Syncro Fuel Tank Insulation - Replace or leave bare?
Central Syncronizer
Central Syncronizer is offline
PostPosted: Sat Feb 23, 2013 5:16 pm    Post subject: Syncro Fuel Tank Insulation - Replace or leave bare? Reply with quote
I've dropped my tank and I've pulled off the OEM insulation. I'm wondering if most syncro owners that do this just leave the tank bare or recover it in a better material.
I'd like to go without insulation and so would like to know how this is working out for those of you that left it off. My thought is that if I do all the body metal with bedliner, there shouldn't be much chance of rust.
cheers and thanks
Jay
Ongoing restoration/maintenance of my syncro double cab (and soon Westy):
http://88syncrodoka.blogspot.com/
insyncro
Banned
insyncro is offline
PostPosted: Sat Feb 23, 2013 5:57 pm    Post subject: Reply with quote
I install adhesive backed ThermoTec insulation to most of the tank.
It is a thinner product than the stock and is superior as a thermal barrier.
0to60in6min
0to60in6min is offline
PostPosted: Sat Feb 23, 2013 6:13 pm    Post subject: Reply with quote
a good insulation barrier is good and I think you should have it..
to insulate heat of the engine to gas tank...
the OEM insulation is barely enough in summer in hot weather... namely Death Valley in the summer
Smile
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sat Feb 23, 2013 6:34 pm    Post subject: Reply with quote
Is the tank insulation something that was only for the North American market?
Both of my imported from Europe Syncros have no insulation that I can see.
Currently:
All that's needed for evil to prevail is for good people to do nothing.
syncroserge
syncroserge is offline
PostPosted: Sat Feb 23, 2013 7:01 pm    Post subject: Reply with quote
Are they diesels? The turbo diesel syncros have no insulation on the tank.
ng
ng is offline
PostPosted: Sat Feb 23, 2013 7:30 pm    Post subject: Reply with quote
I have my tank out for a re-seal right now and I am upgrading my tank insulation in my 86 Canadian Syncro Westy.
However, I have a related question about the piece of foam between the tank and the van body in front of the tank. My foam is in rough shape and I don't see the purpose of it besides sound proofing. I plan to apply an undercoating for rust protection and some sound proofing. Would there be any reason to replace the foam or should I just leave it out as planned?
Thanks!
1986 Syncro Westy "Braunbaer"
http://www.thesamba.com/vw/forum/viewtopic.php?t=607112
Central Syncronizer
PostPosted: Sun Feb 24, 2013 12:21 pm    Post subject: Reply with quote
Thanks for the info.
The Thermotec adhesive-backed looks a lot like the butyl rubber sound dampeners like Fat Mat etc. I've now seen a similar product marketed as either sound deadener, roofing patch, and heat shield/sound deadener.
This butyl/aluminium laminate is great stuff but I'm starting to wonder if there is a factory somewhere producing this stuff and its then being branded and retailed (and priced accordingly!) by the different specialty companies. I've found the stuff at alocal hardware store as aluminum roofing patch for a fraction of the price that the specialty guys are selling it for. I'll dig some up and post a pic and brand to pass on.
cheers,
Jay
Last edited by Central Syncronizer on Sun Feb 24, 2013 12:28 pm; edited 1 time in total
insyncro
Banned
insyncro is offline
PostPosted: Sun Feb 24, 2013 12:27 pm    Post subject: Reply with quote
No rubber in the product I'm using.
It is a fiber weave with radiant barrier of the exterior side.
Check Summit Racing and other race suppliers.
I have posted numerous times about this and with product links.
Central Syncronizer
PostPosted: Sun Feb 24, 2013 12:32 pm    Post subject: Reply with quote
OK, thanks. I looked on their site and the adhesive backed stuff was butyl/aluminium. I'll look again for the fabric stuff with adhesive backing.
cheers
bosruten
bosruten is offline
PostPosted: Sun Feb 24, 2013 12:39 pm    Post subject: Reply with quote
I used this http://www.thermotec.com/products/14001-aluminized-heat-barrier.html I bought from these guys http://www.mopacautosupply.com/index.html They have outlets in B.C.
'87 Syncro Weekender
insyncro
Banned
insyncro is offline
PostPosted: Sun Feb 24, 2013 12:44 pm    Post subject: Reply with quote
Central Syncronizer
PostPosted: Sun Feb 24, 2013 1:58 pm    Post subject: Reply with quote
Am I missing something here? I've been over the entire Thermo tec website and cannot find the product you are describing. There don't seem to be any fibre weave mats with self-adhesive backing.
cheers
Jay
MsTaboo is offline
PostPosted: Sun Feb 24, 2013 3:16 pm    Post subject: Reply with quote
No, both are/were DJ petrol engine equipped. The Doka has a different engine now, so it's possible the insulation was pulled. (which is what I had assumed before I got the Joker) The Joker has original engine. 72K on it doubt it's been pulled. Both Syncros have minimal rust so I doubt either has had the tank pulled.
Interesting that the VW engineers would spec different coverings on the tanks. I figured it was another America insurance thing.
Currently:
zeohsix
zeohsix is offline
PostPosted: Sun Feb 24, 2013 7:42 pm    Post subject: Reply with quote
cheers
Jay
Part number 13585 should do the trick at Thermotec
zeohsix
zeohsix is offline
PostPosted: Sun Feb 24, 2013 7:54 pm    Post subject: Reply with quote
Looks like there is aluminum fiberglass mat on Flea bay for 1/2 the price of Thermotec I'd send a link but on my phone right now.
Central Syncronizer
PostPosted: Mon Feb 25, 2013 12:52 am    Post subject: Reply with quote
Great! Thanks for the info.
Jay
insyncro
Banned
insyncro is offline
PostPosted: Mon Feb 25, 2013 6:47 am    Post subject: Reply with quote
Bingo
tencentlife
tencentlife is offline
PostPosted: Mon Feb 25, 2013 9:04 am    Post subject: Reply with quote
I stripped off all the ratty factory FG, and then covered only the saddle area above the trans with Reflectix bubble-wrap I had a roll of, secured along the edges with "real" duct tape, the kind that never lets go. I can only see the need for insulation above that big radiant body (hot trans). It made stuffing the tank back in a lot easier, and it's held up in good condition.
Experience is death to doctrine.
syncroid
syncroid is offline
PostPosted: Mon Feb 25, 2013 3:01 pm    Post subject: Reply with quote
My imported 16" syncro also lacks the insulation. (Also doesn't have the charcoal canister and vacuum system for the gas tank vapor - and I though Europeans were more ecologically advanced...)
insyncro
Banned
insyncro is offline
PostPosted: Mon Feb 25, 2013 4:10 pm    Post subject: Reply with quote
I put it above all my transmissions.
I made a flap to cover the fuel tank sender.
The starter gets wrapped with the extra.
