Trying to work out how to get started...
abritinthebay
abritinthebay is offline
PostPosted: Thu Mar 14, 2013 10:47 pm    Post subject: Trying to work out how to get started... Reply with quote
Ok, so I have my VW splittie - it's in mixed condition but I'm getting the rust/etc fixed up.
Once that is done... how to I go about repainting?
I want to do the whole thing in Masterseries due to it's salt-fighting ability (I'm on the CA coast) so I figure I need to sand down to bare metal, right?
... but how? I don't have a blaster of any kind and there has to be a better way than a simple DA sander like you'd use on wood. Then surely it'll take ages and that will be a problem for the metal before I can paint the Masterseries primer won't it?
After that... I sand the primer down I assume, reapply, smooth, and then apply a top paint coat... right?
panicman
panicman is offline
PostPosted: Fri Mar 15, 2013 8:28 am    Post subject: Reply with quote
You could take it to a couple shops or call around for a quote on sandblasting. Most feedback from folks doing this indicates that its not expensive. And you are right, sanding it to bare metal would take long enough that you're likely to see surface rust start. The other option would be a part by part, staged process, where you deal with one manageable area at a time, and ultimately do the whole job.
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Mar 15, 2013 9:06 am    Post subject: Reply with quote
Master Series silver and black is good for the pan & chassis, but not for the interior/exterior which deserves primer/paint/clear. Those flap sanding wheels on a drill are the best way to strip paint at home. 1 section at a time is the best approach to bodywork.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Thrasher22
Thrasher22 is offline
PostPosted: Fri Mar 15, 2013 9:12 am    Post subject: Reply with quote
Yes, unless you're confident you can finish the repairs pretty quickly, you don't want to sandblast the whole body and let it sit bare metal.
Personally my approach has been to strip each panel down one at a time, deal with the rust/repairs, then seal it up with spray can primer to protect the metal while I work on other sections.
The downside to this is that I'll have to strip the temp primer off again when I'm ready for paint, but at that stage I'll likely just take it to a media blaster.
To strip the paint by hand I've found nothing works better than a knotted wire wheel brush on an angle grinder, which you can get for around $10 at any home depot-like store.
Many people also have luck with paint stripper too.
abritinthebay
PostPosted: Fri Mar 15, 2013 10:00 am    Post subject: Reply with quote
Awesome info guys, thanks.
To clarify - my plan for the MasterSeries on the interior is to just use it as a (high build really) primer. Probably with a sanding stage to get it smoother (though I know it's self leveling).
The black would be for the undercarriage + wheel wells, but yes, not for the interior. Silver would go on everything first as a protective layer. I can always re-prime with a different base for the color coat (plus clear if I don't go with a single stage, which I probably won't). It's for it's protective qualities mainly on the interior.
I may also shoot the interior with LizardSkin ceramic and sound deadener before I do a final coat, but that would just be in the non-visible places (like door interiors and the roof and floor) as it has a subtle texture.
marklaken
marklaken is offline
PostPosted: Fri Mar 15, 2013 3:03 pm    Post subject: Reply with quote
I wouldn't use use a rust inhibitor product (Masterseries) as a base coat for your entire body. It is a great product for doing repairs to pitted metal that you don't plan to replace and fixing pesky rust areas like floors, wheel wells, undercarraige, bumpers etc. It is self leveling, but not nearly as smooth as a sprayed on primer. It is sandable (unlike rustbullet and POR15), but it doesn't sand as nice as primers (it is really hard paint and hard isn't always good).
If you are sanding down to bare metal over a long time, you can cover your work with cheap enamel rattle can paint to temporary protect the metal from surface rusting (better than the spray can primers, which absorb moisture). You will have to remove that rattle can paint prior to epoxy primer, but it will come of very quickly with a DA sander and some 36 grit paper (which you need to do prior to epoxy primer anyways).
I don't like sandblasting (the sand fills all sorts of non-accessible cavities that are supposed to drain water that you will have difficulty removing (especially the rocker panels and the front nose area).
I've always just suffered through DA'ing the whole body...
Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO
GB2S
GB2S is offline
PostPosted: Fri Mar 15, 2013 5:14 pm    Post subject: Reply with quote
Did a little research on my own about sandblasting.
First, was the cost, I was given a quote of $800.00
Second, there is always the possibility that a panel could be warped.
Third. I was told by a sandblaster, that blasting an older car can open up the metal, make it more porous, which could lead to painting issues.
Fourth. I found here on the Samba a Paint and body person who said he didn't like to sandblast cars because it removes a protective product that is applied at the factory.
I'm just passing along info that I have found for informational purposes
Geoff
1963 Ragtop
vaughn bros.
vaughn bros. is offline
PostPosted: Sat Mar 16, 2013 7:28 am    Post subject: Reply with quote
To sandblast a sedan inside and out correctly, thats dirt cheap!
An experienced body person knows that what he/she warps while blasting, will only result in more work later. Only a idiot would sandblast a flat panel to the point of warping.
Blasting reveals the rust holes, then you cut those hole areas out and replace them with non holey metal. Its the whole idea behind blasting.
The only protective coating I know of is maybe jesus, in which some folks would not try to sandblast that type of coating off. Otherwise you can sandblast (or chemical dip) the entire sedan shell and chassis.
GB2S wrote:
I'm just passing along info that I have found for informational purposes.
So am I. Very Happy
abritinthebay
PostPosted: Tue Mar 19, 2013 3:18 pm    Post subject: Reply with quote
It sounds like limited part sanding (ie - piece by piece) either by hand (me) or blasting is my best bet.
Masterseries is going to be the primer, no question about that. (see aforementioned salt issues)
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Mar 19, 2013 5:44 pm    Post subject: Reply with quote
blast it, get it in epoxy the same day and work from there. you will want to kick a puppy if you have to hand strip a whole bus....or any car for that matter!
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
rays-64
rays-64 is offline
PostPosted: Tue Mar 19, 2013 6:33 pm    Post subject: Reply with quote
I did my entire car (interior and exterior) all in Masterseries. I spoke with the manufacture before doing this. They have done entire cars countless times and the product is compatible with other brands. If you don't have access to a spray system you can use a roller.
The knotted wire wheel works great. Try harbor freight, Home Depot sells for $20.00 each and HF sells for $5.00. I went through numerous ones.
Good luck
abritinthebay
PostPosted: Wed Mar 20, 2013 2:29 pm    Post subject: Reply with quote
What sort of spray system did you use? I know MS isn't supposed to be thinned more than 10% and isn't exactly recommended for spraying...
rays-64
rays-64 is offline
PostPosted: Wed Mar 20, 2013 3:01 pm    Post subject: Reply with quote
I worked on 1 section of the car at a time. Project car so it sat in the garage. I used a foam roller with great results, no brush or roller marks at all. 2 coats. If I would of used a sprayer (which I should of) I would of probably used at least 1/3 less. But then I would of spent the money on spray gun and water trap instead. Check out their web site.
Doug C
Doug C is offline
PostPosted: Wed Mar 20, 2013 9:32 pm    Post subject: Reply with quote
Wouldn't stripping down to bare metal then "washing" the surface down with a rust inhibitor (one of the phosphoric acid solution products on the market) be enough to protect from new rust until the car could be epoxy primed, assuming it would be done in a relatively quick time (couple weeks or so)?
marklaken
PostPosted: Thu Mar 21, 2013 2:08 pm    Post subject: Reply with quote
Salt issues are a non-issue with correct automotive primers. Masterseries and other rust inhibitors just use water as their catalyst (rather than a chemical catalyst additive).
Masterseries and the like are very thick paints and dry very hard. Great for a rigid chassis, but not so sure about a flexy car body. I am not a paint engineer, but I'd bet that thin and flexible epoxy primers provide better micro-adhesion and flexural adhesion.
If you are going to use masterseries as the "direct to metal" (DTM) primer, you could easily hand strip and paint (same day) section by section.
Wish List:
Mark Laken
Fort Collins, CO
rays-64
rays-64 is offline
PostPosted: Thu Mar 21, 2013 2:31 pm    Post subject: Reply with quote
That was the way I did my notch. I used Ospho, this left a lite residue on the parts. The car was garaged the full time.
Doug C
Doug C is offline
PostPosted: Thu Mar 21, 2013 6:22 pm    Post subject: Reply with quote
I've been thinking of picking up some of KleanStrip's "Prep & Etch" from HomeDepot.. it's a phosphoric solution that promotes paint adhesion and kills surface rust. It's cheap and I think it may be the same thing as Ospho. So.. did you epoxy prime right over the Ospho (and it's residue) or did you wipe down with a laquer thinner and/or wax remover first? I ask because it sounds like it's meant to be painted right over.. What's the general conscensus?
rays-64
rays-64 is offline
PostPosted: Thu Mar 21, 2013 7:22 pm    Post subject: Reply with quote
That's the same product I used. There's been discussions on here about priming straight over the phosphoric acid or cleaning it off first. When I used the Prep & Etch there was a residue left on some of the panels and a layer of dried white powder on the pan where the acid was extra thick. For myself, once the acid was completely dried I sanded the panel, wiped with cleaner and the used the Masterseries.
