| Tow bar tow or Trailer haul |
| Tow bar for the win |
38% |
[ 8 ] |
| Trailer for the win |
61% |
[ 13 ] |
| Total Votes : 21 |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6249 Location: SBS headquarters: Missery
Posted: Mon Nov 12, 2012 9:56 pm Post subject: To flat tow or now to flat tow? |
So I'm moving from South Dakota to Missouri in a couple weeks 790 miles. I was think since I'm not haulling balls in the RV, why not flat tow. Or is it really that unsafe that I should trailer it? Trailer is $370 for the trip or I can buy my own tow bar for future use. Either way I have to get my bus there. LOL
Inputs please! _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2744 Location: Salem, Oregon
Posted: Mon Nov 12, 2012 10:07 pm Post subject: |
| Are you pulling it with the RV, or something else? Are you going to be encountering snow/ice along the way? You will be fine in most instances with the tow bar. They do fine as long as you are not hauling...and the tow vehicle is bigger than the bus or bug. You may need to mod the thing if your bus is real low. My stock one would work. On the '64 with 4" narrow beam, it wouldnt fit. Also was too close to ground that we couldnt get a drop hitch to go that far. Is this the nice green/white one you have? If my memory is correct, we had to remove the drag link as well. |
Posted: Mon Nov 12, 2012 10:13 pm Post subject: |
I'll be pulling it with my 34' RV. Which will be the norm once I'm settled in. Can't go RVing without the bus.  _________________ Anthony
SBS #1
SBS #1 on FB
bugcollections Samba Member
Posted: Tue Nov 13, 2012 4:29 am Post subject: Tow |
| It is safer to trailer. It's cheaper to tow. There are about 10 things that can happen when you flat tow; 9 of them are bad. There are about 10 things that can happen when you trailer; 4 of them are bad. Point being; probabilites are on the side of trailering. In either case; if it is a big RV and you cannot see what you are towing/trailering I would get me a rear camera so you can keep your eye on it while moving. |
Posted: Tue Nov 13, 2012 7:21 am Post subject: |
I'd rather have 4 bad options over 9. LOL _________________ Anthony
SBS #1
SBS #1 on FB
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12571 Location: Over 2002 posts deleted!
Posted: Tue Nov 13, 2012 7:33 am Post subject: |
My old bus never was a trailer queen (or my current one either!) but when I moved myself from Floriduh back to San Diego, it went on a trailer!
Not to mention that it was my very first time towing anything on a trailer and the very first day I got myself into a jam in which I had to reverse out of... UPHILL!!!
Talk about learning the hard way!
Nowadays I flat tow just about anything but only within reasonable distance or where it is a must in the inmediate moment and there's no option for trailering. "Piggy back" is the way to go for long distance.  _________________ Some people are so busy being clever they don't have time enough to be wise. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5010 Location: Richmond, Verjinya
Posted: Tue Nov 13, 2012 9:30 am Post subject: |
_________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Posted: Tue Nov 13, 2012 10:35 am Post subject: |
WOW, look at that weld in the last picture. Flippin blind Monkey must of done that. _________________ Anthony
SBS #1
SBS #1 on FB
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5271 Location: Taoswest, USA
Posted: Tue Nov 13, 2012 11:04 am Post subject: |
Something else to consider is you cannot back up with a tow bar or with a tow dolly, unless someone know something I don't. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Tue Nov 13, 2012 2:34 pm Post subject: |
If you do end up using a trailer, use one with actual, working trailer brakes. Otherwise, you will only be compounding your chances for calamity.
I flat towed my '62 DC once, behind a 2000 GMC Safari. I tested it on the first downgrade which is about 3 miles from my house. I didn't stomp on the brakes, merely tested them. The result almost sent me into the right side guardrail and came as close as I ever want to get to jack-knifing. I had to punch it to regain control on a 7 mile long 7-8% grade. I was going 100 mph at the bottom because ANY braking action caused the same result. On flat ground there was really no trouble and I made it to Bug-o-rama in one piece.
So, my recommendation would be to use a big, heavy, long tow vehicle and a proper trailer. Don't be the guy in front of me on that same grade towing an enormous ski-boat with a Ford Bronco II. Someone cut him off and he jumped on the brakes. The boat shoved him sideways into the guardrail just before it passed him in the adjacent lane.
FWIW-My GMC had a complete tow package, including uprated brakes. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
mrlimbo Samba Member
Joined: April 28, 2004 Posts: 289 Location: Adams, MA
Posted: Tue Nov 13, 2012 3:35 pm Post subject: |
I tow my 67 everywhere with my old class C RV. Never had an issue.. thousands of miles. I've got one of the tow bars made and sold here. I picked it up at the Litchfield Bug In years ago. Couple of issues, the pins holding the bar to the beam were a bit small. They bent on me. Drilled them out to 3/8 pins and never looked back. Also, the bar rubs on the sway bar. You also have to remove the stabilizer shock to mount to bar to the beam.
When I first started towing the bus, it didn't like to turn with the RV in tighter corners. It sometimes dragged the wheels in a real tight corner. I thought it was the large over hang past the back wheels on the RV. Come to find out, the lower trailing arm was bent in and the camber was way off. Replaced the arm and it turns like a dream. It probably also caused the pins to bend. I load it was parts, DJ equipment, camping gear, whatever I'll need for the trip I'm taking. Never a problem.
I put chains on everything. Beam to bar, bar to RV. Here is what it looks like... _________________ -Jim DiGennaro, Samba lurker, Disc Jockey and LiMBO freak www.LiMBObus.org
'67 Kombi- April, its not original and I don't care.
'87 Vanagon GL (daily driver)
'01 Jetta Honey's car
Looking for a Vanagon weekender or Escorial green camper. |
Posted: Tue Nov 13, 2012 3:41 pm Post subject: |
| peaceful warrior wrote: |
| Something else to consider is you cannot back up with a tow bar or with a tow dolly, unless someone know something I don't. |
You are correct. Lesson learned on that. I even tried to have my son steer the bus while I backed up. No good. No damage, just had to remove the bus from the RV and back it up.
As mentioned, if you decide to go with a trailer get one with brakes. You might consider renting a uHaul with surge brakes. I rented one a couple months back to take an old bus to Flanders, NJ for the show and the surge brakes made towing AND STOPPING with a full size Chevy Silverado a dream.
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Tue Nov 13, 2012 5:00 pm Post subject: |
A few years back maybe (4-5) there was what was left of a solid 21 or 23 window deluxe for sale on eBay that had been wrecked and rolled over. If I remember it was sealing wax red and beige grey and was just a badly damaged shell without any parts. The ad simply said the vehicle was being flat towed and there was an accident. It went on to say "Never flat tow a bus" and "please don't ask for more details". I think the seller just wanted to forget about the whole ordeal.
Does anyone here know further details about that bus or what happened? I think it was in Michigan or somewhere up north and there were numerous bidders. Someone here must remember something about it.
Josh _________________ Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap) |
widehatch Samba Member
Joined: May 27, 2007 Posts: 777 Location: Memphis, TN aka The Armpit of the South
Posted: Tue Nov 13, 2012 5:17 pm Post subject: |
i've flat towed buses tons of times and for hundreds of miles. mainly because i didn't have a big truck or tailer. flat towing is safe just use common sense. 2 wheel dolly, now those things are sketchy. if i had the big truck and funds to rent a trailer id go ahead a rent the trailer for the 700+ mile journey just for the piece of mind a trailer would offer. _________________ Missouri Micros |
feastbeast Samba Member
Joined: February 15, 2010 Posts: 41 Location: Alpine, UT
Posted: Tue Nov 13, 2012 6:39 pm Post subject: |
| Uhaul all day long. Insure it with them too. Best of luck. Moving sucks. |
