Deluxe Trim Color Insert: How to Install?
Yorkie
Yorkie is offline
PostPosted: Tue Sep 11, 2012 6:10 pm    Post subject: Deluxe Trim Color Insert: How to Install? Reply with quote
I am about to replace the insert trim on my '67 Delux and I was wondering if anyone had some tips on how to make this task go smoothly. Last time I tried it I ended up leaving marks on the insert rubber and my fingers went numb.
Thanks,
Kevin
Long Beach
zuggbug
zuggbug is offline
PostPosted: Tue Sep 11, 2012 6:16 pm    Post subject: Reply with quote
I just did my 67 deluxe and I used a plastic trim tool and placed the rubber trim into the top of the aluminum and pushed the bottom of the rubber trim piece into the bottom of the alumninum trim.
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
cru62
cru62 is offline
PostPosted: Tue Sep 11, 2012 6:21 pm    Post subject: Reply with quote
I've used a credit card, too. It helps if the plastic (trim, not the card!) is as warm as possible so it is flexible.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Z
Z is offline
PostPosted: Tue Sep 11, 2012 6:24 pm    Post subject: Reply with quote
X2 on the warmth of the insert...leave it out in the sun for a while before you start. Also, and esp. if its warm, avoid stretching it along its length as you insert it, as it will then draw back up afterwards and be too short.
Also, when you cut the ends, a bit of a point will help the end caps keep it in place.
69er
69er is offline
PostPosted: Tue Sep 11, 2012 10:57 pm    Post subject: Reply with quote
I sacrificed an old, expired credit card and it helped a lot.
Suggestion: Leave the rubber outside under the midday sun for 7-10 days before installation, let it shrink as much as it could before you put it in the trim.
I learned this lesson the hard way when I didn't do that before parking the bus outside. Two weeks later, both ends of the rubber insert just drew back about half an inch.
runderwood
runderwood is offline
PostPosted: Wed Sep 12, 2012 6:32 am    Post subject: Reply with quote
X2 on the "do not stretch" the insert. I stretched it on mine when I installed and was fine for a few months, then it got cold, and now every piece is way short. I actually brought another insert, and need to redo now.
61 DD Panel
Dluxsplits
Dluxsplits is offline
PostPosted: Wed Sep 12, 2012 8:57 am    Post subject: Reply with quote
I let it soak in bucket of hot water right before install but like said before don't stretch it. good luck
________________
'67 deluxe bus
'66 deluxe bus
'60 og paint kombi
'59 og paint bug
d-rick
d-rick is offline
PostPosted: Wed Sep 12, 2012 7:59 pm    Post subject: Reply with quote
I just did mine on my '66 13 window
I left it in the bed of my truck which has a topper on it(like a dang oven!!).. Let it sit in there for a few hot days. Made it easier for sure. The credit card trick works well if you can get it down
1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI
Split 1
Split 1 is offline
PostPosted: Thu Sep 13, 2012 6:54 am    Post subject: Reply with quote
I put mine in a pan of hot water for a few minutes, used a wooden spatula, went in easy enough
Split1
PostPosted: Fri Dec 06, 2013 5:49 pm    Post subject: Reply with quote
This topic came up today in another thread and I remembered I had some photos of doing my old '64 Deluxe.
Description:
Heating it a little with a hair dryer, then press in with the fat padded end of my wire cutters.
Photos:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=502978
http://www.thesamba.com/vw/forum/album_page.php?pic_id=502977
I liked the handle better than a credit card.
Breckskier
Breckskier is offline
PostPosted: Sat Nov 15, 2014 11:41 pm    Post subject: Reply with quote
Where is a good place to buy this rubber? And what do people feel about this red insert on a Turkis color deluxe?
BreckSkier
67 13w Deluxe-"St. Pete" the Airport Jet Bus
65 13w Deluxe-"St. Nikolas"
67 912(911.5 Outlaw build spring 2015), 90 C4Cab. Formerly: 59 DD, 78 SuperB, 81 911Cab, 82Vanagon, 81Vana & other German / US stuff..
Split 1
Split 1 is offline
PostPosted: Sun Nov 16, 2014 1:25 am    Post subject: Reply with quote
Mine was a Turkis and white duxe and it came standard with the red infill
PostPosted: Sun Nov 16, 2014 9:19 am    Post subject: Reply with quote
The red stuff above I bought from Wolfsburg West.
I personally like the green on my green Bus but if you like red better, go for it.
Breckskier
PostPosted: Sun Nov 16, 2014 11:40 am    Post subject: Reply with quote
Awesome! Thanks!
BreckSkier
Breckskier
PostPosted: Sun Nov 16, 2014 11:44 am    Post subject: Reply with quote
Is there a difference in the Sealing Wax red to the Titan red? I'm sort of color blind, so I don't see the difference well. Which would go on a '66 Deluxe?
BreckSkier
Breckskier
PostPosted: Sun Nov 16, 2014 5:24 pm    Post subject: Reply with quote
There are two options of sealing or Titan on WW, so wasn't sure if much of a difference?
BreckSkier
dawerks
dawerks is offline
PostPosted: Sun Nov 16, 2014 6:28 pm    Post subject: Reply with quote
Cannot be done at -20 Celcius. Don't try it.
"There is only one sin; disconnection from self."
hitest
hitest is offline
PostPosted: Sun Nov 16, 2014 8:40 pm    Post subject: Reply with quote
The Titian red is more a blood, SWR more like a tomato (if it helps). The natural compliment to Turkis would be the darker Titian insert, but if people don't already know you're colorblind, they will after the install. Cool
This thread is heavy with warnings about shrinkage, but it is easily combated, simply cram in more insert than you think you can. Example: on a cargo door, if the piece you pre-cut is 1" long, cram a 1/2 inch of it in the molding. You should be able to cram 1/2" of extra material into every 12" of run in the strip. I easily have 5 1/2" of extra material crammed into my long strip on the driver's side. When it shrinks in 40 years, I'm ready.
FU#5
mandraks
mandraks is offline
PostPosted: Sun Nov 16, 2014 8:44 pm    Post subject: Reply with quote
66 and up would be titian red.
regards
Uli
Breckskier
PostPosted: Mon Nov 17, 2014 3:36 pm    Post subject: Reply with quote
Ha! LOL that's great! Thanks guys.
BreckSkier
