Steering Coupling Disc 211415417 (coupler)
Page: Previous  1, 2, 3, 4 ... 33, 34, 35  Next
68IHscout
68IHscout is offline
PostPosted: Mon Feb 04, 2013 7:01 pm    Post subject: Reply with quote
Got a question , how much are they supposeto flex when turning steering wheel ?
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Feb 04, 2013 7:08 pm    Post subject: Reply with quote
Probably exactly zero degrees. They are intended to take small vibrations form the road and engine out of the steering wheel, not flex……
www.airschooled.com
Road trip reports and tech blog:
Amskeptic
Amskeptic is offline
PostPosted: Mon Feb 04, 2013 7:16 pm    Post subject: Reply with quote
There are occasions where misalignment actually makes them flex, but their real job is to break/bend away in an accident, so the whole column, collapsible bracket, and steering wheel shaft can splat wherever your body rams them. Early solid steering shafts (splitties) could rupture your internal organs with a unyielding steering wheel rim.
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
airschooled
Air-Schooled
PostPosted: Mon Feb 04, 2013 7:18 pm    Post subject: Reply with quote
Ah- I thought that was the web-like internal section on the shaft that did that.
www.airschooled.com
old DKP driver
old DKP driver is offline
PostPosted: Mon Feb 04, 2013 7:18 pm    Post subject: Steering coupler Reply with quote
They really won't deflect much when new providing your front end is in
good condition all the way from proper tire pressure to steering box and
all in between
Ball joints
center pin
Etc..
if in doubt and you have looked at the previous posts in this thread
buy a new GERMAN one from www.wolfsburgwest.com.
don't buy a cheap euromax or others that claim to be good.
V.W.owner since 1967
Amskeptic
PostPosted: Mon Feb 04, 2013 7:20 pm    Post subject: Reply with quote
That is only on Beetles and Type 3s where they also have to *collapse the shaft* as the steering box and front suspension jump at your feet in the crash.
ColinDeathOfTheParty
68IHscout
PostPosted: Mon Feb 04, 2013 7:21 pm    Post subject: Reply with quote
we install one on a 74 and tbe darn thing flexes like about half maybe more inch before the wheel starts turning , brngs the steering wheel up too and now the horn honks when turning , I wonder if the disk flexing that much will cause it to honk?
curtis4085
curtis4085 is offline
PostPosted: Mon Feb 04, 2013 7:25 pm    Post subject: Re: Steering coupler Reply with quote
all in between
Ball joints
center pin
Etc..
WW all out of the German VW... i bought off there site two weeks ago and was sent generic. I ended up buy 3 from Cip1.com ..
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D415%2D417%2DGR
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
busdaddy
busdaddy is offline
PostPosted: Mon Feb 04, 2013 7:45 pm    Post subject: Reply with quote
Sounds like you got a bad coupling, where did you buy it?
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Mon Feb 04, 2013 8:04 pm    Post subject: Reply with quote
If you don't have something that will flex in the steering shaft there is a real chance of the shaft fatiguing and breaking with time. I have known this to happen on several older vehicles. I have never heard, but perhaps the flex couplings were mandated at some point to address the breakage problem.
Amskeptic
PostPosted: Mon Feb 04, 2013 8:23 pm    Post subject: Reply with quote
It was the Big Deal Safety Update of 1968. Check the advertising.
Colin
68IHscout
PostPosted: Mon Feb 04, 2013 9:56 pm    Post subject: Reply with quote
@busdaddy.....dont know where it came from , it looks well made but then again it doesnt say vw on it. But definetly will take a look at suspension parts and preasure on tires ..thanks for replies...
aerosurfer
aerosurfer is offline
PostPosted: Wed Mar 20, 2013 3:03 pm    Post subject: Re: Steering coupler Reply with quote
all in between
Ball joints
center pin
Etc..
I received and installed a German VW shift coupler from WW today.
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
larryducas
larryducas is offline
PostPosted: Wed Mar 20, 2013 7:37 pm    Post subject: Reply with quote
The horn honks because the wire touches as the wheel turns. Make sure the lug is bolted on the bottom side of the rubber coupling thru the middle hole of the rubber
. The top side will make it honk.
71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb
obnoxiousblue
obnoxiousblue is offline
PostPosted: Sun Apr 07, 2013 5:32 pm    Post subject: Reply with quote
Got my new coupler, it isn't marked at all... But doesn't look or have the shape of the Euromax ones.
Was told, it's German... But well, you know how that goes.
Worth installing? It seems to have a layer sandwiched in it, not sure if it's the mesh described herein but I'll defer to the general opinion...
Mike
1964 Beetle
2001 Eurovan Camper
SGKent Premium Member
SGKent is offline
PostPosted: Sun Apr 07, 2013 7:11 pm    Post subject: Reply with quote
Richard at OE Vee Dub before he sold out shipped me a genuine VW one. Only it didn't say VW so he sent me another that did. When I compared them I found that the only difference was that the VW was ground off the first one. All other marks and casting flaws were the same identical. Whomever VW contracted out to also sold them on the market but had to grind off the VW Audi logo. If you have one made in the EU or Germany that has a grind mark on it, it still may be an original VW one.
George Carlin:
Skills@EuroCarsPlus:
fusername
fusername is offline
PostPosted: Sun Apr 07, 2013 8:26 pm    Post subject: Reply with quote
good to know. I parted out my bus and found that the ~4 year old coupler had already started degrading noticably. will check the new one on the new bus.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
obnoxiousblue
PostPosted: Sun Apr 07, 2013 8:33 pm    Post subject: Reply with quote
Wow, that fast?
The one on my bus is badly cracked, it has a chunk missing too.
So I'm inclined to say anything is better than the ticking time bomb I have.
This one has no VW marks on it however it does have the letters LEGAR on it. It feels very firm, resists my attempts to flex it, and seems to have a middle layer in it, I don't know if its a mesh or just a higher density rubber.
Going to try to get it in tomorrow. I really want to avoid pulling the column apart again.
Mike
1964 Beetle
2001 Eurovan Camper
fusername
PostPosted: Sun Apr 07, 2013 9:20 pm    Post subject: Reply with quote
what I did and got away with, is crawl underneath and remove the 1 pinch bolt that holds the lower flange to the steering box, then you can pull the whole thing up w/ the column and everything. then you don't need two people or 5 foot long arms to hold a wrench above and below the floor!
[email protected]
obnoxiousblue
PostPosted: Mon Apr 08, 2013 4:07 pm    Post subject: Reply with quote
Done
Mike
1964 Beetle
2001 Eurovan Camper
Page 3 of 35
