Another Pertronix wiring question
Crestrider
Crestrider is offline
PostPosted: Sat May 11, 2013 10:24 am    Post subject: Another Pertronix wiring question Reply with quote
Hello, first post here so hello first of all.
I have a 71 bay 1600 and a Karmann Ghia (but the Ghia is another story)
I only got the bay a month ago and plan on using it over the summer and then starting a resto.
I've had a few issues with backfires and loss of power so set up the timing and all was fine however a trip out on Friday led to a breakdown and closed points.
So I purchased and fitted a Petronix igniter but I'm a little confused by the wiring, I've had a look and seen a few questions on here already but couldn't find anything specific to help solve my problem so here goes.
Install: removed condenser, points and fitted kit ~ black wire to negative ~ red wire to positive. However I had to remove the black wire which splits and goes to the solenoid and automatic choke.
With the red wire from the Pertronix and the other red wire (starter) connected there now isn't a positive terminal for the black wire. That's where I'm confused because without this wire connected the engine stars and runs sweet but I'm concerned I should have the black wire attached too?
Any help and tips appreciated.
Thank you
WI sportmobile
WI sportmobile is offline
PostPosted: Sat May 11, 2013 11:08 am    Post subject: Reply with quote
They do sell spade connecters that allow you to "piggy back" off another spade. Look at your FLAPS. You may have to cut the choke wire and crimp one of these spades on there. I had the same issue once. Do you currently have 3 male spade terminals on the pos 15 and neg 1 of the coil?
73 VW T2 Sportsmobile T4 1800 dual webber ICT's
06 TOY Tacoma TRD
Don't mess with the DNR.
"Bargain hunter becomes the bargain hunted."
Crestrider
PostPosted: Sat May 11, 2013 11:18 am    Post subject: Reply with quote
Hi
Cheers for the reply, I have 4 male terminals 2 pos and 2 neg
Both pos are now used and one neg.
So what I should do is get a connector and join the red pos wire from the Pertronix to the black wire that leads to solenoid and auto choke (effectively all 3 wires off the pos 15 terminal?
Thanks
WI sportmobile
PostPosted: Sat May 11, 2013 11:29 am    Post subject: Reply with quote
Crestrider wrote:
Hi
Thanks
No The best option here is to get some three male spade termanals for the pos and neg of your coil for a total of six. This way you will not have to splice or crimp any wires.
06 TOY Tacoma TRD
Crestrider
PostPosted: Sat May 11, 2013 11:41 am    Post subject: Reply with quote
Ok, thanks very much for taking the time to post.
All the best.
