Squatty or tall manifolds on 2.0 carbed
williamM
williamM is offline
PostPosted: Mon Jun 03, 2013 7:16 am    Post subject: Squatty or tall manifolds on 2.0 carbed Reply with quote
I have just finished a 2.0 lt on 1800 heads and want to decide which intake manifolds for stock duals would perform the best and maybe some hints on jetting.
Also which tins cool the best on this set up?
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Bleyseng
Bleyseng is offline
PostPosted: Mon Jun 03, 2013 7:37 am    Post subject: Reply with quote
For best cooling make sure to use ALL of the tins and carefully fit them together including the very bottom pieces that cover the pushrod tubes.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
babysnakes
babysnakes is offline
PostPosted: Mon Jun 03, 2013 9:20 am    Post subject: Reply with quote
The shorter manifolds should provide more torque than talls. But the shortys also get hotter at the carb than a tall manifold.
williamM
williamM is offline
PostPosted: Mon Jun 03, 2013 9:50 am    Post subject: Thanks! Reply with quote
Would putting the FI insulator blocks in there help with the heat- Torque is good!
Don't step in any!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Jun 03, 2013 10:26 am    Post subject: Reply with quote
Tall. Easier to dial in, fuel has a better chance of vaporization. I ran shorts for ict's, swapped out for talls an had way better throttle response and they were easier to tune. Did I mention better throttle response?
Ditched it all and run dell 36's
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jun 03, 2013 10:42 am    Post subject: Reply with quote
tall will give a better low end as well as fuel mixing. In some climates it would be more prone to icing. I would think that on a bus tall would be better but were it me I call John at aircooled and asked him what his experience is with them. We have no idea what the resonate length is of your engine and what RPM you are trying to get max power out.
http://www.wallaceracing.com/runnertorquecalc.php
1600 (97cu) with 4 cylinders and 5000 RPM peak HP:
Optimum Intake runner area 1.37 square inches (calculated)
Optimum Intake Length 16.80 inches long (from valve head to plenum).
Bleyseng
Bleyseng is offline
PostPosted: Mon Jun 03, 2013 12:57 pm    Post subject: Reply with quote
Short if you want higher rev's but tall for better low end which IMHO is the best for a bus.
babysnakes
I've always used talls. When I got my second set of 34ICT's a couple of years ago they came with shorts. I used the talls because the shorts had no balance tubes to use for the power booster. They seem to work fine.
SGKent is offline
PostPosted: Mon Jun 03, 2013 1:28 pm    Post subject: Reply with quote
it is like a flute - the longer the tube the lower the oscillation frequency it supports. The optimal distance from the top of the air horn to the back of the intake valve would be 16.8 inches at a peak HP at 5000 RPM on a 1600 engine.
CoastalAirCooledVW
CoastalAirCooledVW is offline
PostPosted: Mon Jun 03, 2013 6:12 pm    Post subject: Reply with quote
What air cleaner set up are you planning on using? If you are going for a stock look I would recommend the tall manifolds so that you can use the paper air filter instead of the dual carb oil bath which I have a strong love hate relationship with.
1966 Velvet Green Standard
