Conflicting timing info...which setup should I use?
Tox56
Tox56 is offline
PostPosted: Tue Apr 24, 2012 3:39 pm    Post subject: Conflicting timing info...which setup should I use? Reply with quote
How I know which settings are correct from oldvolkshome posted below?...my bugs not running well at the moment but either 0 tdc and 7.5 btc seem to affect how it is running so how do I know which is right when I am using a 'VW 113-905-205M, Bosch 0231 137 021 Distributor' on a 1500 manual engine that was not originally fitted to my Beetle as the PO put it into my 56 Oval?
I am running a 'Solex 30 Pict-1 VW105-1 (with power fuel circuit) in conjunction with this setup.
Pulley notches cannot be trusted either as it is not the original pulley I am led to believe after having to locate tdc myself using and old spark plug with a bolt through it to get it smack on.
Beetle 1966-1967 * 1300/1500
Distributor: VW 113-905-205K/L, Bosch 0231 137 009/010 > 315-905-205B, 0231 137 031
Can Use: VW 113-905-205M, Bosch 0231 137 021, 113-905-205T, 0231 137 035 or 036
Points Replacement Plate Assy: VW 111-905-227B, Bosch 1237 110 139
(Note: Order 01 013 Points when using this Plate Assy)
Condensor: 02 007 - Note: If equipped w/AC use 02 069
Rotor: 04 006
Cap: 03 001
Parts Kit (Shims, Washers & Hardware): 059-998-211, Bosch 1237 010 007
Coil: 6 Volt - 00 001, 12 Volt - 00 015
Blue Coil: 6 Volt - 00 016, 12 Volt - 00 012
Vacuum Can: 07 017
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum (Advance Only): 17-19deg @ 1.3 In. Hg, 24-28deg @ 3.2 In. Hg
Beetle 1968 * 1500 Man Trans
Distributor: VW 113-905-205M, Bosch 0231 137 021
Can Use: VW 113-905-205T, Bosch 0231 137 035 or 036
Replacement: VW 111-905-205AA, Bosch 0231 137 039
Rotor: 04 006 (Replacement uses 04 033)
Cap: 03 001 (Replacement uses 03 010)
Coil: 00 015 (Blue Coil: 00 012)
Vacuum Can: 07 024 (Replacement uses Bosch 1237 121 400)
Spark Plug: W8AC
Timing Set At:: 0deg TDC Static or @800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum (Advance Only): 17-19deg @ 1.3 In. Hg, 32-35deg @ 3.2 In. Hg
sxuxrxf
sxuxrxf is offline
PostPosted: Tue Apr 24, 2012 8:19 pm    Post subject: Reply with quote
Easiest way is to buy or borrow a cheap pulley with degree marks.
This way you can truly see where the marks are.
You can transfer the degrees you want to your stock pulley when you're finished.
(ignore the X's )
Tox56
Tox56 is offline
PostPosted: Tue Apr 24, 2012 9:01 pm    Post subject: Reply with quote
Yeah I was planning on doing that in all honesty but as it stands one lot of setting on old volks home says 7.5 btc and the other says 0 tdc and I stumped as in which way to go...I'm just keen for a little clarity on what settings I should be using for sure if anyone knows?
sxuxrxf
sxuxrxf is offline
PostPosted: Tue Apr 24, 2012 9:20 pm    Post subject: Reply with quote
That is weird that it says 7.5* for the 205K/L, but you may also use the 205M/T as a substitute.
While for the 205M/T it says 0*.
I was running at 7.5* with my 205T, by misreading the marks. Thought it was 0*. It started making noises that I didn't like. Got a degreed pulley and put it at 0* and things got better.
(ignore the X's )
Tox56
Tox56 is offline
PostPosted: Tue Apr 24, 2012 10:50 pm    Post subject: Reply with quote
My pulley is definately marked right now for sure...what are we saying then, where should I be timing then to get mine right as the two groups of setting on oldvolkshome contradict one another for sure?
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Tue Apr 24, 2012 11:27 pm    Post subject: Reply with quote
They don't really contradict each other. It's a case of [i]too much information[/0] in that they list several other "can use" distirbutors with different specifications. Yes you can substitute most of the 1965-70 distributors for each other with 30 series carburetors. But in looking at those listings you need to only look at the specifiations of the very first distributor listed.
They also list the full range of possible variation on the advance of the distributors, but in reality the 009/K gives about 25 degrees, so if you time it statically to 7.5 you get about 32 total. The 023/M and 035/T's vacuum canister gives about 32 degrees, so you want to start at TDC.
-Andy
Tox56
Tox56 is offline
PostPosted: Wed Apr 25, 2012 12:22 am    Post subject: Reply with quote
I see what your saying...so would we say then I should time at 0 TDC then inline with the 1500 68 beetle manual spec then if we are going for the dizzy listed in the first position?
The Android
PostPosted: Wed Apr 25, 2012 12:45 am    Post subject: Reply with quote
The M and the T get timed to TDC (and the K gets timed to 7.5BTDC)
However, it IS possible to mix and match vacuum canisters... so if there's no number stamped on the arm of the vacuum canister for you to cross-reference, then you have to verify total advance with a timing light. You don't want to go much over 32, not unless you are at higher elevtations.
-Andy
Tox56
Tox56 is offline
PostPosted: Wed Apr 25, 2012 10:16 am    Post subject: Reply with quote
So if I am going to time at TDC then the Vacuum Canister must be numbered '07 024'? I'm not by the car right now so can't check but will do.
Tox56
Tox56 is offline
PostPosted: Tue May 29, 2012 5:26 am    Post subject: Reply with quote
Can you confirm for me I am doing this correctly with the Stroboscopic Timing Light...I am timing at TDC for idle as is correct with my Solex 30 Pict 1 with Power Fuel Circuit Carb and my VW 113-905-205M, Bosch 0231 137 021 Dizzy Setup.
Vacumm Hose on Dizzy is plugged and the carb hose inlet for the Vacumm is also plugged. Timing is then set to TDC with the Strobscopic Timing Light at Idle.
I then re-attach the Vacumm Hose to the Dizzy and Carb and at between 2500rpm - 3500rpm she sits at 32 Degrees Maximum Advance.
Is this correctly set then?
Culito
11010101
Culito is offline
PostPosted: Tue May 29, 2012 10:21 am    Post subject: Reply with quote
Sounds good. See how it runs and listen for any pinging.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Tox56
Tox56 is offline
PostPosted: Tue May 29, 2012 3:38 pm    Post subject: Reply with quote
The bit that was getting me was the timing at idle with the vacumm and carb ports plugged...any then timing the advance at 32 degrees with it connected...thats right though isn't it?
Its just that the 0TDC line moves when i reconnect the vacumm about 10 degrees so the idle is then different then isn't it?
I have a cheeky little backfire/pop every now and again, that would be to rich a mixture would it?
If I can hear pinging what does that mean also?
Finally...do I set the idle speed with the vacumm attached or plugged?
Culito
11010101
Culito is offline
PostPosted: Tue May 29, 2012 10:04 pm    Post subject: Reply with quote
Not sure about your backfire...that could be other issues altogether.
Pinging (usually under load) means too much advance, back it off a few degrees..but again, you should be fine.
Adjust the idle with everything connected as normal.
'62 bug
johnnypan wrote:
Tox56
Tox56 is offline
PostPosted: Wed Mar 20, 2013 3:01 pm    Post subject: Reply with quote
Can anyone clarify for me...I'm planning on setting again this weekend as I'm not happy with how its running.
Am I timing at idle with the vacum hose disconnected and plugged? (I only ask as when I plug in it advances so doesn't that effectively move my idle timing to being wrong?)
Furhermore, when timing/checking the advance what should be my static rpm rate that I am looking to adjust the timing at to hit 32deg for my 'M' dizzy?
I take it that its best timing at 0deg at the right idle with the strobe light and then hitting ""rpm and just checking it advances according to 32deg?
The Android
PostPosted: Wed Mar 20, 2013 4:38 pm    Post subject: Reply with quote
Yes, with an "M", it's TDC for static or hose-disconnected-idle. Then with the hose hooked back up, rev it up until the timing maxes out and that should be around 32°BTDC.
-Andy
Boom
Boom is offline
PostPosted: Wed Mar 20, 2013 4:54 pm    Post subject: Reply with quote
I have always set timing at full advance and run it. If its off then advance or retard as needed.
Ovals are Overrated.....Click to view image
67 Chubby White Chic
Düg Büg
dLk
tasb
The Distributor Distributor
tasb is offline
PostPosted: Wed Mar 20, 2013 4:57 pm    Post subject: Reply with quote
In other words there is no such thing as static idle timing. Do as Andy says set the timing at 0 degrees with the engine NOT RUNNIING then increase the RPM gradualy and you should see with the timing light that the spark is advancing until it tops out at no more than 32 degrees BTDC.
Roads Scholar
Member# 2059
Tox56
Tox56 is offline
PostPosted: Wed Mar 20, 2013 5:33 pm    Post subject: Reply with quote
Thanks fellas...I didn't know if there was a specific rpm count I should be hitting at 32deg as I have a rev counter on my multimeter so was going to utilise that feature?
The Android
PostPosted: Wed Mar 20, 2013 5:42 pm    Post subject: Reply with quote
I seldom bother looking at a tach, I just watch the timing marks as I rev it up and wait for them to stop moving.
