berkeleyjack Samba Member
Joined: April 27, 2012 Posts: 175 Location: Northern California
Posted: Sun Feb 24, 2013 4:50 pm Post subject: Still can't get the power steering belt on! |
Normally I am the kind of guy who has all of my van's maintenance done down at my Friendly Local Vanagon Shop, but recently I decided I'd like to learn how to do at least the basic stuff by myself so I can take care of some of it when I'm on the road.
Right now I'm replacing the power steering belt (BABY STEPS!) and I've got the Conti-SF AVX 10x1075 belt that GoWesty sells, and I've got a copy of the Bentley Repair Manual, but I cannot for the life of me find the section of the Bentley that tells me what the steps are for replacing this belt.
I can find places in the manual where it mentions the belt as part of the power steering pump (48.9), but it says it's a 9.5x1080 and there is nothing directly about replacing a power steering belt. Should I be calling it something else?
I found the instructions on Vanagonauts and that in conjunction with the diagram on 48.9 explains it pretty well, but I'd like to find where that section is in the Bentley since I'm sure it's in there somewhere.
http://www.vanagonauts.com/Belts,-Changing,-Tensioning215.htm _________________ All-grain homebrewer with a 1990 Vanagon Carat.
Posted: Mon Feb 25, 2013 5:23 pm Post subject: |
So does the Bentley not have these instructions in it?
Is there a different, better manual I should have gotten for that kind of information? Is that information something that would have been in the original Owner's Manual?
From the way people talk about it I thought the Bentley was supposed to be the everything-and-the-kitchen-sink Vanagon repair manual... _________________ All-grain homebrewer with a 1990 Vanagon Carat. |
AdrianC Samba Member
Joined: January 13, 2012 Posts: 526 Location: Wherever the road's gone
Posted: Tue Feb 26, 2013 12:51 am Post subject: Re: Power steering belt replacement + Bentley maual confusio |
My Bentley PDF isn't on this laptop, so I can't check where in the manual it is.
The difference between 10x1075 and 9.5x1080 is half a mm on the width and 5mm on the length. Nada.
But it's dead straightforward. Find the pump. Slacken off the various bolts that hold the pump to it's mount, so that it can move. Rotate it towards the engine, so the belt goes slack.
Remove the belt. It's a bit looped round stuff, not least one of the bleeder hoses (you'll need to temporarily remove that).
Put the new belt on, and feed it round the pulleys. Rotate the pump back out as far as you can by hand. Now, with a big screwdriver or similar, lever the pump out and nip the bolt on the main pivot up. You're aiming for the belt to be tight enough not to slip, but not so tight as the bearings get chewed up. If you can turn the belt by hand 90deg in the middle of a length, you're good to go. Tighten the other belts up.
If you're doing the PS belt, you might as well do the alternator and water pump one at the same time, since you have to remove the PS belt to get to that. Same story, with the adjustment on the alternator. Just make sure it goes round the right groove on the crank pulley when you put it back on, and check the tension on the longest side.
If you've got AC, that's probably on another belt - I dunno for sure. _________________ Adrian
Zookeeper of a miscellany of motoring silliness, from 0.75bhp to 9ft tall.
Living life on the road in an '88 2.1DJ Westfalia Club Joker Hightop.
www.WhereverTheRoadGoes.com |
teej Samba Member
Joined: November 26, 2010 Posts: 908 Location: Seattle
Posted: Tue Feb 26, 2013 6:48 am Post subject: |
| berkeleyjack wrote: |
From the way people talk about it I thought the Bentley was supposed to be the everything-and-the-kitchen-sink Vanagon repair manual... |
For inexperienced mechanics the Haynes manual can be helpful, it spells some procedures out better that the Bentley. Having both has proven helpful for me. Bentley assumes a certain knowledge base. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Fri Mar 01, 2013 4:48 pm Post subject: |
Hmm.... Thanks for the advice, guys.
Surprised about the Bentley. The diagrams are helpful, but I kind of expected some troubleshooting information and a better index for $75! Kind of disappointed.
I think the PO must have just over- or under-tightened this belt which is what caused it to pop off. The other ones all look pretty new. _________________ All-grain homebrewer with a 1990 Vanagon Carat. |
randywebb Samba Member
Posted: Fri Mar 01, 2013 4:58 pm Post subject: |
the Vanagon Bentley is the worst Bentley I've seen, but it is what it is... _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Sat Mar 02, 2013 5:02 pm Post subject: |
Dang, I cannot get this belt to go on!
I've loosened the nut at the bottom of the pump as much as I can without the nut coming off, and I've loosened the bolt to the left (looking at the front of the pump) so that I can move the pump around, but even when I push it all the way to the left I still can't manage to get the belt on!
Any idea what I'm doing wrong? Do I need to use a screwdriver to pry it on there or something?
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17313 Location: Brookeville, MD
NorCalbuggy Samba Member
Joined: March 06, 2006 Posts: 128 Location: Tracy, California
Posted: Sat Mar 02, 2013 5:30 pm Post subject: |
Take a look at the bracket with the elongated hole for adjustment - now loosen the bolt where it connects to the pump so it can rotate a bit. _________________ "Steam seems to have killed all gratitude in the hearts of sailors"
1987 Westfalia Vanagon - "Clifford" |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 769 Location: Lancaster PA
Posted: Sat Mar 02, 2013 5:41 pm Post subject: |
The PS pulley essentially has taller sides than the crank pulley so it's easier to put it the belt on the PS pulley first and then over the crank pulley. Look how deep the belt on the alternator is and you'll see what I mean.
A 5mm longer belt would be easier but I believe you can still get the one you have on. _________________ wv2yb0252gg092706 |
Posted: Sat Mar 02, 2013 5:46 pm Post subject: |
Here's the page from the Bentley that I'm using for reference.
I've loosened the 35 Nm nut with the washers at the bottom of the front pump bracket as much as possible, and loosened the 20 Nm bolt in the slotted hole on the front pump bracket as much as possible too.
I can move the pump back and forth, but even when I push the pump inboard enough that it is pressing up against the pump mounting bracket I still can't get the belt on. Even tried prying it on there with a screwdriver for a while but stopped because I was worried I might damage the pulley. _________________ All-grain homebrewer with a 1990 Vanagon Carat. |
Posted: Sat Mar 02, 2013 5:48 pm Post subject: |
| MayorMcCheese wrote: |
Hadn't thought about that.
Lemmie give it a try.
HEY! THAT WORKED!! Thanks for the suggestion!
I got it into my head that bigger wheel = harder and I never would have thought of that.
Everything seems to be in order now. No time for a joyride now, but I'll drag her out for a drive around town tomorrow to test it out.
Thanks guys!  _________________ All-grain homebrewer with a 1990 Vanagon Carat. |
bluebus86 Banned
Posted: Sun Mar 03, 2013 9:54 am Post subject: |
it would help if they sold you the right sized belt. I had the same issues, the belt they sell is fatter and shorter, which means it is a tighter fit. real pain in the arse to install. The correct belt goes on eitehr pulley first, and is a breeze to install, the short fat belt is not so easy.
the 10 X 1075 is not the same as the correct 9.5 x 1080. that is where the problem is. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12419 Location: Santa Cruz, CA
Posted: Sun Mar 03, 2013 11:06 am Post subject: |
| bluebus86 wrote: |
10x1075 is the correct size that VW fitted the vans with. I don't know why the Bentley shows a slightly different size. |
bluebus86 Banned
Posted: Sun Mar 03, 2013 11:20 am Post subject: |
| syncrodoka wrote: |
| bluebus86 wrote: |
where you get that information? |
Posted: Sun Mar 03, 2013 12:01 pm Post subject: |
| bluebus86 wrote: |
A parts program. A slew of parts vendors worldwide also sell that belt.
Ironically my '91 owners manual specs out the 9.5x1080mm belt.
The difference is so minimal it doesn't really matter if you put it on correctly. 5mm is a ~3/16, not a game changer. |
