rusty wheel treatment?
targis58
targis58 is offline
PostPosted: Mon Apr 29, 2013 11:10 am    Post subject: rusty wheel treatment? Reply with quote
Hi, all
I have 15" south african steel wheels that have been sitting in my back yard which have collected some rust on the surface. I would like to use these wheels as a off-road set but would like to treat them before putting tires on.
What are some available options?
They are black now with not so terrible rust on.
Thanks
Allen
90 westy 2wd w/ TBD
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Apr 29, 2013 11:27 am    Post subject: Reply with quote
Depends on what you are after.
You can use CLR to get light rust off. Then just wax. Might be good enough.
Use Metal Prep (acid,) rinse, dry, scuff and paint to suite.
Powder paint (sand blast and coat.)
Or leave alone and just be sure sealing surfaces are clean.
What is your goal? Function or looks?
targis58
targis58 is offline
PostPosted: Mon Apr 29, 2013 12:06 pm    Post subject: Reply with quote
With rust, function is still there.
I would like a proper look to match my van Very Happy
90 westy 2wd w/ TBD
MarkWard
MarkWard is offline
PostPosted: Mon Apr 29, 2013 12:36 pm    Post subject: Reply with quote
Sand blast and powder coat then.
SteveVanB
SteveVanB is offline
PostPosted: Mon Apr 29, 2013 1:46 pm    Post subject: Reply with quote
Ospho?
91 CARAT
targis58
targis58 is offline
PostPosted: Wed May 01, 2013 11:16 pm    Post subject: Reply with quote
Do tires have to come off the wheels for sand blasting and powder coating?
90 westy 2wd w/ TBD
targis58
targis58 is offline
90 westy 2wd w/ TBD
BillWYellowstone
BillWYellowstone is offline
PostPosted: Thu May 02, 2013 7:18 am    Post subject: Reply with quote
Yes, have to remove tires, and valve stem.
Live Fulltime in motorhome
Have 86 Westy Camper 2.1 rebuilt
Work in Yellowstone NP year round.
MarkWard
MarkWard is offline
PostPosted: Thu May 02, 2013 9:48 am    Post subject: Reply with quote
If pulling the tires and valve stems seems like too much trouble, some steel wool, sand paper, masking tape primer and rustoleum and you can get a pretty nice result. Oh, I forgot the elbow grease. Rustoleum spray will lay out pretty nicely but takes forever to dry.
unibagel
unibagel is offline
PostPosted: Fri May 03, 2013 4:42 am    Post subject: Reply with quote
Wurth Wheel Paint works really well!
