Islandman Samba Member
Joined: March 20, 2008 Posts: 671 Location: Clarksville, TN
Posted: Sat Mar 02, 2013 5:57 pm Post subject: Hood and Side Molding Question |
Hey,
The PO filled in the holes for the molding clips by denting in the hole areas, then filling the dents with body filler. Was wondering if anyone knows of a source for molding that's the same, or similar, to factory but has the pressure sensitive tape on the back side. Also wondering if the back of the original style molding would support the use of the double sided press sens tape.
It's for a satin black lowered cruiser and not for an original resto so as long as its close to it that'll be cool.
Anyone looked and found anything like this? |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Sat Mar 02, 2013 6:59 pm Post subject: |
double sided tape on the original moulding should hold. Ensure surfaces are clean, grease free and dry and you should be good to go _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
74autobot Samba Member
Joined: January 31, 2013 Posts: 65 Location: Texas Corners, MI
Posted: Sat Mar 02, 2013 7:00 pm Post subject: |
i think a 3m double sided tape would work fine for an original molding just get the 3/8" or the 1/2" and stick it on to the back side, trim off the excess with a fresh razor blade.
regards,
justin _________________ For once you have tasted flight you will walk the earth with your eyes turned skywards,for there you have been and there you will long to return. |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Sat Mar 02, 2013 11:46 pm Post subject: |
I would just drill new holes like 1" over from the old ones, and use the proper clips and trim.. leave the dented in holes covered.. _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Posted: Sun Mar 03, 2013 6:26 am Post subject: |
vw_hank wrote: |
I would just drill new holes like 1" over from the old ones, and use the proper clips and trim.. leave the dented in holes covered.. |
I was going to ask about that. I've never seen molding up close but it looked like the clips slide around from the pictures I found. I like this idea better. Only thing is, I'd be worried about drilling right into one of the filled areas. I haven't located them all yet. I've been looking at pictures to try to map these out. The car is already painted. The magnet trick isn't working very well. I'll have to come up with a way to positively identify the mud filled areas.
Thanks Hank |
MRJEL Samba Member
Joined: June 04, 2012 Posts: 478 Location: Jawja, USA
subwayaz Samba Member
Posted: Sun Mar 03, 2013 1:40 pm Post subject: |
Interesting thanks for the link. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11793 Location: Redding, CA
Posted: Sun Mar 03, 2013 5:47 pm Post subject: |
If the magnet trick doesn't work, you have lots of filler.
Or ... a funky magnet.
Tim |
Posted: Sun Mar 03, 2013 7:35 pm Post subject: |
Tim Donahoe wrote: |
Tim |
LOL! Actually, magnet was on piece of metal I welded. Fail. Got a good magnet now. Holes located.
But,....MRJEL's peel and stick looks interesting. I assume that's the same shape as the stock molding? |
MRJEL Samba Member
Posted: Sun Mar 03, 2013 8:44 pm Post subject: |
Islandman wrote: |
Tim |
You can actually find that type of trim in most any size and style you wish. In fact, I just removed some from a 73 last week. I used my stud welder and plugged the holes on that one, going with the naked look.
Check at some of the FLAPS near you. I remember seeing some there. |
