disk brake convertion
steveo61
steveo61 is offline
PostPosted: Wed Nov 28, 2012 9:35 pm    Post subject: disk brake convertion Reply with quote
would like to convert a69 double cb to front disk brakes what are my options?
mnskmobi
mnskmobi is offline
PostPosted: Thu Nov 29, 2012 6:34 pm    Post subject: Re: disk brake convertion Reply with quote
Disc brake conversions have been covered before. Have you tried a search? Wink
This is an article about adding power assist to the existing drum brakes which is another option you may consider:
http://www.thesamba.com/vw/forum/viewtopic.php?t=511636&postdays=0&postorder=asc&start=0
jpstewart19
jpstewart19 is offline
PostPosted: Sat Dec 01, 2012 7:28 am    Post subject: Reply with quote
Reach out to aeromech (see link posted above) he is ultrafriendly and very helpful. Last year I was setting up my dual battery but was a bit confused, and he was very patient helping me get my head out of my ass.
1985 Vanagon Westfalia Subie
1972 Super Beetle Convertible
1990 Vanagon GL "Winston" (Sold)
1980 Vanagon Westfalia “Rusty” (Sold)
1982 Vanagon Westfalia “Rusty II” (Sold)
1977 Smurf Blue Campmobile (Sold)
grandpa pete
grandpa pete is offline
PostPosted: Sat Dec 01, 2012 7:46 am    Post subject: Reply with quote
has anyone tried swapping a 70 front beam, with all the disc brakes attached, onto a 69 bus...besides the wheel adaptors what else would I run into???
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
busdaddy
busdaddy is offline
PostPosted: Sat Dec 01, 2012 9:32 am    Post subject: Reply with quote
I assume you really mean 71 with the discs, the answer is a few have tried but they discover the bolt pattern where it attaches to the frame is wrong. But you can put the 71+ trailing arms/etc. onto the early beam.
Слава Україні!
grandpa pete
PostPosted: Sat Dec 01, 2012 10:29 am    Post subject: Reply with quote
70-71 Embarassed i wuz close Shocked as always appreciate your vast knowledge mr BD...a bolt up exchange would have been nice..I think I.ll write VW a letter and tell them.... Twisted Evil
63 two fold rag
rubbachicken
rubbachicken is offline
PostPosted: Sat Dec 01, 2012 8:46 pm    Post subject: Reply with quote
you can put any late bay hubs on a '68 bay ball joint beam
i have put '78 bay hubs rotor and calipers on a '68 bay beam for my old chickensplit bus
lucy our westy
lucy's BIG adventure
meet 'burni'
Tom Powell
Tom Powell is offline
PostPosted: Sat Dec 01, 2012 10:22 pm    Post subject: Reply with quote
I put front disc brakes on my '69 camper and posted my experiences.
Aloha
tp
steveo61
steveo61 is offline
PostPosted: Wed Dec 12, 2012 8:06 pm    Post subject: Reply with quote
OK so ill just need to find the whole rotor and calipers set of a late bay and put them on the 69 double so just remove the whole spindal assumbily and replace with late ones? Anything else needed in the change over?
aeromech
aeromech is offline
PostPosted: Wed Dec 12, 2012 8:23 pm    Post subject: Reply with quote
You're being way too nice. That was a nice complement and I appreciate the good thoughts.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
aeromech
aeromech is offline
PostPosted: Wed Dec 12, 2012 8:27 pm    Post subject: Reply with quote
To the OP. try just doing the booster install first and see what you think. You can always add the calipers to the front later on. Right now I'm doing my 4th booster install and all my customers have been happy.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
grandpa pete
PostPosted: Wed Dec 12, 2012 9:21 pm    Post subject: Reply with quote
How much is the conversion kit aeromech? is it a bolt in kit or do I have to have anything welded?
63 two fold rag
aeromech
aeromech is offline
PostPosted: Thu Dec 13, 2012 10:13 am    Post subject: Reply with quote
Hey Pete,
I covered everything in that thread but here's the short version.
Get yourself a booster that works. I usually buy them used and then get them rebuilt for about $155 out the door here in San Diego. You'll need a 1971 MC for about $50 and the rod that goes between the booster and the brake pedal. The rod needs to be lengthened an inch. Then you'll need to weld a plate to the beam for mounting the booster. After that you plumb in the front and rear hydraulic circuits to the MC and wire the switches. All that's left is to run a vaccum line from your engine to the booster. That's about another $25 for the line and $12 for the check valve.
It works very well. Here's the thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=511636&highlight=brakes
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
68bajabus
68bajabus is offline
PostPosted: Tue Aug 13, 2013 10:17 pm    Post subject: Reply with quote
hey aeromech!
thanks for all the great info and help... i was looking into a front disk conversion, but i'm going to take your advice and install the booster first. sounds like a good first step that's less expensive and time-consuming. i have a friend going to san diego this week... is there a source for a rebuilt booster down there that my buddy could walk out the door with? i am in bend, oregon and will be flying back to pittsburgh in late sept. (where i drove the bus last fall) to visit parents and work on the bus. there are virtually no parts or vintage vw infrastructure left in pittsburgh. the bugs and buses have all rotted and the mechanics have closed up shop. thanks again for your help!
68bajabus
PostPosted: Tue Aug 13, 2013 10:20 pm    Post subject: Reply with quote
ps... do i need to buy a new master cylinder, too? i have heard only 73-79 are available. i think my mc is a fairly new oem from 2005 or 2006.
68bajabus
PostPosted: Tue Aug 13, 2013 10:36 pm    Post subject: Reply with quote
one more question... once you install the booster, are you set up to eventually continue with a front disk brake conversion? people have said here that a booster is essential with the front disk conversion. the booster install would work for the front disk conversion, too, i guess? thanks for the great info!
aeromech
aeromech is offline
PostPosted: Wed Aug 14, 2013 6:18 am    Post subject: Reply with quote
hey there,
i posted a reply to your brake booster post on the forum. i am looking for a source for rebuilt brake boosters to install one on my 68. my friend is going to san diego this week and would pick it up, if it was an out the door rebuild... also wondering if i need a new mc... if you get a chance, i would be so grateful if you responded to the post. and that way, the info is there for others.
thanks again!
68bajabus
Okay, here goes....
There is no source here in SD for "rebuilt boosters". There is however a shop here that rebuilds your booster. So first find yourself a rebuildable booster and then find a shop to rebuild it for you. The place I use is called "Bush Power Brake".
Bush Power Brake Service
25 E 17th St Ste A
National City , CA91950
(619) 474-8906
Find someone who's parting out a 1971+ bus and buy the booster, old MC with lower reservoir, and the rod that runs from the booster to the brake pedal.
I always install a new master cylinder and the ones I use fit the 1971 bus. They are available from Brazil I believe and work just fine for about $45 or so. You'll also want to buy a couple new rubber bungs that go in the top of the MC and hold the lower reservoir.
Most people want front disk brakes because they like the way they stop and maintenance is easier. When you install just the booster you'll find much easier braking but you'll still have the higher periodic maintenance that goes along with drum brakes. None of the booster conversions I've done have gone on and installed the disks because people are satisfied with just the booster.
I hope this helped,
Gary
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
68bajabus
PostPosted: Sat Aug 17, 2013 10:04 pm    Post subject: Reply with quote
thanks so much, gary! gonna start looking. i'll let you know how this goes...
