Cargo door screw removal
CSR7644
CSR7644 is offline
PostPosted: Mon Jun 10, 2013 7:07 pm    Post subject: Cargo door screw removal Reply with quote
Can anyone suggest a good(easy)way to remove two stripped cargo door screws?? Sad
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Jun 10, 2013 8:05 pm    Post subject: Reply with quote
Which screws? Interior panel, pop out, hinge, strap door stop, rubber bumper, etc.....
In Stereo, Where Available!
BulletBus
BulletBus is offline
PostPosted: Tue Jun 11, 2013 6:01 am    Post subject: Reply with quote
No such thing as easy on this one. Start by using penetrating spray around the bolts and behind the hinge in the little open area. Then you have to step drill the bolts using small drill bits and stepping them up till you can get an easy out (usually nothing easy about them) in there. Give the bolt some heat with a torch and a couple good whacks using a screwdriver on the center of the screw. Lots of patience. Good luck.
53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen.
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Tue Jun 11, 2013 6:42 am    Post subject: Reply with quote
Welding a nut to the head of the screw works a lot of times too
Mitch Case
Mitch Case is offline
PostPosted: Thu Jun 13, 2013 4:25 pm    Post subject: Reply with quote
You can also try to drill the center out just smaller than the threads and and use an easy out to try to back the remaining screw out. Heat is allways good
Check out a few of my projects.
61 mango
http://www.thesamba.com/vw/forum/viewtopic.php?t=269607&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=281851&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=428154
http://www.thesamba.com/vw/forum/viewtopic.php?t=429578
http://www.thesamba.com/vw/forum/viewtopic.php?t=439644&highlight=
View user's profile Send private message Send e-mail Facebook Classifieds Feedback
Eric&Barb
PostPosted: Thu Jun 13, 2013 6:42 pm    Post subject: Reply with quote
Skip the easy out!! All too easy to break it off in there and it is hardened so it will not be drillable........
BarryL Premium Member
BarryL is offline
PostPosted: Thu Jun 13, 2013 7:07 pm    Post subject: Reply with quote
There's a video of how that guy did his in The Funky Truck thread. Maybe someone can link it.
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Thu Jun 13, 2013 7:14 pm    Post subject: Reply with quote
drill and retap it
Why buy what you can build.
campingbox Premium Member
campingbox is offline
PostPosted: Thu Jun 13, 2013 7:24 pm    Post subject: Reply with quote
Get one of these for your air chisel - then add a phillips impact driver bit.
I have removed screws that that no longer looked like phillips heads before.
I would only use this to knock it loose, once it's loose then try threading it out normally.
glideking
glideking is offline
PostPosted: Thu Jun 13, 2013 7:39 pm    Post subject: Reply with quote
There ya go.
"The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639
PostPosted: Thu Jun 13, 2013 7:54 pm    Post subject: Reply with quote
http://www.yardstore.com/browse.cfm/4,3698.html
MrBusCo
MrBusCo is offline
PostPosted: Thu Jun 13, 2013 8:33 pm    Post subject: Reply with quote
X2 on this tool. I have the longer version and it works great.
Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com
View user's profile Send private message Visit poster's website AIM Address Facebook Gallery Classifieds Feedback
vwserphguy
vwserphguy is offline
PostPosted: Thu Jun 13, 2013 9:55 pm    Post subject: Reply with quote
glideking wrote:
There ya go.
Great video (and some funny moments) on how to remove frozen screws with your welder.
"Relax and just enjoy the ride knowing everybody passing is wishing they had one."
BulletBus
PostPosted: Fri Jun 14, 2013 6:20 am    Post subject: Reply with quote
At least we know that Gary Bussey's brother is doing well. Laughing
53 Hatch Barndoor
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Fri Jun 14, 2013 8:27 am    Post subject: Reply with quote
I second this.
I removed several frozen gate hinge screws from my SC this way.
Drilled out the screw slightly smaller than thread size. The stripped Phillips centres the bit nicely.
Then heat it up real good with a micro torch aimed in the drilled hole and the Easy Out should turn it out effortlessly.
This method spares the original paint around the screw head.
Always got to be careful with an Easy Out and I would not attempt the Easy Out without heat.
Like E&B said, they are a bitch to try to drill out.
Welding a nut on the head works well too, as the heat breaks the corrosion bond, but it is harder on the surrounding paint.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
