therealfrogman Samba Guitar Hero
Joined: October 23, 2007 Posts: 666 Location: Pueblo, Co
Posted: Thu Feb 21, 2013 6:59 pm Post subject: Rookie flywheel removal question |
Any ideas for a guy working solo to stabalize the case while I take the flywheel nut off?
_________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
Really appreciate what Everett has done here. Almost like he hand picked some of you. I am very thankful for all the help I get here. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4215 Location: San Diego
Posted: Thu Feb 21, 2013 7:13 pm Post subject: |
Its easier to loosen the nut before you remove the heads/cylinders.
Now you need an impact or get a long piece of angle iron that you can bolt to 2 holes in the flywheel. Get a helper also to stabilize it |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20891 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Feb 21, 2013 8:24 pm Post subject: |
| chrisflstf wrote: |
This is what I use.....
And there is proper tool for locking flywheel.... Be real careful with home made tool, if it fails you can be on a impact course with objects in shop....
http://www.mamotorworkstv.com/vw/product/engine-flywheel-lock-tool_111476/
IF you can not budge flywheel (its torques to 276 ft-lbs) take it to commercial tire shop (services truck tires) and have them hit it with 3/4 or 1 inch air impact... Takes about 3 seconds....
Then there are these tools....
http://www.mamotorworkstv.com/vw/product/air-coole...ol_376122/
http://www.mamotorworkstv.com/vw/product/torque-multiplier-kit-for-gland-and-axle-nuts/
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Thu Feb 21, 2013 8:38 pm Post subject: |
| chrisflstf wrote: |
That;s all I;ve ever done but I wouldnt use a rattle gun, a breaker bar is much more controlled.
Joined: January 01, 2007 Posts: 17925 Location: sticksville, ct.
Posted: Thu Feb 21, 2013 8:42 pm Post subject: |
ahem....
if you are going to get all john muir on that, please be careful _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
runchman Samba Member
Joined: October 03, 2012 Posts: 254 Location: Algonquin, Illinois
Posted: Thu Feb 21, 2013 8:54 pm Post subject: |
big ass bar bolted thru a couple holes, and mine came off *really* easy. I think my bar is about 4 feet long:
Posted: Thu Feb 21, 2013 8:55 pm Post subject: |
Posted: Thu Feb 21, 2013 9:07 pm Post subject: |
Thank you! _________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
Posted: Thu Feb 21, 2013 9:14 pm Post subject: |
BTW, you guys are great! I made the clamps based on some of the pics I saw of what I guess is the actual tool, I think they will work but I will be careful not to destroy any thing. Going to be doing a 12volt conversion with my rebuild. _________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
modok Samba Member
Joined: October 30, 2009 Posts: 27749 Location: Colorado Springs
Posted: Thu Feb 21, 2013 10:03 pm Post subject: |
I have seen those clamps too, not sure what they are supposed to do.......
Another vote for "bolt a long thingy to it" |
SBD Samba Member
Joined: October 24, 2012 Posts: 3298 Location: SOUTH DAKOTA
Posted: Fri Feb 22, 2013 9:55 am Post subject: |
Be careful when using that tool in the middle in Dale M's post. A friend gave his to me when he was through with it. He bought it new and used it while rebuilding one engine. The first time I used it the welds gave up and the handle came off. ABSOLUTELY NO WELD PENETRATION. It might as well been glued on with JB Weld. And this was well over 20 years ago, before the amount of offshore stuff was as bad as it is now. Just sayin'.....
Not sure where he bought it.  |
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2064 Location: El Cajon, CA
Posted: Fri Feb 22, 2013 11:02 am Post subject: |
The "torque-meister" or torque multiplier, is worth every penny.. I bought one for about $50 last year and I love it, you get EXACT torque instead of what I used to do.. (hmmm.. I weight about 150 pounds, so if I have a 3 foot jack handle on my breaker bar, and I hold it about this far away and put my body weight on it.... )
plus, if you have stock rear brakes, it works for those nuts too. _________________ -pariah
'72 Volksrod |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80317 Location: Sneaking up behind you
Posted: Fri Feb 22, 2013 11:04 am Post subject: Re: Rookie flywheel removal question |
| therealfrogman wrote: |
| Any ideas for a guy working solo to stabalize the case while I take the flywheel nut off? |
Use a impact gun, you barely need to hold it. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
SBD Samba Member
Posted: Fri Feb 22, 2013 11:07 am Post subject: |
| tattooed_pariah wrote: |
plus, if you have stock rear brakes, it works for those nuts too. |
Yeah, I finally broke down & bought one of those too. Only way to go. |
Glenn  Mr. 010
Posted: Fri Feb 22, 2013 11:17 am Post subject: |
Home made one.... 9:1 factor.
Member #1009
#BlueSquare
Posted: Fri Feb 22, 2013 4:29 pm Post subject: |
The inpact did it! I did have to heat it up a bit but it came right off. I did not think my 1/2 driver would do it (26 gallon tank) 150 psi.... Yipee! _________________ 73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
75smith Samba Member
Posted: Fri Feb 22, 2013 5:32 pm Post subject: |
First time I removed a gland nut, tried a 1/2" impact(100 gal tank), tried for a couple minutes, nothing, my marks hadn't moved, so tried a 5 ft angle iron bolted up with a 6 ft 3/4" breaker, nothing had my whole weight on it(I weigh 220), tried the impact again, nothing, came back the next morning, shop had cooled down quite a bit, tried the impact again-came right off, didn't even take 2 seconds....still can't explain it, but sometimes it just takes time
by the way Glenn, nice one, you use the starter gear off a starter? _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
