starting problem
billclimbs
billclimbs is offline
PostPosted: Sat Jun 01, 2013 9:54 pm    Post subject: starting problem Reply with quote
This question is on my 85 Westy..for the past couple of years i have occasionally needed to giggle the steering wheel to get it to start. recently it became more. frequent and tonite at the beach it didnt start for abourt 20 minutes. tried a new key when i got home but that didnt seem to help. it makes the click and buzz sounds but wont turn over..a short somewhere?
rcook52459
rcook52459 is offline
PostPosted: Sun Jun 02, 2013 5:58 am    Post subject: Reply with quote
1st check to make sure connections are tight at starter and battery.have battery checked.if all checks out replace ignition switch
85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l
billclimbs
PostPosted: Mon Jun 03, 2013 9:15 pm    Post subject: Reply with quote
i will replace the switch...what is this pin they speak of on other threads...should this be replaced as well??
billclimbs
PostPosted: Tue Jun 04, 2013 9:36 pm    Post subject: Reply with quote
i ordered a beck arnley replacement switch...that a good brand?
dhaavers
dhaavers is offline
PostPosted: Wed Jun 05, 2013 4:57 am    Post subject: Reply with quote
Should be good as you can do nowadays. Get another spare for your
glovebox: the quality on these parts doesn't seem to be getting any
better, and you may need to do your next swap AT the beach...
"The WonderVan"
billclimbs
PostPosted: Sat Jun 08, 2013 7:18 pm    Post subject: Reply with quote
put in a new swith..the old one was cracked..evidence of the oil leaking out...but still it only clicks when i turn the key...checked the battery terminals...where are the other places i should check for ground, ect?
randywebb
randywebb is offline
PostPosted: Sat Jun 08, 2013 9:03 pm    Post subject: Reply with quote
oil leaked out of the ignition switch?
1986 2.1L Westy 2wd Auto Trans.
billclimbs
PostPosted: Sun Jun 09, 2013 7:37 am    Post subject: Reply with quote
i read somewhere that it had oil in it to prevent arcing?...whatever..there is a new one in..could it be the starter.i have forgotten what a starter acts like befor it dies
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Jun 09, 2013 7:44 am    Post subject: Reply with quote
I thought only British cars did that (they leak oil from everything).
I would clean/check all connections at the starter. Might be best to disconnect the battery while you do this (just disconnecting the ground cable from the battery is easiest and sufficient).
rcook52459
PostPosted: Sun Jun 09, 2013 8:55 am    Post subject: Reply with quote
take starter out and take to local auto parts store(they'll test it 4 free) and have them test it,if all connections are tight and battery is fully charged
randywebb
PostPosted: Sun Jun 09, 2013 1:07 pm    Post subject: Reply with quote
someone might have sprayed oil into the ignition switch, thinking that would cure a problem (like the one you are having)
the oil mechanical portion of the ignition switch should be lubricated periodically, just like other keyways, but a better choice is to hose the key down with Teflon spray and then insert it a few times
randywebb
PostPosted: Sun Jun 09, 2013 1:09 pm    Post subject: Reply with quote
" it [] clicks when i turn the key"
this means some power is getting to the solenoid, so you have eliminated some possible issues
absolutely, remove power before pulling the starter out
see the FAQ for pics of where gnds are located (for some years) and clean them all
billclimbs
PostPosted: Mon Jun 10, 2013 9:29 pm    Post subject: Reply with quote
i was going to add a ground to the starter...what size wire would you use
billclimbs
PostPosted: Mon Jun 10, 2013 9:31 pm    Post subject: Reply with quote
i was going to add a ground to the starter...what size wire does this need
Tobias Duncan
Tobias Duncan is offline
PostPosted: Tue Jun 11, 2013 9:34 am    Post subject: Reply with quote
Have you tried jumping the starter with a screwdriver?
billclimbs
PostPosted: Thu Jun 13, 2013 10:06 pm    Post subject: Reply with quote
Yes...did that which left only a bad connection. Took the battery ground off, took a grinder to the surface,sanded the connector and started right up. So simple. Check your grounds!!! Even if they look good. Thanks folks.. Get back to my 83 fuel injector problems
