuff needed for this modification can be bought at your well-stocked homebrew supply shop. The 3-way ball valve I found at McMaster Carr. And the stainless steel box I had fabricated by a friend using Corny keg threads salvaged from a destroyed keg.
I hope that you found my homebrew draft system to be well thought out. Cheers!
If the pix die.
'75 Riviera
Whether you are a novice or know your way around an ACVW, a day with Amskeptic is money well spent. My mechanical ability/knowledge/bus is always better after Colin visits.
http://www.thesamba.com/vw/forum/memberlist.php
brookmp
brookmp is offline
PostPosted: Sun Sep 02, 2012 1:23 pm    Post subject: Reply with quote
You, Sir, are a genius! Very Happy. Incredible!
1968 Westfalia Campmobile
1971 Double Cab Pick-up
1974 Standard Beetle
WI sportmobile
WI sportmobile is offline
PostPosted: Sun Sep 02, 2012 2:17 pm    Post subject: Reply with quote
You sir are awesome!!!! I had a dream about doing this at some point. Can you ditch out the water and have 2 kinds of beer? Does the water go through the chiller? Thank you so much for posting.
73 VW T2 Sportsmobile T4 1800 dual webber ICT's
06 TOY Tacoma TRD
Don't mess with the DNR.
"Bargain hunter becomes the bargain hunted."
peaceful warrior
peaceful warrior is offline
PostPosted: Sun Sep 02, 2012 2:24 pm    Post subject: Reply with quote
That is friggin' awesome! My only concern is if you get pulled over by Troopers and they ask to search the Bus, will they nail you for open tap?... Laughing
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
raygreenwood
raygreenwood is offline
PostPosted: Sun Sep 02, 2012 2:39 pm    Post subject: Reply with quote
Very nice work!....just get rid of that brass valve. Its "adequate" for water but not for beer which can have Ph problems with brass. There are plenty of 3 way valves made of stainless of polypropylene. Ray
babysnakes
babysnakes is offline
PostPosted: Sun Sep 02, 2012 2:55 pm    Post subject: Reply with quote
I love you! That is incredible. I used to home brew. Wow! Now you're making me think. Thinking is bad....I think. Very Happy
mranker
mranker is offline
PostPosted: Sun Sep 02, 2012 3:05 pm    Post subject: Reply with quote
Applause Applause Applause
'70 Bus
'02 Eurovan MV Weekender
TequilaSunSet
TequilaSunSet is offline
PostPosted: Sun Sep 02, 2012 3:53 pm    Post subject: Reply with quote
Very Happy Very Happy Very Happy Applause Applause Applause Applause Drool Drool Drool
Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Sep 02, 2012 5:26 pm    Post subject: Reply with quote
Wow.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
akscooter
akscooter is offline
PostPosted: Sun Sep 02, 2012 6:22 pm    Post subject: Reply with quote
I Love it.... Applause but being a homebrewer myself the addition of a co2 tank would be the cats meow to the mix, and only use the pump system as a backup.... Wink
1975 campmobile
1949 Ply Special Deluxe
1991 Custom 1200 HD Sportster XLH
david_594
david_594 is offline
PostPosted: Sun Sep 02, 2012 6:26 pm    Post subject: Reply with quote
That is really pretty impressive! How long do the 12gram CO2 cylinders last? I'm kind of surprised you didnt use a Paintball CO2 cylinder with your setup.
1968 westy weekender
2000 jetta tdi
79 vespa p200e
chazz79
chazz79 is offline
PostPosted: Sun Sep 02, 2012 6:40 pm    Post subject: Reply with quote
Single best bay modification ever.
One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster
aeromech
aeromech is offline
PostPosted: Sun Sep 02, 2012 6:58 pm    Post subject: Reply with quote
Hahahaha
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy
busdaddy is offline
PostPosted: Sun Sep 02, 2012 7:06 pm    Post subject: Reply with quote
Impressive!
Слава Україні!
giller
giller is offline
PostPosted: Sun Sep 02, 2012 8:41 pm    Post subject: Reply with quote
It's already been said, but best mod ever!
I now believe in God.
Please take your ingenuity and turn it towards a fix for climate change. Very Happy
Cheers
notchboy
notchboy is offline
PostPosted: Sun Sep 02, 2012 8:46 pm    Post subject: Reply with quote
Real men of genius:
Fat chick drivin, Orange color bus movin, sleeping and drinking camper beer keg guy.
We solute you!
So when can I get my bus outfitted?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
relaxedryan
relaxedryan is offline
PostPosted: Mon Sep 03, 2012 1:56 am    Post subject: You sir Reply with quote
Hats off too you. Wow. Very impressive.
Chillaxin, Duct tape, Beer.
poptop tom
poptop tom is offline
PostPosted: Mon Sep 03, 2012 3:44 am    Post subject: Reply with quote
Sweet work, Chris! Applause
And I love the stout ring stain on the instructions! Wink
Come down and visit before fall ends!
'76 Deluxe Campmobile
Collie
Collie is offline
PostPosted: Mon Sep 03, 2012 6:02 am    Post subject: Reply with quote
Applause Applause
I agree with EVERYONE above, that is a well thought out system and I love it!
thewalrus
Big Jack
thewalrus is offline
PostPosted: Mon Sep 03, 2012 7:10 am    Post subject: Reply with quote
Extremely cool and I'm very jealous!! Applause Applause
'73 Transporter 1.7L Dual Carb
notchboy wrote:
You ran over some #Vanlife'ers hopes and dreams?
60vwnewengland wrote:
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards!
Page 1 of 4
