Beetle 1300cc (Historic Touring Car Racing)
Page: 1, 2, 3  Next
hrsr
hrsr is offline
PostPosted: Fri May 24, 2013 10:51 am    Post subject: Beetle 1300cc (Historic Touring Car Racing) Reply with quote
She's getting quicker! Very Happy
Roadcow
Roadcow is offline
PostPosted: Fri May 24, 2013 11:10 am    Post subject: Reply with quote
nice job with the Cortina!
71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat
hrsr
hrsr is offline
PostPosted: Fri May 24, 2013 11:18 am    Post subject: Reply with quote
Yep!....Quicker on the day than four of the 911's, couple of Lotus Cortina's and a 7 litre Galaxie.
djway3474
djway3474 is offline
PostPosted: Fri May 24, 2013 12:10 pm    Post subject: Reply with quote
that motor sounds great. if you could get rid of some understeer you would be right up front.
hrsr
hrsr is offline
PostPosted: Fri May 24, 2013 12:40 pm    Post subject: Reply with quote
The understeer is just cold tires. Once they are up to temperature the car is pretty well balanced...Not a lot of grip though with skinny Historic crossply tires 120mm fronts and 135mm rears!
Boolean
Boolean is offline
PostPosted: Fri May 24, 2013 2:22 pm    Post subject: Reply with quote
Very nice work with that car! It sounds brilliant!
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
VW&MGman
VW&MGman is offline
PostPosted: Fri May 24, 2013 4:20 pm    Post subject: Reply with quote
Could you post some pictures of the out side of your car? I'm running a Beetle in vintage racing and just wondering if you have any aero devices on your car. Your steering seem very stable at 100 MPH as opposed to mine.
Thanks!
hrsr
hrsr is offline
PostPosted: Fri May 24, 2013 5:10 pm    Post subject: Reply with quote
Hi
No aero devices allowed so the cars stability is all down to the suspension setup. If you look at all 1960's, 1970's rear engined road racers (Porsches, Renault Alpines, Fiat Abarths etc) the rear end is always lower than the front. Rear engined cars must have more aerodynamic lift on the front than the rear (this is one reason why Porsche 911's have such large rear spoilers and the same reason why VW raised the Beetles front ride height by an inch or so in the late 60's, early 70's)
Set the rear end an inch or so lower than the front and you should see a difference on the straights AND in the corners.
Good luck!
Ian
[/img][/code][/url]
fcampbell356
fcampbell356 is offline
PostPosted: Fri May 24, 2013 5:29 pm    Post subject: Reply with quote
Ian:
Whats up with the motor? And what brakes are you running?
Cool cars, gotta love them.
Thanks
Frank
hrsr
hrsr is offline
PostPosted: Fri May 24, 2013 6:02 pm    Post subject: Reply with quote
CSP disc brakes all round with fast road pads. The brakes kept locking up when I tried using race pads as the skinny historic tires don't have enough grip to cope with the braking power.
The engine is fine, the stuttering in the corners is tire shake!!
I'm pushing the car so hard now that I'll need to start adding better bracing on the gearbox. I've also been told to replace the rear body rubber mounts (in front of the rear dampers) with metal spacers as this should stop the rear torsion housings from flexing.
fcampbell356
PostPosted: Fri May 24, 2013 6:57 pm    Post subject: Reply with quote
Main intrest in engine, size, carbs ect. You might consider one of the offroad type transmission strap kit like Bugpack list, their part number
6522. Look on the Bugpack or any offroad supplier for something similar.
to help with the tranny flexing.
Does the car feel stable at top speed? The sedans always wanted to fly around.
Thanks
Frank
hrsr
hrsr is offline
PostPosted: Fri May 24, 2013 10:39 pm    Post subject: Reply with quote
The Beetle is really stable and doesn't slide or twitch around anything like as bad as the Lotus Cortinas and Hillman Imps that I'm up against. If you notice on that lap, i'm going through bends at up to 83-99mph without any drama.
Car Spec: 1965 swing axle Beetle, CSP disc brakes all round, 1285cc, 44 Webers, Engle FK10 cam, reworked stock heads with stock sized valves, cooling by 12 inch electric fan and ram air pipes, approx 120-125bhp@ 8000rpm. Bears close ratio gearbox with a Quaife ATB diff, Dunlop historic crossply tyres, weight around 740kg with driver. Front suspension: Stock beam, springs and rubber bushes, adjustable Formula Vee anti-roll bar, 2.5" dropped spindles, Quantum double adjustable motorsport dampers. Rear suspension: Stock springs and rubber bushes, lowered 2 splines, custom made heavy duty adjustable Z-bar, Quantum double adjustable motorsport dampers.
dawie
dawie is offline
PostPosted: Fri May 24, 2013 11:54 pm    Post subject: Reply with quote
Nice. What is your compression ratio and fuel type/ octane?
John Moxon Premium Member
John Moxon is offline
PostPosted: Sat May 25, 2013 12:33 am    Post subject: Reply with quote
That looks a lot of fun Ian...thanks for posting. Keep 'em coming. Very Happy
John.
VW&MGman
VW&MGman is offline
PostPosted: Sat May 25, 2013 2:09 am    Post subject: Reply with quote
Thanks for the pictures. The car looks awesome!
Are you using any caster shims up front? How many pairs are you using?
bugguy076
bugguy076 is offline
PostPosted: Sat May 25, 2013 3:42 am    Post subject: Reply with quote
Outstanding !
hrsr
hrsr is offline
PostPosted: Sat May 25, 2013 7:15 am    Post subject: Reply with quote
I believe its 9.5: or 10:1 and it currently runs on regular 101 octane supermarket fuel...nothing fancy.
May try some Sunoco fuel at some point but it must be designated 'pump gas' to be legal for the racing, so there won't be any noticeable HP gains...may run cooler though.
hrsr
hrsr is offline
PostPosted: Sat May 25, 2013 7:26 am    Post subject: Reply with quote
I believe there is only one set because the front is barely 1 inch lower than stock. the rear is probably only 2 to 2.5 inches lower than stock.
Lowering your swing axle Beetle to the floor won't make it handle any better...It's a 1550lb car with a fairly low centre of gravity, so you can get away with plenty of suspension travel and quite a soft setup. As an example my front suspension moves by 4 or 5 inches (watch the front end when I brake hard)
boxkiteflyer
boxkiteflyer is offline
PostPosted: Sat May 25, 2013 10:54 am    Post subject: Reply with quote
What a nicely sorted car! Thanks for posting!
fcampbell356
PostPosted: Sat May 25, 2013 1:01 pm    Post subject: Reply with quote
Ian:
Please keep updating the thread with pics and details. Reminds me when some guys got together and ran a 71 or 72 Super Beetle in the Old
Trans-Am Series here in the States. They went so fast , bent the front
hood in and helped with the aero.
Page: 1, 2, 3  Next
