Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sat Mar 16, 2013 9:41 am Post subject: Panel flexing advice needed |
I've gotten rid of "most" the flexing/oil canning in my rear panel, except around the gas cap, where there is quite a bit of movement. If I push on the metal I can hear a "ping" sound which sounds like its trying to catch something (see video).
Is there something that the panel should be bonded to back there? If I could figure out exactly where the supports are I'd ideally just drill a hole and weld it in place. I need to use some filler lower down in the panel where I welded in a large patch, and I'm worried that someone will lean up here causing the whole panel to flex a little and crack the thin layer of filler below.
Any tips? Tricks? I've done quite a bit of shrinking on the rest of the panel already, and I think this area is too wide to do the same treatment. |
fusername Samba Member
Joined: March 15, 2006 Posts: 2899 Location: Boston MA
Posted: Sat Mar 16, 2013 10:19 am Post subject: |
pretty sure the filler hole itself adds a bit of structure. have you looked from inside the b us? I think there is only trim panels between you and seeing that sheet from inside. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52885 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Mar 16, 2013 10:22 am Post subject: |
There are a couple of spots that are (were) welded or bonded in there, you'll have to pull the filler to look (should be changing that anyways ). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Mar 16, 2013 10:45 am Post subject: |
Can't see from the inside, there is an interior (metal) panel in the way.
Good idea on pulling the filler, I hadn't thought of that being removable. I'll do some poking around this afternoon and see what I can find. Thanks guys! |
Joined: January 01, 2007 Posts: 17871 Location: sticksville, ct.
Posted: Sat Mar 16, 2013 1:37 pm Post subject: |
if the panel came unglued/unwelded, you can use panel bond to re attach it. often times when doing work to old cars, the factory glue will give up. if it was crashed in that area, it could have released the glue/welds once you have brought it back to straight _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
