jakokombi Samba Member
Joined: August 15, 2010 Posts: 785 Location: Milwaukee
Posted: Wed Dec 12, 2012 10:58 am Post subject: |
Now you've done it! You posted a picture of your fuel filter! Be prepared.
It looks like you're on the right track with the hitch, tho there are not enough pictures to be sure.
Really nice bus! _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Wed Dec 12, 2012 11:59 am Post subject: |
jakokombi wrote: |
Really nice bus! |
I know, the fuel filter is getting moved later this afternoon along with a bunch of fuel line. The hitch is bolted through the underside of the bumper in two spots then on the frame in two spots. It isn't welded to the bumper, just bolted. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com |
Posted: Wed Dec 12, 2012 1:10 pm Post subject: |
It sounds like you could pull them as one by removing the 4 bumper bracket bolts (up into frame) and the 4 hitch bolts. If you have splash pans at the bumper ends, remove the small bolts into the body. _________________ 70 Sunroof Kombi
73 Thing
72 Baja |
Posted: Wed Dec 12, 2012 3:16 pm Post subject: |
jakokombi wrote: |
It sounds like you could pull them as one by removing the 4 bumper bracket bolts (up into frame) and the 4 hitch bolts. If you have splash pans at the bumper ends, remove the small bolts into the body. |
yeah i figured so. I plan on removing the hitch anyway, so i'll probably work on that tonight. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Thu Dec 13, 2012 2:11 pm Post subject: |
I'm going to start refurbing my wheels this afternoon. Two questions:
1. is aircraft grade paint stripper safe to use on the chrome hubcaps? there is a ton of paint on top of the chrome that i would like to strip so i can polish the chrome. i just want to make sure the stripper wouldn't harm the chrome.
2. what is a close to factory krylon/rustoleum color for the stock white on my 68 to use on the wheels? i'm eventually going to get stock 14s and have them powdercoated, so i'm going to paint my 15s in the meantime since i can't stand the bus having red wheels. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Mon Dec 17, 2012 1:05 pm Post subject: |
made some progress this weekend on the bus. Removed the rear luggage rack and cleaned the roof underneath. Replaced some missing screws and installed the busdepot luggage rack trim to match the pop-top seal.
I also installed a new engine seal and worked on removing the tow hitch. Unfortunately, the tow hitch bolts seem to be broken. they are spinning freely and it looks like nuts were welded inside the frame rail and can't be accessed to get a wrench on them to remove them.
at this point, it seems like my only option is to have the bolt heads cut off.
the bumper shell is off along with the bumper bracket on the driver's side. the passenger side bracket has some rebar welded on top of the bracket, preventing me from lifting it up and over the tow hitch. what are my other options at this point?
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Mon Dec 17, 2012 2:09 pm Post subject: |
Those holes are indeed threaded, I'm surprised that bolt just spins. It could be the weld broke, or the bolt is too small and has a nut.
Do you have access to a cut off wheel?
I think getting that hitch off is your next step.
As to your other question, I don't know if stripper will effect chrome, but I'd be hesitant to try. _________________ 70 Sunroof Kombi
73 Thing
72 Baja |
grandpa pete Samba Member
Posted: Mon Dec 17, 2012 2:31 pm Post subject: |
jakokombi wrote: |
As to your other question, I don't know if stripper will effect chrome, but I'd be hesitant to try. |
I didn't end up stripping the hubcaps, I'm just going to find another set. The hitch bolts just spin and I'm not able to pull them out - I can feel a nut on the other end but there's no access point to get to where they're bolted. Looks like I'm going to have to cut the heads off, right? Once I do that I'll be able to drop the hitch but the bolts will still be stuck in the frame, right? _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Mon Dec 17, 2012 2:53 pm Post subject: |
That looks like the correct dome light, I've got the same one, plate and all in my headliner.
Cut the bolts off and don't worry about it for now. Hopefully they are just bolts and nuts, and the original nuts are still welded to the frame. _________________ 69 Westy |
Posted: Mon Dec 17, 2012 3:02 pm Post subject: |
RocketSurgeon wrote: |
Cut the bolts off and don't worry about it for now. Hopefully they are just bolts and nuts, and the original nuts are still welded to the frame. |
Awesome, thank you. The plate is pop-riveted into the original headliner, I'll drill out the rivets and attach it to my new headliner once it's stained.
I'm taking the bus to a local muffler shop after work to have them torch the bolt heads off. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Mon Dec 17, 2012 3:09 pm Post subject: |
Yes, cut the bolts and push them into the frame. No problem. _________________ 70 Sunroof Kombi
73 Thing
72 Baja |
Posted: Mon Dec 17, 2012 3:21 pm Post subject: |
jakokombi wrote: |
Yes, cut the bolts and push them into the frame. No problem. |
Awesome, thanks. Does anyone know of a store-brand spray paint that is close to the factory color for the bumpers? I figure while my rear bumper is off i might as well give it a quick paint job so it doesn't look as bad. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Mon Dec 17, 2012 4:40 pm Post subject: |
You might try some Easy Off oven cleaner to remove some of that p.o. paint on them first. Do both bumpers and the wheels and that bus could look very original/cool.
Come to think of it, oven cleaner won't hurt the hub caps (oven racks are chrome right?).
Otherwise, most any bright white spray paint like rustoleum should look pretty close. _________________ 70 Sunroof Kombi
73 Thing
72 Baja |
kooldub Samba Member
Posted: Tue Dec 18, 2012 9:02 am Post subject: |
i researched here on the samba and came up with duplicolor wimbledon white on the rims and krylon dover white on the bumpers. if i remember correctly, the split bus guys used these colors. i know our bays are a different factory color (cloud white vs silver white vs lotus white etc) maybe someone else can chime in?!?
the wimbledon is more of a "off" white then the krylon dover white.
sorry, no pic of the stock rims with painted bumpers...
kris _________________ 64 Notchback
68 Fastaru
68 Camper
70 Squareback
73 Thing |
Posted: Tue Dec 18, 2012 10:53 am Post subject: |
kooldub wrote: |
kris |
Awesome, thanks a bunch. this is going to be a weekend project for sure. The bumpers are pretty haggard at the moment, but they're not too dented so I'm sure a fresh coat of paint will help a ton.
I went to the local muffler shop yesterday and they offered to torch the bolt heads off, so I'll be heading there Friday to get that taken care of. I'm off work all next week so I'm sure it will be a productive week. I have both front and rear headliner panels to stain and install, pop-top canvas and seals to install, all stationary window glass to go in, and wheels to sand and spray. Going to be a great week and the bus will be looking way better. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Tue Dec 18, 2012 3:04 pm Post subject: |
Nice camper. I have a '68 as well, except white.
Mine has a hitch too, but it is very different. It doesn't attach to the bumpers at all afaik. It has it's own little frame that goes under the bumper and attaches to the frame.
I'll be watching your thread with interest.  _________________ ~Kevin
My 1968 Campmobile |
Posted: Tue Dec 18, 2012 3:32 pm Post subject: |
Hikelite wrote: |
I'll be watching your thread with interest.  |
Thanks! I'll be sure to check out your thread as well. I'll post more updated pictures on Friday of the hitch and how it was attached. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Wed Dec 26, 2012 3:50 pm Post subject: |
OhHerrooo wrote: |
Hikelite wrote: |
Thanks! I'll be sure to check out your thread as well. I'll post more updated pictures on Friday of the hitch and how it was attached. |
Nothing is gonna happen on my thread for another year. Revenue is going to pick up towards the end of next year, then I will have the $$$ to start on mine. I'll be living vicariously through you and others until then  _________________ ~Kevin
Posted: Wed Dec 26, 2012 4:20 pm Post subject: |
well not much has been happening lately on account of the holidays, but more parts have come in and I've gotten some things done here and there. I had the trailer hitch bolt heads cut off so i could remove it. i got some new blue basketweave seat covers and seat padding for the front seats for christmas, so those will be going on as soon as i get new seat stand mats.
i also got a buffer for christmas, and i've started working on the paint. so far it is shining up very well. I need to get some polishing bonnets and polish before i'm 100% done, but it should turn out great.
'69 Squareback
'68 Westfalia
'68 Squareback
