colins84 Samba Member
Joined: January 20, 2012 Posts: 104 Location: Orange, CA
Posted: Wed May 22, 2013 5:51 pm Post subject: Hole in Transmission? Gear Carrier |
Hey, Quick question. 1985 Westfalia. 1.9L, 091 Tranny.
I am in the middle of replacing my clutch. Noticed this small hole in the Gear Carrier on the transmission. There has been a small amount of gear oil coming out of this hole. I stuck a small flat head screw driver in there, and it is about a half an inch deep.
Any thoughts as to whether this hole should or should not be leaking?
What is this hole for?
Arrow points to the hole.
_________________ 1985 Vanagon Westfalia (Subaru EJ25 w/ Peloquin)
1986 Vanagon GL (2.2L) |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10486 Location: Orbiting San Diego
Posted: Wed May 22, 2013 5:55 pm Post subject: |
It is a breather vent hole so when the tranny gets hot and the gear oil expands it has somewhere to relieve the pressure instead of forcing it out the seals.
Lots of badly leaking trannys are because that vent gets blocked solid. Then the seals leak and replacing the seals won't stop it unless to unblock the vent too.
Mark
Last edited by crazyvwvanman on Wed May 22, 2013 6:23 pm; edited 1 time in total |
Posted: Wed May 22, 2013 6:00 pm Post subject: |
So does this mean that it is okay if it is dripping a bit? _________________ 1985 Vanagon Westfalia (Subaru EJ25 w/ Peloquin)
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2026 Location: Pittsburgh PA (ish)
Posted: Wed May 22, 2013 7:16 pm Post subject: |
| Install a small nipple into the hole and run a hose to a higher location if you want. This reduces the chance of the vent getting clogged by crap that collects on the top of the box. |
