gonebaby Samba Member
Joined: July 08, 2009 Posts: 110 Location: freeland pa.
Posted: Wed Mar 20, 2013 4:47 pm Post subject: do the Military have smaller turn signals? |
looking to see if the military 181's have smaller front turn signals? if so where can I get them? Thanks Rob |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Wed Mar 20, 2013 5:35 pm Post subject: |
The Military versions were usually on older pre73 bodies with smaller bases for the turn signals. 181's were built as early as 1968 I believe.
They also had the split windshield bus tail lights. _________________ 74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6 |
el_safari Samba Member
Joined: January 01, 2005 Posts: 397 Location: Nouvelle Aquitaine,France
Posted: Thu Mar 21, 2013 2:27 am Post subject: Re: do the Military have smaller turn signals? |
gonebaby wrote: |
All 181's sold in Europe have smaller front turn signals with a special model for Italy .
Chrome on civilian , painted on military .
Small base for the turn signals on all the swing axle models .
Larger base on all IRS models .
If you don't find some you can PM me  |
ratrodthing Samba Member
Posted: Thu Mar 21, 2013 11:12 pm Post subject: |
smal base on the front fender have they from 1968-1969 Thing that are the frist things and very rare
but the 1968 are prototypes vw build 16 things
because the pruduktion from the munga was end and the german army Need new kurrier cars
from 1970 there have all Long base and
all things in europe have turnlights from the bug from 1963-1973 i know
and rear from the late split bus and first bays from 1963-1972
that i find
The VW Type 181 Kurierwagen is a military jeep, which was first produced in 1968 exclusively for the Bundeswehr. The model was produced until 1980 and sold alongside the German army also to other agencies as well as to private individuals. In Mexico, the Type 181 was built from 1970 to 1980 as a VW Type 182 Safari. In the U.S., the model by his nickname "The Thing" but became known as under his real name, so Volkswagen of America this as time goes by and in its advertising materials such as television advertising, posters and even the print catalogs used as an alias, without the actual model designation from Mexico to be deleted from their program. In Indonesia it was assembled from 1973 to 1980 VW Camat. In the export version for other right-hand drive countries there however as he rolled off the assembly line VW Trekker
The career of the courier truck began as a "stopgap". The German army had the problem that the production of the DKW Munga expired at the end of the 1968th As a replacement was developed jointly by France, Italy and Germany, the "European Jeep" planned, but this international project did not go beyond the planning stage.
When searching for an alternative, the choice fell on Volkswagen. The Wolfsburg-based group should construct based on the VW Beetle the necessary, limited off-road utility carts. In the construction that was developed for the VW based in Australia, 1967 Country Buggy presented, which was developed by Volkswagen engineers in the Australian assembly plant in Clayton Victoria [2]. Also driven the engineers at VW jeep that was used in World War II.
In September 1969, during the presentation at the International Motor Show in Frankfurt am Main, the VW 181 was found as a military vehicle in the style of the jeep, only slightly more modern, but bigger and heavier. The box-shaped body with four half doors was adapted to the use and the style of the time. With the sales name "courier car" should be a roll-call connection to the jeep of the Armed Forces should be avoided. Nevertheless, he quickly earned the nickname among soldiers "bucket".
The body was bolted to a central tube-frame platform (in this case was the change in various aspects of the platform Karmann Ghia Type 14 is used). Side members (sills) ensured the required torsional strength. Also with regard to many other components fell back on existing technology and robust handle. VW Beetle from 1500 of the air-cooled 1.5-liter 44-horsepower boxer engine, clutch, instruments, steering and the 40-liter fuel tank was taken. The gearbox and the rear axle came with Radvorgelegegetriebe, easily modified. Adjusted first of the 1967 Volkswagen Transporter
By the use of the countershaft gears on the rear wheels, the ground clearance is increased. Four drum brakes made for a sufficient delay. From the weather, the occupants were protected by an unlined all-weather canopy with a water resistant PVC cover and called Einsteckscheiben made of poly. The front could be folded forward and locked with two snaps
The interior was only heated by a heater, with the spare wheel under the front hood had its place. The two-stage adjustable front seats upholstered in durable synthetic leather. The rear seats fold down completely or could be shared, which created additional loading. Just one year after the performance of the vehicle in 1970 was a 1.6-liter engine is used. By a withdrawal of the compression of 1:7.5 to 1:6.6, the power of 44 PS remained unchanged, but allowed in use worldwide, the use of inferior fuels also. The transmission is fitted to the reduction gears a higher ratio, the top speed was thus increased to 115 km / h (before 110 km / h).
Major changes were made in 1973, the engine was sealed up and carried now at gleichgebliebenem Displacement 48 hp. The pendulum axis is replaced by a semi-trailing arm axle with double cardan shafts as in the VW 1302 / 1303rd A design with a combination of beetle that time current bus transmissions replaced the outdated countershaft design. The tire size was changed from 165 to 185 R 15 R 14. A fresh air heating replaced the obligatory heater in conjunction with large air intake slots above the rear fender, so the engine does not exhaust gases are sucked in and could not get into the interior (the same principle as with the Beetle). Military vehicles were the exception, in part because of additional costs, partly because of the heater and the military maintained exhaust system. The civilian version had a cross similar to type 1 pot
Priced the third beside VW Beetle and Karmann Ghia Volkswagen was open at a high level. Private customers had to pay for a 8500 DM spartan equipped vehicle. A limited slip differential cost DM 435 extra.
The German Army has ordered 15,275 vehicles of "Cars 0.4 t tmil 4 × 2" (cars, 0.4 tonne payload, teilmilitarisiert, four wheels, two of which are driven). These vehicles were delivered in the period from 1969 to end of 1979. Also at the Federal came in the vehicle the 1970s used mainly as patrol vehicle on the inner German border.
The production of "courier car" began in 1968 with 16 copies of the main plant in Wolfsburg. Until 1974, there were 57,574 units produced. Thereafter, the production was moved to the Volkswagen plant in Hanover. Hanover to 1975 left a total of 10,629 vehicles the tape. The last domestic manufacturing plant with 2,323 units of the Volkswagen plant in Emden (production end 1978) was. In America, the "courier car" with considerable success was expelled. 1970 and 1971 were known as CKD kits from Wolfsburg exported and assembled in the recipient country. From 1972, the VW Safari is built in Mexico. Imports from these production vehicles are seen at the oversized "Elefantenfußrückleuchten" like the VW Beetle 1303rd That came from the VW Safari in the U.S. at the beginning of the 1975th There was the newly adopted safety requirements for new vehicles do not meet the safari. However, it was in spite of the U.S. ban, making the sales figures dropped, continued to be produced in Mexico. In 1980 in Puebla, only 695 cars off the line. Then in the final assembly plant for the VW 181 production to 64,254 units has been set. In the period from 1968 to 1980 140,768 vehicles rolled off the production lines, which exceeded expectations at Volkswagen.
Some parts of the VW type 181 found after the cessation of production at VW Iltis use, such as the window frame. With modified hinges Verdeckspriegel, sun visors, windshield wiper motors and the window glass |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2013 Location: Athens, TN
Posted: Fri Mar 22, 2013 3:39 am Post subject: Re: do the Military have smaller turn signals? |
Hey Rob...
Check out my build thread. I used '63 bug turn signals up front. Obviously you'll still have the big light base on the fender, but it's not terribly obvious to most... Only real Thingers will notice.
I got mine from a local vw parts house, new for maybe $50???
Good luck!
gonebaby wrote: |
_________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
jjrannauro Samba Member
Posted: Fri Mar 22, 2013 11:44 am Post subject: |
Some picts from Military 181
Posted: Fri Mar 22, 2013 1:00 pm Post subject: |
Thanks for the help guys.. it's appreciated. Im going to find a early set of turn signals to throw on those fenders. thanks again. Rob |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Fri Mar 22, 2013 6:23 pm Post subject: |
I used the small lights from 67-69 on my purple car. With these you have a dual element light bulb and the light will cover all the holes on the fender. |
GI Joe Samba Member
kubelmann Samba Member
Posted: Sat Mar 23, 2013 6:38 am Post subject: |
Those are the same lights I am collecting to put 5 on the front leading edge of my hard top as running lights and additional front turn signals. I am replacing the filament bulbs with LED units. Will be very sharp looking when i get them done. |
Posted: Sat Mar 23, 2013 7:24 pm Post subject: |
Kubelmann make sure you post pictures with the led's in ok |
waxhead Samba Member
Joined: January 19, 2004 Posts: 950 Location: Philly 'burbs
Posted: Tue Mar 26, 2013 6:44 pm Post subject: |
_________________ Mike B. |
Posted: Tue Mar 26, 2013 7:01 pm Post subject: |
wow waxhead thats actually how im making my thing.. color and all. great look man. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Wed Jan 14, 2015 7:23 pm Post subject: |
I am working on patch panels to make correct looking early fenders out of later ones since the early ones are impossible to find.
_________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Posted: Wed Jan 14, 2015 7:25 pm Post subject: |
72 down style verses 73 up
GI Joe Samba Member
Posted: Thu Jan 15, 2015 3:12 am Post subject: |
Nice patch !  _________________ La terre n'est qu'un seul pays |
Posted: Thu Jan 15, 2015 11:24 am Post subject: |
jeremyrockjock wrote: |
Very nice! Good job ! |
Dimitrios Samba Member
Joined: May 02, 2005 Posts: 113 Location: Athens, Greece
Posted: Thu Jan 15, 2015 12:02 pm Post subject: |
Nice work.
I have more than 10 sets of early signal front fenders from ex army 181s as well... _________________ Used Porsche 911 & VW 091 & 094 transaxles!!! |
Posted: Thu Jan 15, 2015 12:16 pm Post subject: |
Here is The Military Thing Mexican Brochure. Enjoy
A brochure for some special equipment
Hellenic Navy VW 181 (Information taken from the forum Dastank.com)
The first example has Hellenic Navy registration number '254'. Note that is has air intake muffs. Rear view of '254'. It has the small rear lights, as fitted to all military production VW 181s.
The second example, number '278', lacks the air intake muffs. Note that '278' has the later 'elephant feet' rear lights. Military spec VW 181s normally have the small rear lights
