Swingaxle to IRS or Swingaxle w/o RGB pros/cons
mk1motorsport
mk1motorsport is offline
PostPosted: Mon Mar 25, 2013 5:14 pm    Post subject: Swingaxle to IRS or Swingaxle w/o RGB pros/cons Reply with quote
Looking to gather info on weather to covert from Swingaxle to IRS or stay Swingaxle w/o RGB pros/cons. Please post a comment if you can help! PICTURES WOULD BE GREAT TOO! If you have done either conversion please tell what kit you uses and your like/dislikes
*i'm hoping this will help others in the future
Cheers
David
joe56vw
joe56vw is offline
PostPosted: Mon Mar 25, 2013 5:30 pm    Post subject: Reply with quote
The pros and cons would depend on your plans for the bus
Irs and no rgbs are good for lowering and faster freeway speeds
Rgbs are good for using it as a work truck or trailbash bus
There are lots of other pros and cons but it would be easier to answer if we know what yours plans for the bus are
'60 15 window walkthrough
why is there no sarcasism button on here?
mk1motorsport
PostPosted: Mon Mar 25, 2013 5:43 pm    Post subject: Reply with quote
I personally am looking to build a kick a55 63 panel. Something that will handle (as well as a panel will handle). Twist up to 6500-7000rpm. Do killer smoke shows, looks its age without feeling it and make people smile:).
joe56vw
joe56vw is offline
PostPosted: Mon Mar 25, 2013 5:58 pm    Post subject: Reply with quote
Then you will probaly want irs cause swingaxles break easily when doing burnouts
GTV
GTV is offline
PostPosted: Mon Mar 25, 2013 6:55 pm    Post subject: Reply with quote
The biggest advantage of IRS is that it handles much better, but is more complex (more parts to break, especially when abusing it) and it is heavier. If you want to abuse your trans like that (and I mean that in a positive way), you're best to convert the trans to the later 68+ style with IRS. It's more expensive at first, but they can take a serious beating.
EMPI Power Rules!
rubbachicken
rubbachicken is offline
PostPosted: Mon Mar 25, 2013 7:48 pm    Post subject: Reply with quote
i went with IRS, it'll handle better.
if you find an early steel A arm 924/944 rear end, you'll have everything you need, and you get porsche rear brakes, the porsche rear brakes will bolt straight onto an IRS but i think you might need to add a spacer in there somewhere
lucy our westy
lucy's BIG adventure
meet 'burni'
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Mar 26, 2013 6:26 am    Post subject: Reply with quote
To "IRS" or "not to IRS", that is the Q Cool
vdubdan
vdubdan is offline
PostPosted: Tue Mar 26, 2013 7:58 am    Post subject: Reply with quote
While you are thinking about making it go faster start thinking about how you are going to stop it. It is all a balance and Volkswagen had it pretty well thought out.
mk1motorsport
PostPosted: Tue Mar 26, 2013 4:18 pm    Post subject: Reply with quote
Absolutely! But right now I'm running a 1500. I just want to remove the RGB, but at the same time move forward. Thank for the putting that out there someone may not have given that a thought
mk1motorsport
PostPosted: Tue Mar 26, 2013 4:29 pm    Post subject: Reply with quote
What kits are people using? If custom built: how did you build it.
demon1018
demon1018 is offline
PostPosted: Tue Mar 26, 2013 4:35 pm    Post subject: Reply with quote
i used a bug irs in my 64 . i bought the "clips" online . these are the brkts to convert a swing axle bug to irs. i opened them up to fit the bigger torsion tube but worked real nice . im real happy i did it. ive got pics in my build thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=506171
joe56vw
joe56vw is offline
PostPosted: Tue Mar 26, 2013 5:24 pm    Post subject: Reply with quote
if i had the money i would get a kit from wagenswest all the stuff i have seen of his was really nice
if i was going the budget route i would just get all the parts from a late model bug and have the springplates cut to bolt up to the irs trailing arms
Vintagespeed
Vintagespeed is offline
PostPosted: Thu Mar 28, 2013 5:05 am    Post subject: Reply with quote
damn that's a sick setup. Love it! Wink
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Clara
Clara is offline
PostPosted: Thu Mar 28, 2013 7:42 am    Post subject: Reply with quote
a stock 63-67 1 ton tranny is geared perfectly for a 1500/1600.
If you have a stock 1500/1600, and run it up to 6500-7000, better be ready to build another motor. IIRC, the redline on that motor is around 4K. But you probably already have plans for a balanced blah blah blah motor.
mandraks
mandraks is offline
PostPosted: Thu Mar 28, 2013 9:22 am    Post subject: Reply with quote
I would recommend to any and everybody to drive a rock stock 65, large nut 1600 with stock wheels and tires BEFORE they rip everything out and build bigger motors, remove RGBs, put tiny wheels on it, etc.
Many might find that a well maintained stock bus drives much better than they think.
Unfortunately many vw owners have never owned a good stock bus, and think that the hulk they just bought is the measure of how a VW bus drives.
with good tires, healthy motor, good brakes, new tie rods, adjusted steering box and good shocks a bus will drive just fine, go anywhere, get 25 miles to the gallon, won't veer of the road when you stomp the brakes, and is NOT susceptible to windgusts on highway overpasses.
Once that baseline is established, you can still modify it to "fix" what you need.
not a rant, just a recommendation Smile
regards
Uli
Harleyelf
Harleyelf is offline
PostPosted: Thu Mar 28, 2013 3:58 pm    Post subject: Reply with quote
My '66 had a '74 bug transmission in it when I bought it, and late '68 brake backing plates and drive stubs. I've added Safari drive stubs to the trans so I can run large CV joints on both ends of the axle. It's taken me from California to Florida and back three times and handles fine.
64+65doubledoor
64+65doubledoor is offline
PostPosted: Thu Mar 28, 2013 8:35 pm    Post subject: Reply with quote
safaris on the gearbox ,interesting
March 55 Wolfsburg bus
march 54 barndoor s.c
58 beetle
demon1018
PostPosted: Fri Mar 29, 2013 5:40 pm    Post subject: Reply with quote
theres also alot of info on this on the steering box scrapers website. look uner technical section and its right at the top. just remember theres more than one way to do it Wink
