Restoration of my COW-LOOK car at GAB-FAB
Page: 1, 2, 3  Next
danny gabbard
danny gabbard is offline
PostPosted: Sat Mar 23, 2013 12:19 pm    Post subject: Restoration of my COW-LOOK car at GAB-FAB Reply with quote
This thread is going to be on the build of the car, Paint and bodywork,assembley and light fab work. If you want to see the custom welding and fab work, It is in my thread metalshape'n and fabrication at GAB-FAB. I will start off here with the pan. I cut and made the center of pan removeable. I ct and replace pan halfs from a pan I got from mark at wolfsburg west. The pan with the orange pan halfs is a pan that I did for roger crawfords 67 convertable. Just useing pictures as a reference to how bottom bolts back on.
Shipping is NOT included in any of my products or parts. Just want to say thanks from GAB-FAB for any purchase!!
danny gabbard
PostPosted: Sat Mar 23, 2013 12:40 pm    Post subject: Reply with quote
I removed stock clutch cable and added a morse cable, And removed stock center section of rear torsion house'n and added a adjustable center section
danny gabbard
PostPosted: Sat Mar 23, 2013 12:49 pm    Post subject: Reply with quote
Few more shots of the chassis build,356 B brakes I rebuilt and tranny installed, and start of stainless plumbing.
danny gabbard
PostPosted: Sun Mar 24, 2013 11:11 am    Post subject: Reply with quote
Few shots of my hella battery cut/off switch that I reworked to look like a heater knob and fuel pump and bracket I made.
Keith
Keith is offline
PostPosted: Sun Mar 24, 2013 9:33 pm    Post subject: Reply with quote
Looks good . Where did you get the rebuild parts for the 356b brakes ?
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
danny gabbard
PostPosted: Mon Mar 25, 2013 4:50 am    Post subject: Reply with quote
Hi Keith, Stoddards in cleveland Ohio carries all the stuff you need to rebuild 356 B brakes. They also make stainless pistons for wheel cylinders and stainless bleeder screws.
danny gabbard
PostPosted: Mon Mar 25, 2013 5:01 am    Post subject: Reply with quote
This is a mid mount that I make if anybody is interested. There is meant to be the piece welded to the flange on the frame horns, I already had pan painted and tranny in car before I started make'n them. So The next time the tranny is out, I will weld piece on. And another shot of the other mount I make.The deal in center of mount , Is meant to locate on the center of floor jack with out the ring on jack. Keep from slipping off jack.
danny gabbard
PostPosted: Mon Mar 25, 2013 5:12 am    Post subject: Reply with quote
Couple shots of the rear apron after fill'n exaust outlets and heat shield. Had to fix one fender bolt nuts on front 1/4 and then off to wallnut shell blast the original ruby red paint. Then it gets its first primer. DTM from valspar is the primer I used
danny gabbard
PostPosted: Mon Mar 25, 2013 5:18 am    Post subject: Reply with quote
danny gabbard
PostPosted: Mon Mar 25, 2013 5:24 am    Post subject: Reply with quote
The only two spots I had to use filler on complete car.
danny gabbard
PostPosted: Mon Mar 25, 2013 5:53 am    Post subject: Reply with quote
Few shots of the paint, Color is L-87 and I used single stage deltron and clear coated while still wet.
danny gabbard
PostPosted: Mon Mar 25, 2013 5:59 am    Post subject: Reply with quote
Now that I let paint set up or cure for about a week, I take a razor blade and go around car and scrape any dirt and and tiny sag's I got while spray'n the car. After that, I go around with 1000-1500 grit sandpaper on a soft rubber pad and color sand and then rub paint. I like useing the sponge pads that 3M offers to rub paint
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Tue Mar 26, 2013 1:45 am    Post subject: Reply with quote
I'm suprised at the clacker fuel pump on that build. I've had good luck with them but most people bad-mouth them.
I'm going to steal your idea on the removeable center spine panel. That's a great way to make upgrades and maintenance easy!
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
danny gabbard
PostPosted: Tue Mar 26, 2013 10:41 am    Post subject: Reply with quote
Ya, I have heard a lot of bad feed back on the fuel pumps, Mostly the new ones made in china, Mine is a new original facet pump. All I can do is hope for the best !!LOL Good to hear on the pan, Does make do'n any work much ez'r
Dauz
Dauz is offline
PostPosted: Tue Mar 26, 2013 12:04 pm    Post subject: Reply with quote
Words can't describe how jealous I get when I see a classic VW being built like this. I wish I had the resources.. .
danny gabbard
PostPosted: Tue Mar 26, 2013 12:09 pm    Post subject: Reply with quote
Thanks, Means a lot to hear!
vaughn bros.
vaughn bros. is offline
PostPosted: Wed Mar 27, 2013 8:49 am    Post subject: Reply with quote
Are those Halibrands? Man you are a hard worker. I hate painting white(or variations of white) because of all the little problems it attracts. Love your thread. Very Happy
oldmanmark
oldmanmark is offline
PostPosted: Wed Mar 27, 2013 10:26 pm    Post subject: Reply with quote
wow,nice work. guys like you and the vaughn bros. just knock the wind out of me. im a garage tooled hobbyist, something to reach for. good thread.
danny gabbard
PostPosted: Thu Mar 28, 2013 8:34 am    Post subject: Reply with quote
Thanks again, The wheel are second generation original 5 spoke empi's By second gen, They change the casting's, More web'n on back side, Where the wheel halve's meet they got rid of sharpe corners and the last thing is get rid of the counter sunk lugs and went to the BMR style insert/lug. Wheels were pron to crack'n
danny gabbard
PostPosted: Thu Mar 28, 2013 8:35 am    Post subject: Reply with quote
My pleasure and thank you!!
Page: 1, 2, 3  Next
